HIDs - Mustang Evolution
Old 01-20-2012, 08:07 PM   #1
MikeWatkins17's Avatar
HIDs
Hooked up this hid kit i got, basically plugged what fit together, together and hoped for the best. first thing i noticed was when low beams are on, on the dash the hi beam symbol is dimly illuminated and when i flip highs on, lights dont get brighter but the symbol does. now after getting in my car again only one headlight works? what could i have done so wrong?
MikeWatkins17 is offline   Reply With Quote
Old 01-20-2012, 08:16 PM   #2
Justasix98's Avatar
Mine do the same thing, when hooked up the bright light illumination in the dash comes on, but you flip on the brights and only the passenger light stays on, right ? It's the ballast, only for single beam, not hi & low..
Just A Sixxer!
Proud member of WickedStangs Okc Chapter!
Justasix98 is offline   Reply With Quote
Old 01-20-2012, 08:28 PM   #3
Right now only one light is on (passenger) on hi or low, is the driver side one blown already or?
Old 01-20-2012, 09:44 PM   #4
Re: HIDs
Two things-
Did you purchase a "Bi-Zenon" kit?~Hi/Low Beam Kit~
Did you verify that when bulb extends outward for high beam, that it has the room to do so without hitting the lens or headlight somewhere.
Old 01-21-2012, 07:36 AM   #5
yeah its a bizenon hi low, it came with the headlights i bought so i would think they were designed to work together and give the bulb enough space
Old 01-21-2012, 09:15 PM   #6
Re: HIDs
OK, There should be some HID lighting sites that have illustrations as to how to plug everything together step by step or hopefully the seller will provide you the answer. I bet your not the first to question it.
-Did it come with a negative and a positive small wire to connect to battery post? Sounds like a short or no negative/ground connection.
Old 01-21-2012, 10:24 PM   #7
Yeah, there was one red that i connected to pos on battery and 2 blk wires that i grounded to the car. first test both lights came on but didnt switch btwn hi and low, now just one light works. thinking im just going to order a new kit from myhidkit.com instead of messing with this ebay set up
HIDS! ! stangstar92 1996-2004 Mustang GT 2 12-30-2011 10:48 AM
HID lights Petty_stang Pre-2005 V6 Mustang 14 12-10-2011 04:32 AM
HIDs Artaz Mustang Paint, Appearance & Detailing 4 10-14-2011 09:23 PM
HIDs Jump3back 2005-2010 V6 Mustang 7 10-13-2011 03:18 PM
What are the best HIDs for a 07 stang Redmustang2007 Pre-2005 V6 Mustang 4 06-30-2011 06:55 AM
04:48 PM
