Value of Midpipe - Mustang Evolution
Old 01-23-2012, 09:01 AM   #1
willrad00's Avatar
Value of Midpipe
So the 3.8 mustang having the even firing engine a mid pipe shouldnt boost hp at all. So my question is why do so many people spend the extra money for the X or H pipe if its not adding anything, is it just sound? I'm starting to piece together my exaust system and i dont know if i wanna go straigh duals.
Any opinions?
willrad00 is offline   Reply With Quote
Old 01-23-2012, 10:15 AM   #2
kickerofdoom's Avatar
Just sound, the x pipe can maybe add one or two at the top end. I love my straight through
Old 01-23-2012, 10:27 AM   #3
97Stallion's Avatar
Re: Value of Midpipe
Actually, it helps balance the pressure and helps with scavenging. You're not gonna get huge gains from this, but every little bit helps.
Living one day at a time!
Old 01-23-2012, 10:41 AM   #4
Eturner's Avatar
+11
Old 01-23-2012, 10:44 AM   #5
deadsp0t's Avatar
Traditionally the X helps up top and is more raspy, and the H helps down low and has a deeper sound- I would think it'd be similar on the 6 as well
That's unimpressive
Old 01-23-2012, 10:46 AM   #6
Eturner's Avatar
It is the same!.. Just your gains won't be as good do to the smaller displacement!.. But the exhaust still works the same!...
Old 01-23-2012, 12:34 PM   #7
97Stallion's Avatar
Actually my x-pipe sound pretty damn awesome!! not raspy up top.
Old 01-23-2012, 12:48 PM   #8
deadsp0t's Avatar
As compared to?
That's unimpressive
Old 01-23-2012, 01:18 PM   #9
Eturner's Avatar
As compared to?
As compared to what your whole setup really is!.. Me and a buddy of mine have the exact same cat back system but different mid pipes!.. His is an o/r H-pipe and mine is a o/r X-pipe!.. There is very little difference in the sound between the two, just that his is a slightly deeper tone!..
Old 01-23-2012, 01:21 PM   #10
MAC prochamber ftw!!!
Hawk is offline   Reply With Quote
Old 01-23-2012, 01:41 PM   #11
97Stallion's Avatar
Originally Posted by deadsp0t View Post
As compared to?
I have an extreme setup. I used to have an O/R H-pipe. Now i have a hi-flow catted x-pipe. Much better sound. Plus I have a radical cam compared to most, so that helps alot. I have a 224/230 cam if you are wondering. Very lopey and deep. Plus i have some flowmaster 40s on my setup as well.
Old 01-23-2012, 01:45 PM   #12
irishn8's Avatar
Best answer
Old 01-23-2012, 02:46 PM   #13
being an even fire motor, is there really an issue with balancing or just not as bad as an odd fire car?
I would assume its mostly due to the design, not because its needed... you just expect to see a balance pipe so you get one.
Old 01-23-2012, 03:01 PM   #14
97Stallion's Avatar
You are correct, it's almost a non-issue with the balancing. But as I said before, every little bit helps. The main benefit comes from the scavenging reducing the pressure and strain on getting that exhaust out of the chamber which is why equal length long/short tube headers work so well. They provide a constant equal "vaccum" on the exhaust to suck the air out of the chamber
Old 01-23-2012, 05:37 PM   #15
willrad00's Avatar
Hmm, for 1 or 2 horses i'll probaly just skip the midpipe. Someone was tellling me that the i should go 2.5 piping instead of 2.25 cus the 2.5 will be louder, any truth to that?
Old 01-23-2012, 05:54 PM   #16
austinknoll's Avatar
What the difference between even fire and odd fire? I have a clue it Moght be the order in which the plugs fire but idk
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 01-23-2012, 06:14 PM   #17
Eturner's Avatar
Top view of the 4.6 engine cylinder #s!...
4 8
3 7
2 6
1 5
The firing order is. 1, 3, 7, 2, 6, 5, 4, 8
Old 01-23-2012, 11:21 PM   #18
That is a very weird order
---------- Post added at 12:21 AM ---------- Previous post was at 12:19 AM ----------
Why would that effect the noise of the exhaust though?
65 Mustang coupe
Old 01-23-2012, 11:28 PM   #19
irishn8's Avatar
I don't know why it has a firing order like that. I never really noticed how weird it is.
Old 01-24-2012, 06:32 AM   #20
Eturner's Avatar
Yes it is!.. Because instead of it being Left side then Right side and back n forth like that!...
Old 01-24-2012, 08:59 AM   #21
Could that be why my friends Tacoma has a mug better sounding flowmater than mine? We both have the same muffler but his sounds amazing
65 Mustang coupe
Old 01-24-2012, 09:03 AM   #22
Eturner's Avatar
I can't believe you just said a Toyota sounds better than a Mustang!!!.....
Old 01-24-2012, 11:00 AM   #23
irishn8's Avatar
Ya! GTFO! Lols
Old 01-24-2012, 11:12 PM   #24
The single muffler Isnt loud enough
65 Mustang coupe
Manifold to midpipe question jwhayne0001 1979-1995 Mustang GT 7 12-15-2011 05:45 PM
Gt midpipe on v6 Dgerow12 Pre-2005 V6 Mustang 3 10-04-2011 12:58 PM
midpipe kickerofdoom Pre-2005 V6 Mustang 8 08-13-2011 11:03 PM
Midpipe Question CodyNelson 1996-2004 Mustang GT 2 08-02-2011 08:45 AM
03:31 PM
