fog lights - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 11-15-2007, 10:39 AM   #1
98mustang2007 is unknown around these parts
fog lights
hi everyone Ive gotten a lot of good info from her the last couple months. I am getting fog lights and the directions say hot wire to battery where is the best place for hot wire if I only want it hot when key is on .can the hot wire be connected to one of the fuses under th hood . thanks
98mustang2007 is offline
Old 11-15-2007, 04:34 PM   #2
Terminator Owner
SpectorV is just getting started.
Re: fog lights
The way I would probably wire up my fog lights would be to use a Relay. A relay will allow you to run a wire from the battery straight to the fogs and use another source to turn the relay on/off to turn the fogs on/off.
Wire up the relay somewhere safe, like right beside the battery (a fuse on it as well that is 18 inches away from the battery) and then run the wire to the fog lights. Then for the wire that tells them when to turn on run a the wire that is hot when the parking lights are hot down to the relay. So when ever the parking lights are on the fogs will be.
You can also buy a wiring harness and wire up a switch and such its just more work.
SpectorV is offline
Old 11-16-2007, 05:52 AM   #3
greenpony02 is unknown around these parts
Re: fog lights
Also it is technically illegal to allow your fog lights to stay on when you turn on your high beams. I'm not sure if you're in a state that has inspections or not. To make it so they turn off with your high beams, run the fog light ground wire to the high beam positive wire.
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline
Old 11-16-2007, 06:47 AM   #4
Herbstang's Avatar
Herbstang is unknown around these parts
Re: fog lights
One the site sponsor has a wiring kit Do a search for fog lights VMP Tuning - Ford SCT & GM HPT Custom Handheld Flash Tuners
Mods-K&N CAI , True Dual Flowmaster 40,BBK Ceramic Shorties,3.73 ,T-Lok, 25% UDP, 3/8 Phenolic Intake Spacer ,Steeda Tri-ax, SCT Chip/Dyno Tune
Herbstang is offline
Closed Thread
Fog Lights PenguinFan Pre-2005 V6 Mustang 31 08-01-2009 01:32 AM
fog lights immenukka Mustang Audio & Video 22 06-18-2007 07:09 PM
Swap my Cobra fog lights for your GT fog lights TheDad Mustang Parts for Sale and Wanted 1 01-19-2006 01:01 PM
Fog lights mustang22 Mustang Audio & Video 6 04-14-2005 11:43 AM
fog lights charkelly9 Pre-2005 V6 Mustang 8 02-04-2005 08:02 AM
11:30 AM
