swap out help - Mustang Evolution
Old 01-24-2012, 10:55 AM   #1
mustangg2000's Avatar
Region: Arkansas
swap out help
I got a 2000 v6 stang was told k member is the same as fox body 302 k members and bolt up just fine.. I'm getting a 5.0 H.O to drop in it was also told it will bolt up to my T5 trans but ill have to use 5.0 engine bell houseing cause starter.. my question is electrial side do I get a harness conversion tip that will connect 5.0 computer to v6 interior electrical harness.. so my cluster gauges and interior lights etc. Will work or what??
mustangg2000 is offline   Reply With Quote
Old 01-24-2012, 11:41 AM   #2
Re: swap out help
I think the 5.0's ECU is not ODBII, its older tech not sure it can work easily, may have to replace the entire thing and get a new computer.
Your speedo is digital readout on the trans, you may have to swap over to a new cluster as well as the cable driven speedo system (new tailshaft on your T-5 trans)
I am also not sure on the K member, there is a chance but not sure on that.
Old 01-24-2012, 11:45 AM   #3
351mustanggt's Avatar
i would guess that the v6's have the same mounts as the v8's which would be the modular 4.6. so pretty sure the mounts wouldnt be the same since for a 4.6 to go into a fox you need different mounts
351mustanggt is offline   Reply With Quote
Old 01-24-2012, 02:33 PM   #4
97Stallion's Avatar
Re: swap out help
The EEC in the pre-96 mustang are EEC-IV, so yes they are different. The K-member in the 94-95 5.0 is the same as our 3.8/9s so it should bolt up just fine. I'm not sure about the speedo/trans issue since the trans is a whole seperate entity, so you might have to do some research on that, but just thinking about it, if you need a EEC-IV to run your car, you might need to swap out your tailshaft of your tranny for an older one and go the old school way with a speedo drive and driven gear. Might be easier to just swap the whole tranny IMO since you would need a mechanic to drill a hole in your tail shaft to hold your speedo drive gear in place.
Living one day at a time!
Old 01-24-2012, 02:46 PM   #5
Region: Arkansas
Well thanks guys I did know computers was different but as far as types I didn't .. thinking I'm just gonna go carberated swap out intake have one wire start which is wat I was wanting to do in first place just a lot less a mess ... What yall think ... And the 94/95 5.0s is wat ill be getting
Old 01-24-2012, 03:59 PM   #6
Cool I wanted to do a motor swap but people kept telling me it's a waste of time and money
Blackedout is offline   Reply With Quote
Old 01-24-2012, 04:07 PM   #7
Region: Arkansas
If its wat you wanna do than no time or money will be wasted.. everything thing is possible.. and it will set your stang out
Old 01-24-2012, 07:20 PM   #8
I have a 2000 v6 mustang and it has 126,000 miles on it. So I'm planning on dropping a 2000 Gt motor in it. I have an automatic they had the same automatic transmission those years. What will I need to do this besides getting the gt rear end?
Old 01-24-2012, 08:00 PM   #9
Region: Arkansas
Well k memebers are different so starting there motor mounts.. front suspension not saying front suspension wouldn't work just easier to grab whole with k member ...wire harness.. computer.. possibly even the bell housing on that transmission on GT the radiators are different v6 it may work if u take it easy but more likely swap it to ... Unless u got the donor GT already be cheaper to redo a wrecked GT .. but if your up for the experience more power ... Great learning experience
Old 01-24-2012, 08:10 PM   #10
I wanna v8. Might save up.
Old 01-24-2012, 08:13 PM   #11
Region: Arkansas
And ill say this too you 6 has butt loads of potential.. in my other stang I has windstar intake cold air a cam and true duals with flowmasters and headers stage two clutch and a short shifter ate a few GTs
---------- Post added at 08:13 PM ---------- Previous post was at 08:11 PM ----------
Oh I feel u me to that's why I'm swapn my 6 for a 5.0
Old 01-24-2012, 08:16 PM   #12
I wish you all the luck bro. You seem to be a cool guy.
Old 01-24-2012, 08:19 PM   #13
Region: Arkansas
You to bub
My official 5.0 engine swap thread PureVenom 1979-1995 Mustang GT 35 10-06-2013 01:12 PM
V8 engine swap Venomouz831 Pre-2005 V6 Mustang 12 12-10-2011 08:32 PM
Engine swap 96 stang 1996-2004 Mustang GT 8 09-19-2011 07:56 AM
Pi engine swap Kurlywhiteboy 1996-2004 Mustang GT 0 08-14-2011 10:48 PM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 10:07 PM
02:33 AM
