Removing Cluster Needles - Mustang Evolution
Old 01-19-2012, 11:32 PM   #1
2003SonicBlue's Avatar
Anybody know anything about it or if it messes up the dash... I want to know if it will break it.... Trying to remove film behind needles... Thanks!
2003SonicBlue is offline   Reply With Quote
Old 01-20-2012, 03:14 AM   #2
Re: Removing Cluster Needles
They make a tool that looks like a fork but I have always just pulled them off. When you put them back on, just make sure not to push them in too far so that they don't bind or get caught up.
Old 01-20-2012, 05:34 AM   #3
If I put them in the correct spot and everything will it mess with my calibration?
Old 01-20-2012, 10:05 AM   #4
97Stallion's Avatar
Nope, but before you pull them, make sure you remove the posts that the needles rest on. The needles wil move past the posts slightly, so when you put them back on you put them pointing in that direction instead of just resting on the post.
Living one day at a time!
Old 01-20-2012, 10:07 AM   #5
ive taken mine off, you just have to pull them straight up and out (not from the side). My gauge kit came with two little "tools" (bent peices of metal) that you slide under each side of the needle and push them down to push up the needle and it pops off the little pin it sits on.
ONCE they are off they MUST be calibrated to go back on FYI (on 99+ you can calibrate them rather easy on your own).
Putting them back on take note of how far they sat off the face and return them to that spot.
I mark all gauges where they are when the car is fullly warm etc and fill up the car with gas all the way etc and mark that one etc. That only leaves speedo/rpm. The dash cluster can tell you those... you just have to go driving and set cruise and then slide needle on.
I recommend leaving the plastic cover off a bit just to make sure they work then put it back on.
Old 01-20-2012, 12:43 PM   #6
This all sounds sketchy lol I put in blue LEDs but It looks weird with green film behind... Any ideas?
Removing cats from stock h pipe 2003-04 mach 1 Mach1Bob General Mustang Discussion 26 10-16-2014 07:38 AM
Removing decals V6pwny12 2011-2014 V6 Mustang 15 01-20-2012 04:49 PM
cluster change 88fox 1979-1995 Mustang GT 26 12-02-2011 05:37 PM
does cluster gauge affect sensor?? jmpark527 2005-2010 Mustang GT 0 11-23-2011 08:32 AM
Instrument cluster question matthoffman22 1979-1995 Mustang GT 3 06-25-2011 08:11 PM
05:38 PM
