Gt rear end - Mustang Evolution
Old 01-17-2012, 08:00 PM   #1
Gt rear end
I hear about how you can put a Gt rear end on a v6. What's the benefit from this? And what do I have to get to do this? The whole rear end? Need info on this bc I'm planing on doing this
Blackedout is offline   Reply With Quote
Old 01-17-2012, 09:01 PM   #2
Re: Gt rear end
Well there's definitely a benefit...actually more than one
The GT's rearend is 8.8" compared to the v6's 7.5". The larger rearend (ring gear) is much stronger and capable of handling much more hp, or stress.
The 8.8" comes with a traction lok and 3.27 gears. The standard tlok will allow you to do 2 wheel burnouts and give better traction/launches.
The 7.5" has the open differential, which allows only one wheel to spin. The gearing is the same too, 3.27.
The 8.8" will bolt right up in place of the 7.5". The GT's had quad shocks as to where the v6's did not.
The chassis brackets are not on the v6's but the threaded holes for them are. So if you can get the brackets from the same car you get the rearend from do it. You can get brackets from cars as far back as the 80's (fox bodies).
The only reason you wouldn't want the quad shocks (axle dampers), is if you get aftermarket LCA's. They come with much better poly bushings that tend to eliminate wheel hop, which is why the quad shocks were there in the first place.
Old 01-17-2012, 09:38 PM   #3
Fordhartbreaker's Avatar
Very well said
Fordhartbreaker is offline   Reply With Quote
Old 01-18-2012, 12:04 AM   #4
To piggyback on the original post, what are the benefits of an IRS upgrade? Which is better, IRS or 8.8?
Stubzmekenzie is offline   Reply With Quote
Old 01-18-2012, 05:44 PM   #5
Re: Gt rear end
It's a matter of opinion. IRS is a novel thing to make you think your car handles better in my opinion.
It does ride better and give better angles for the rear tires, but a solid axle car can handle just as well, if not better with current technology.
Old 01-18-2012, 06:45 PM   #6
So what all I need to swap the my 7.5 to the 8.8?
Old 01-18-2012, 07:36 PM   #7
The 8.8
Old 01-18-2012, 08:22 PM   #8
Can I keep the stock driveshaft from my v6?
Old 01-19-2012, 02:55 PM   #9
davidcseifert's Avatar
Region: Arkansas
Re: Gt rear end
yes.... direct swap in
you have big plans for the future? if anything past 350rwhp then yes upgrade, if not just put a posi in your 7.5.... with the unneeded (for anything within normal build standards) extra strength of the 8.8 rear comes an extra hundred or so pounds.... would slow you down more than help honestly
i have the cheap FRPP T-lok in my 7.5 and it has been holding up just fine to 242rwhp lol
blower/new cam soon
Old 01-19-2012, 03:09 PM   #10
Crazy idea actually I wanna drop a crate motor in it
Old 01-19-2012, 03:24 PM   #11
Region: Arkansas
Re: Gt rear end
-_- that would have been worth the mention in the original post in asking if the swap is worth it.........
is this just an "idea" or a plan?....
blower/new cam soon
Old 01-19-2012, 04:41 PM   #12
Well I know I've been flip flopping my ideas, but after much research- I'm just going to get a supercharger from American muscle that's easier than swapping. I been wanting to do something to get to at least 300 hp. Supercharging is what I wanna do.
---------- Post added at 05:41 PM ---------- Previous post was at 05:38 PM ----------
So my new thing to research is the supercharger. I have a question what should I modify for 11 psi?
Here's the site. http://www.americanmuscle.com/procha...e2-9903v6.html
Rear End Swap Sycopath80 2005-2010 V6 Mustang 3 12-30-2011 11:25 AM
95 8.8 5Lug Rear End into 87 5.0 Fox mcdonaldnick 1979-1995 Mustang GT 2 10-12-2011 06:03 PM
Rear end swap bmabbott Pre-2005 V6 Mustang 9 10-01-2011 12:14 AM
1996 mustang GT rear end gear change soldierdude28 1996-2004 Mustang GT 6 08-24-2011 03:15 PM
Any idea of what rear end gears i may have in my 92 GT? macmarine39 1979-1995 Mustang GT 4 07-16-2011 08:25 PM
09:44 AM
