timing problems on 94 3.8 - Mustang Evolution
Old 11-12-2007, 10:18 PM   #1
eagle05's Avatar
Cool timing problems on 94 3.8
Ok just bought this car for my daughter it matches my 95 gt under the carport. its a good looking car. problem is the timing is off and it don't make sense it doesn't matter if i pull the spout or not its at about 30deg BTDC "makes it a bit hard on the starter to crank too" from what i have read it gets it signal from the crank shaft sensor on the front of the motor "right behind the 10 degree mark that it suppose to line up with" and it senses the teeth on the gear bolted to the balancer or is it part of the balancer I haven't had time to really check yet. anyway i may have a couple of problems " because the timing mark didn't change when I unplugged the spout connector" but i feel like something "like this gear" isn't lined up right any Ideas any help i would be thankful for. thanks in advance. Wayne in SC
:drive:95 GT T5 K&N filter B&M Pro ripper kicked the cats out and flowmasters :burnout:
eagle05 is offline   Reply With Quote
Old 11-13-2007, 05:58 AM   #2
Herbstang's Avatar
Re: timing problems on 94 3.8
Make sure the motor is a top dead center on the compression stroke and line it up with the cam. The notch on the cam should be pointed straight down at the notch in the gear on the crank. timing is supposed to be set at 10* advanced with the spout out.
This may help Ignition Timing
Old 11-13-2007, 07:31 AM   #3
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
I had the same problem one time. couldnt get timing set right. took it to ford and It was some timing computer underneath the dash that went bad. cost me 1k to get replaced including labor.
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 11-13-2007, 03:15 PM   #4
eagle05's Avatar
can't see paying ford for this need some good info and I can fix I was a crypto tech in the army i have 5 years as electrician in a finishing plant and about 5 years as a instrument tech after that I just need some drawing of the circuit and a better understanding of how this gear mounts to the shaft before I jump on it. but thanks for the advise. friends.
Old 11-21-2007, 03:57 PM   #5
eagle05's Avatar
ok I think this is not the spout connector I have pulled its the octane adjustment plug where is the spout connector on these 3.8 94 mustangs?
Old 11-25-2007, 09:09 AM   #6
eagle05's Avatar
Ok I found the Spout connector its by the MAF and hidden under the MAF wire. The timing was correct after all. The battery was week even though it showed 12.45 volts it only had 160 cranking amps I had it load tested at the zone and bought a new one sorry guys but thanks for the help.
Old 11-25-2007, 10:27 AM   #7
MonteCitan's Avatar
Yeah, that battery was toast haha
Glad you figured it out!
Good luck with her new car
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 11-26-2007, 07:00 AM   #8
Herbstang's Avatar
Glad you got it running !!! Guess we over thought the problem !!! Damn Battery
3.8 timing marks. Foxone Pre-2005 V6 Mustang 0 05-26-2010 06:43 PM
Timing is off!!!! ballajb 1979-1995 Mustang GT 2 10-28-2009 02:09 PM
TIMING HELP!?!? timeformiller44 1996-2004 Mustang GT 2 04-27-2009 10:05 AM
need help figuring out timing bearbackcowboy Pre-2005 V6 Mustang 1 09-18-2008 09:31 AM
Timing question damighty5.0 1979-1995 Mustang GT 12 05-22-2006 04:23 PM
08:16 PM
