gt k member - Mustang Evolution
Old 01-22-2012, 02:28 AM   #1
97V6stangct's Avatar
gt k member
I'm trying to do weight reduction an I can't find a light weight k member for my car will a gt one work? An if you any sites with good products let me know thanks
97V6stangct is offline   Reply With Quote
Old 01-22-2012, 11:30 AM   #2
97Stallion's Avatar
Re: gt k member
The Gt and V6 K-member is the same part. But that's all the info i'll give you because you have that damn chevy corvette in your avatar.... Remove it and maybe we'll talk more!!
Living one day at a time!
Old 01-22-2012, 12:58 PM   #3
Well I'm sorry you feel that way but that's my dads car he bought brand new in 77 an I restored it for him last year so I show my respect to him but thanks for the info.
Old 01-22-2012, 02:23 PM   #4
97Stallion's Avatar
Re: gt k member
LOL, well..... since it's your dad's I can under stand the respect thing so here is some more info for you.
Stock 94-98 K-Member: 58 lbs
Aftermarket: AJE Tubular Mild Steel 24lbs
UPR Tubular Chromoly 19lbs
I hope this helps. Sorry about giving you some much crap earlier.
Old 01-22-2012, 07:22 PM   #5
Haha Ur good man and thanks trying to get my lil 6 to handle better
Old 01-22-2012, 07:38 PM   #6
Well I have a question can you help? Can I put a crate motor on the Gt k member?
---------- Post added at 07:38 PM ---------- Previous post was at 07:32 PM ----------
In particular a 327SR roush crate motor
Blackedout is offline   Reply With Quote
Old 01-22-2012, 08:45 PM   #7
97Stallion's Avatar
I should probably clarify myself before someone yells at me. The 94-95 GTs with a 5.0 have the same k-member as the V6. The 4.6 had a slightly different k-member thats sits an inch farther back. When Ford first built the Mustang in 94, everything was the same body/suspension wise until the engine went in. Some cars just got a V6 while others got the V8. So that should also answer the question about the 327 since it is a stroked 302.
Old 01-22-2012, 10:24 PM   #8
Thanks Stallion. So no need to buy a k member?
Old 01-23-2012, 10:21 AM   #9
97Stallion's Avatar
Re: gt k member
I'm about 99% sure you shouldn't have to.
Old 01-23-2012, 10:42 AM   #10
mustangg2000's Avatar
Region: Arkansas
I got a 2000 v6 stang was told k member is the same as fox body 302 k members and bolt up just fine.. I'm getting a 5.0 H.O to drop in it was also told it will bolt up to my T5 trans as well ill have to use 5.0 engine bell houseing cause starter.. my question is electrial side do I get a harness conversion tip that will connect 5.0 computer to v6 interior electrical harness.. so my cluster gauges and interior lights will work ??
mustangg2000 is offline   Reply With Quote
New Member, New GT DBAVIS 2011-2014 Mustang GT 19 01-14-2012 08:13 PM
my 04 gt, vs 03 cobra and 2011 mustang gt secomejia 1996-2004 Mustang GT 57 01-04-2012 09:07 AM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 05:49 AM
08:49 AM
