Rpm sticking - Mustang Evolution
Old 01-21-2012, 04:00 PM   #1
Surffer227's Avatar
Rpm sticking
Have a manual 01 v6 and I know that my throw out bearing is going bad, but when I push in the clutch and coast my rpms jump up to like 2,500 or 3,000 and stays until I come to almost a complete stop, then it drops to like 1,000. Could it be the clutch? Or my dads friend said something about a vacuum leak, someone helpp pleaseee.
Surffer227 is offline   Reply With Quote
Old 01-21-2012, 05:36 PM   #2
Project Pony's Avatar
Its easier and cheaper to check for a vacuum leak, I'd start there first.
[SIGPIC][/SIGPIC]
Old 01-21-2012, 06:15 PM   #3
Sounds like a vacume leak but ive seen this happen with an exhaust leak as well something about the back pressure. Do u smell exhaust in the car? If not id start checking ur vacume lines. If so trace ur exhaust and look for damage or cracks or holes. Its prolly vacume though.
Hawk is offline   Reply With Quote
Old 01-21-2012, 06:38 PM   #4
Surffer227's Avatar
Well I only have one cat, my pasenger side just has a pipe welded in
Old 01-21-2012, 11:44 PM   #5
Deff look for a vacume leak its more then likely that.
Old 01-22-2012, 01:48 PM   #6
97Stallion's Avatar
Re: Rpm sticking
Nope it has to do with your IAC. I would get a restrictor plate or make one and bolt that baby on. It's not uncommon for the 5-speeds to do this. I had the same thing on my mustang till i made my restrictor plate. Worked like a champ.
Living one day at a time!
Myths about "back-pressure" Eturner General Mustang Discussion 45 09-08-2016 01:31 PM
2 step rpm 94GTx306 1979-1995 Mustang GT 1 12-18-2011 12:53 AM
Rpm at launch willrad00 Pre-2005 V6 Mustang 3 11-14-2011 09:38 PM
Dyno numbers are here!! Benzo 2011-2014 Mustang GT 32 11-07-2011 04:55 PM
V6 RPM Spad 2005-2010 V6 Mustang 5 07-26-2011 04:28 PM
01:12 PM
