cooling system flush - Help!!!- - Mustang Evolution
Old 11-09-2007, 12:23 PM   #1
00stang3.8's Avatar
I want to flush the coolant system in the stang becuase it has 72,000 on it and has never had one to my knowledge. I am confused though. Haynes repair manual says to take out the drain plugs in the block as well as the one on the radiator. Is this necessary? Also, I bought radiator flush to put in as well, is this safe?? What is the best way to make sure I am getting the right 50/50 mix of antifreeze/water?? Any help would be appreciated, I don't want to break anything and I've never done this before. Thanks!
00stang3.8 is offline   Reply With Quote
Old 11-11-2007, 06:31 PM   #2
Re: cooling system flush - Help!!!-
It depends no how you wish to go about it. You can drain just the radiator and change about 2 gallons of it~ There will still be some left in the system.
Since your car has NEVER had it changed (which is not good) you can pull the plugs on each side of the block and rain more of it. I would do this. The only downside is getting the air out of the system. You can get a shop to vacuum the system and suck the coolant back into the engine and this works very well~ but you will be paying for a coolant change at a shop. I would flush it out as well with some distilled water before putting new coolant in it.
Run the 50/50 premix that mixes with any coolant type. DO NOT put tap water in your engine. You can rinse it out with it if you must but dont let it stay in there.
Old 11-11-2007, 11:10 PM   #3
DarkShadow's Avatar
Send a message via AIM to DarkShadow
And that right there is what pisses me off so bad about 90% of the customers that come into my store.
"Bah I don't want that premix ****! That's stuff **** and I'm not paying extra when I can just stick a hose in my radiator!"
Freaking idiots.
DarkShadow is offline   Reply With Quote
Transmission Flush runvsofthisbull Pre-2005 V6 Mustang 13 06-26-2008 11:01 AM
Need help with cooling system Dman Pre-2005 V6 Mustang 5 06-16-2007 10:35 PM
Burping the cooling system? I_luv_HP&trq General Car Discussion 2 09-06-2006 09:55 PM
My Cooling System 04MonteSS The Bar 12 07-30-2005 03:50 PM
How to: Steering Fluid Flush? cagedthought Pre-2005 V6 Mustang 2 10-24-2004 09:30 PM
02:29 AM
