So, slight problem... - Mustang Evolution
Old 01-19-2012, 10:24 PM   #1
Las0mbra's Avatar
So, I was blasting through my neighborhood last night ( I know, stupid.), but as I was saying. Came to a stop sign. I was flooring it and then just let off, and by the time I had come to a complete stop, my car just died, wtf? Also, I was coming back from off campus lunch at school and I floored it and let off and went to neutral and it almost died again! Anybody have any ideas? I've already cleaned my IAC valve recently too.
Old 01-19-2012, 11:00 PM   #2
2003SonicBlue's Avatar
Does the engine completely shut off?
2003SonicBlue is offline   Reply With Quote
Old 01-19-2012, 11:15 PM   #3
Las0mbra's Avatar
Well, that one time it did, the second time it dropped to 250 before I revved it back up.
Old 01-19-2012, 11:31 PM   #4
Sounds like the clutch isn't catching in the proper position? Warped clutch? I'm no expert though!
Old 01-20-2012, 10:32 AM   #5
Las0mbra's Avatar
Bump. I really need some help with this guys!
Old 01-20-2012, 01:21 PM   #6
Fordhartbreaker's Avatar
Idle air controle valve mine does the same thing
Fordhartbreaker is offline   Reply With Quote
Old 01-20-2012, 01:47 PM   #7
DaBluedude's Avatar
Yeah sounds like an iac issue.
2003 Mach 1
Old 01-21-2012, 03:40 PM   #8
Las0mbra's Avatar
I don't know... I've already cleaned it. Ugh.
Old 01-21-2012, 03:46 PM   #9
Jamesgt08's Avatar
Clean ur idle air control and ur MAF sensor. Clean out ur throttle body and plenum. And check for vacuum leaks.
Jamesgt08 is offline   Reply With Quote
2000 GT starting problem jjsg09 1996-2004 Mustang GT 53 02-01-2012 08:19 PM
Cut out problem 89white GT 1979-1995 Mustang GT 3 01-05-2012 05:48 AM
Problem with OBD Code P0455 tonyjuan 1996-2004 Mustang GT 8 08-24-2011 09:51 PM
Please Help Transmission Problem znpzmustang Pre-2005 V6 Mustang 1 07-26-2011 12:52 PM
10:32 AM
