Gloss black maf sensor - Mustang Evolution
Old 01-28-2012, 10:22 AM   #1
ID:	39318   Click image for larger version
ID:	39320   Click image for larger version
Blackedout is offline   Reply With Quote
Old 01-28-2012, 10:29 AM   #2
Now going paint
---------- Post added at 11:29 AM ---------- Previous post was at 11:24 AM ----------
Mega fail!!!! Don't use gloss. I'm going back and painting it flat black
Old 01-28-2012, 11:22 AM   #3
Flat Black worked
Old 01-28-2012, 11:24 AM   #4
Mass air flow blackedout
I went ahead and painted those windshield wipers too... Came out better than Maf sensor
Old 01-28-2012, 11:28 AM   #5
I recommend this flat black paint on small projects if you black things out... Never let me down just take your time and spray a mist left to right. Add three coats and your good
Old 01-28-2012, 11:30 AM   #6
You could use semi gloss too. Trojan recommended that one.
Old 01-28-2012, 12:01 PM   #7
Horseplay's Avatar
how do u remove the whipers ? i wana do that too
Low2v
Old 01-28-2012, 12:03 PM   #8
Alright pick up the wiper, there's a little Switch at the bottom where you pull. I'll show you
Old 01-28-2012, 12:11 PM   #9
This is the driver side wiper I'll show you on. There exactly the same way on both. No when you get the wiper off you'll see under the wiper look for the letter L or the letter R. This is so you don't swap the wipers around (driver L eft, passenger R ight)
Pull the wiper up
Pull this switch to remove wiper. When off you see it's basically a latch.
Use the krylon flat black spray paint for better looks. And spray lightly away like 6 inches away so your basically mist spray. That's how painters paint.
Old 01-28-2012, 12:13 PM   #10
And u can either leave the wiper blade on but cover it. Or you can take it off
---------- Post added at 01:13 PM ---------- Previous post was at 01:12 PM ----------
And u can either leave the wiper blade on but cover it. Or you can take it off.
Old 01-28-2012, 12:35 PM   #11
Horseplay's Avatar
cool thanks !!! u got sweet ideas bro thumbs up
Low2v
Old 01-28-2012, 12:40 PM   #12
Thanks. Use imagination
Old 01-28-2012, 12:43 PM   #13
Horseplay's Avatar
thats why i read ur posts lol
Low2v
Old 01-28-2012, 12:59 PM   #14
Well thanks. I like when some of my work is appreciated.
Old 01-28-2012, 02:54 PM   #15
Horseplay's Avatar
no prob bro! hey another ? i wana paint the cowl now that im painting the whipers. how do i remove this?
Low2v
Old 01-28-2012, 04:27 PM   #16
Re: Gloss black maf sensor
Looks good.
If you paint things exposed to the sun and rain I would use the semi-gloss Dupli-Color paint.
It will hold up much better outside in the elements and if you accidently hit it with wax when you are waxing it won't affect it as much as flat black.
You can actually wax it if you desire without any ill effects.
You can get Dupli-Color paints at almost any automotive parts store.
Old 01-28-2012, 04:39 PM   #17
Horseplay's Avatar
came out pretty good !!
Low2v
Old 01-28-2012, 04:40 PM   #18
Horseplay's Avatar
just needa paint the cowl real nice now
Low2v
Old 01-28-2012, 06:31 PM   #19
Looks real good. The crowl is easy to remove. There's a how to on this site.
---------- Post added at 07:31 PM ---------- Previous post was at 07:30 PM ----------
Originally Posted by Trojan Horse
Looks good.
I'll keep that in mine.
Old 01-28-2012, 07:17 PM   #20
Horseplay's Avatar
how do u remove those little screws from it ? then ones that u see when you open the hood. its like a super tight space. and when the screws are out, do i just pop it all out or will that break it
Low2v
Old 01-28-2012, 08:30 PM   #21
You need to find the part up in these threads on how to do it. I'll have an answer tomorrow. I did this before it's pretty straight forward, and as far as tight spaces- as you mechanical skills get better the easier it'll get.
---------- Post added at 09:21 PM ---------- Previous post was at 09:13 PM ----------
Check this out.
Painting Faded Mustang Cowl Pieces
---------- Post added at 09:25 PM ---------- Previous post was at 09:21 PM ----------
REMEMBER TO TAKE YOUR TIME DOING PROJECTS. THIS SHOULD BE A 4 hour job.
---------- Post added at 09:30 PM ---------- Previous post was at 09:25 PM ----------
Does this help? If not I might do mine tomorrow so I can show you step by step.
Old 01-28-2012, 10:47 PM   #22
Horseplay's Avatar
Check this out.
it sounds like its gona be a pain !!!and it would be kool for u to do a step by step but i wouldnt want u to go through the hassle again of removing it.
Low2v
Old 01-28-2012, 11:02 PM   #23
I'll see what I can do. It'll take a while but it's what I'll do tomorrow.
---------- Post added 01-29-2012 at 12:02 AM ---------- Previous post was 01-28-2012 at 11:59 PM ----------
I'm wondering should I use flat black or satin like they say. Or semi gloss I'll try flat black. Satin is the color the plastic already is. Flat black will seem a lot better just watch when you wax.
Old 01-28-2012, 11:08 PM   #24
Horseplay's Avatar
how do you prep it before you paint the cowl
Low2v
Old 01-28-2012, 11:10 PM   #25
Better use satin they really recommend it. Since it bonds to plastic better. I'm going to do this another day. It will be easy tho you just have to follow the instructions. To me it's common sense because I did it before but to a first timer it's always confusing. Just take your time. I don't wanna do bc I super glued the wiper hoses to the sprayers connected to the crowl itself. I wish I could show you. Try to you tube it?
Old 01-28-2012, 11:10 PM   #26
Flat paints are porous, thus they don't wear well outside.
The semi-gloss is very similar to the satin.
You know, I wonder what one of those headlight polishing kits will do on the cowl?
They are plastic too and you wouldn't be depending upon trying to get paint to stick to it.
Old 01-28-2012, 11:33 PM   #27
Horseplay's Avatar
yeah ill see what i can do bro no worries thanks for the advice !
Low2v
Old 01-29-2012, 09:11 AM   #28
Alright think I'm going to try it.
Old 01-29-2012, 10:01 AM   #29
Im going to make u a visual on how to take the crowl off...
Old 01-29-2012, 10:03 AM   #30
Horseplay's Avatar
sweet !!!
Low2v
Old 01-29-2012, 10:14 AM   #31
Start by taking this rubber thing off. It's easy on easy off basically an attachable seal to keep water out the engine
Next take these pins out. There's three all together. If you damage them it's no big- you can find them at any auto store I already have a pack I'll show you the pack when I'm done so you'll know what to look for
alright I'm doing this as I go....
Old 01-29-2012, 10:25 AM   #32
Alright after that close the hood... Then take the windshield wipers off.
Alright get a flat head screw driver and start prying. BE EASY WITH DOING THIS!!! I EMPHASIZE THIS BE VERY EASY!!! If you feel as if it isn't working with you take a break calm down and try again remember this is a four hour job! Don't risk cracking the crowl they're quite expensive. However you can find them on American muscle if you accidentally break it.
Then when you have it loose lift with your hand "carefully" be patient
Old 01-29-2012, 10:34 AM   #33
Alright here we go. Now that its loose now we must locate the wiper lines for your sprayers, disconnect these obviously there's two, drivers side and passenger.
Passenger
Drivers side, see the wiper pump? Alright go ahead and disconnect those
Here's the upper crowl it's completely off.
Wash the crowl with soap and water then clean with alcohol.
I might think about painting my lower crowl to. You see this part in the engine bay.
Old 01-29-2012, 10:48 AM   #34
Ok now while my upper crowl is drying I'm going to take my lower crowl off... And paint it as well....
Old 01-29-2012, 11:05 AM   #35
Alright lower crowl...
Unscrew all these screws in the lower crowl
Use a 7mm
Injectors not pulsing? Otlaw80 1979-1995 Mustang GT 21 07-27-2014 03:12 PM
Maf sensor Blackedout Pre-2005 V6 Mustang 7 01-27-2012 08:15 PM
Matte black or gloss black? Srohda 2011-2014 Mustang GT 17 10-28-2011 08:38 AM
Red or Black? cruisin99coupe Mustang Paint, Appearance & Detailing 18 09-30-2011 01:17 AM
MAF sensor Mustanglife Pre-2005 V6 Mustang 5 07-01-2011 07:22 AM
01:13 PM
