Oil guage problem - Mustang Evolution
Old 01-24-2012, 02:58 PM   #1
Oil guage problem
Today at work I decided to turn my car on and i noticed the oil gauge went to it's normal position and then dropped went back up and dropped did this like 5 times and when it went down it stayed down for a while...
I had a new oil change, and no oil leaks so whenever I check the oil level there was always oil.
I called my mechanic and he said my motor is either about to blow up or it's an oil pressure valve or something...
Help???
Blackedout is offline   Reply With Quote
Old 01-24-2012, 03:05 PM   #2
97Stallion's Avatar
Re: Oil guage problem
I'm willing to bet you have a loose or chaffing wire coming from your oil sending unit. That's where I would look first.
Living one day at a time!
Old 01-24-2012, 03:21 PM   #3
How do I do that?
Old 01-25-2012, 06:57 AM   #4
97Stallion's Avatar
The sending unit is right behind the power steering pump/alternator bracket. You'll have to look there. I'll see if i can find a pic for you.
Old 01-25-2012, 07:22 AM   #5
Ok
Old 01-25-2012, 07:46 AM   #6
also just to put your mind at ease the oil pressure gauge since about mid 96 has not been anything more than an idiot light. It clicks on at anything more than about 6psi and just goes to the middle... its not a real gauge so no real worries. If you had oil pressure issues such that the gauge let you know it would already be to late.
Old 02-04-2012, 06:53 PM   #7
Now that oil gauge is sometimes just staying down. What the heck.
Old 02-04-2012, 07:42 PM   #8
97Stallion's Avatar
Here is a pic of the sending unit. Check this wire to see if its loose. It's under the alternator accessory bracket.
Old 02-04-2012, 07:46 PM   #9
If it's loose it's just able to go back to how it's suppose to be? And it's the black wire plugging into something right?
Old 02-04-2012, 07:55 PM   #10
Is that area suppose to be this dirty?
Old 02-04-2012, 10:33 PM   #11
97Stallion's Avatar
Nope clean that **** off and stick it back on.
Old 02-04-2012, 10:37 PM   #12
What could that stuff be?
Old 02-05-2012, 01:54 PM   #13
97Stallion's Avatar
Not sure, could just be grime and dirt mixed with some oil... Clean it off and see if it comes back right away.
Old 02-05-2012, 02:03 PM   #14
That's what I did. It's only around water pump and It could possibly be engine bright that just settled there idk
Old 02-05-2012, 02:15 PM   #15
97Stallion's Avatar
Did you clean off the sending unit and inside the connection terminal? Did it fix your problem?
Old 02-05-2012, 04:03 PM   #16
Yes for now and yes it was loose I must have loosen it when I was cleaning the engine....
Old 02-05-2012, 04:27 PM   #17
97Stallion's Avatar
Sweet glad to hear it. Damn I'm amazing!!!
Old 02-05-2012, 04:30 PM   #18
Well I remember what that stuff was... One time my engine over heated and a friend of mine took the thermostat off to cool it down and radiator fluid sprayed everywhere. That's what that stuff is.
---------- Post added at 05:30 PM ---------- Previous post was at 05:27 PM ----------
Lol yeah you are
Old 02-06-2012, 02:41 PM   #19
my 00 mustang also does that with the gauge ..
mustang00 is offline   Reply With Quote
Old 02-12-2012, 04:44 AM   #20
Just_John's Avatar
Region: South Dakota
Weird... today my car started doing the exact same thing... intermittent signal loss, it frequently drops to zero and jumps back up to normal.
I'm sure glad there was a recent thread with pics to help me fix this... too bad it's below zero outside now. Repairs will have to wait!
01 V6 5 spd
Windstar upper, shorty headers, high-flow catted X, American Thunder catback, SCT Tuner, ASP 25% UDP, FRPP T-Lok
Just_John is offline   Reply With Quote
Guage / Stepper motor problem fix Charles.young10 2005-2010 Mustang GT 0 01-05-2012 09:10 AM
Oil pressure issues Klinton 1979-1995 Mustang GT 6 09-11-2011 01:52 PM
Off Topic Question - Oil Weight illestdomer2005 Pre-2005 V6 Mustang 7 09-09-2011 09:26 AM
What oil should be used on my cam break in? wc3john 1979-1995 Mustang GT 6 08-14-2011 11:43 PM
88 fox oil leak 04TRV6 1979-1995 Mustang GT 4 07-05-2011 01:17 PM
09:48 PM
