Clutch?..... - Mustang Evolution
Old 01-15-2012, 03:38 PM   #1
CashKash147's Avatar
Region: Nebraska
Send a message via Skype™ to CashKash147
Clutch?.....
Hey I have a quetion and if anyone could answer please do!
-ok I have a 01 mustang v6 manual and there is a sqeaking noise coming from the front of my car and when I place my foot on my clutch it stops ... And then when I let go it sqeakes again... What's up with my car?
CashKash147 is offline   Reply With Quote
Old 01-15-2012, 03:43 PM   #2
Patcurrie008's Avatar
Region: Wyoming
I had a 02 gt and my clutch did the same thing before my clutch blew up. Hopefully it doesn't happen to you but you might wanna get it checked out before your driving and it blows up. Thats what happened to me
Patcurrie008 is offline   Reply With Quote
Old 01-15-2012, 03:45 PM   #3
jhagan1980's Avatar
Sounds like the throw out bearing.
jhagan1980 is offline   Reply With Quote
Old 01-15-2012, 04:00 PM   #4
Gster's Avatar
+1
Gster is offline   Reply With Quote
Old 01-15-2012, 06:30 PM   #5
Matney10's Avatar
Juss had to deal with this same problem. The throw out bearing was worn out and that was causing the squeaking. I went ahead and changed the clutch while I was replacing the TOB tho. Good luck.
Matney10 is offline   Reply With Quote
Old 01-17-2012, 04:18 AM   #6
TaylorF25's Avatar
Its the throw out bearing like stated above
TaylorF25 is offline   Reply With Quote
Old 01-19-2012, 06:45 AM   #7
MikeWatkins17's Avatar
I'm having the same issue, can you just replace the TOB or should i just do a new clutch?
MikeWatkins17 is offline   Reply With Quote
Old 01-19-2012, 06:54 AM   #8
Matney10's Avatar
Well since you already have to take the trans put to put a new TOB in I would go ahead and replace the clutch unless it was replaced recently.
Old 01-20-2012, 03:24 AM   #9
Re: Clutch?.....
Very common with our cars. Throw out bearing. Try getting under and put pressure against the clutch fork. There is always play in it and it rattles. Tighten it up too much and the pilot bearing is always engaged.
If u have air in the break fluid can that make ur clutch pedal feel stiff? bluestorm52 2005-2010 Mustang GT 7 12-10-2011 04:49 PM
New guy with a clutch question Cajunick 1996-2004 Mustang GT 7 11-15-2011 11:32 AM
Clutch just went 04machazblue 1996-2004 Mustang GT 9 08-24-2011 05:41 AM
Spec or ram clutch 04machazblue 1996-2004 Mustang GT 3 08-23-2011 04:36 PM
Clutch? :( nickysixx 1996-2004 Mustang GT 5 07-08-2011 04:13 PM
12:50 PM
