next mod? - Mustang Evolution
Old 01-29-2012, 07:35 AM   #1
kickerofdoom's Avatar
next mod?
Does anyone have a driveshaft? Also how hard is it to install a cam? Where can i get racing seats belts?
Old 01-29-2012, 02:15 PM   #2
Matney10's Avatar
Unless your pretty experienced with engines I would suggest not installing a cam on your own. But like 4 point harness can be bought from pretty much anywhere online. I'd look on amazon or eBay first.
Matney10 is offline   Reply With Quote
Old 01-29-2012, 06:08 PM   #3
Aluminum drive shaft you mean?
Blackedout is offline   Reply With Quote
Old 01-29-2012, 09:12 PM   #4
Yes I was looking to get one since I have all bolt on and I know a cam isn't easy but worth a try.
Old 01-29-2012, 09:32 PM   #5
Funny I always see you giving me advice.. Research the cam. Learn all about it. And if you don't wanna do it yourself find a mechanic you can trust.
They sell aluminum driveshafts from American muscle after an few basic mods under the hood I'm getting one
---------- Post added at 10:32 PM ---------- Previous post was at 10:29 PM ----------
Dude anything is possible. I'm turboing my v6. But I have a lot of modding to do to get there in the end its worth it. I'll be very fast. And only driving a sixer.
Old 01-29-2012, 09:33 PM   #6
I mean I have had my car for 3 years and i have installed all my own parts so I can offer what works and what difference It's makes. I wanna make 200 HP at wheels so i know with a cam I should have it. Unless I get tons of money I'm done modding I had fun and learned a lot
Old 01-29-2012, 09:44 PM   #7
Modding never ends sounds like someone giving you crap like they did me. They keep saying it ain't worth the money, u can make your car beat 200 hp. Turbo it
---------- Post added at 10:44 PM ---------- Previous post was at 10:44 PM ----------
You can make your car have as much or more power than the newer sixers
Old 01-30-2012, 07:00 AM   #8
Turbo with parts and everything is at least 3000-4000 and it would be cool but at that point I might as well look into another car. Mine is a auto and takes off are ok. When i get out of college I will look into getting a new car. I'm happy with what I got and learned so far. Plus when the engine goes down I will look into dropping a 4.2 engine or adding a gt one
Old 01-30-2012, 08:44 AM   #9
mustangg2000's Avatar
Region: Arkansas
Turbo kits are high but just know you can get turbo off anything and make it work ... Piece it together parts here and there that you know are good.. me I didn't buy a kit .. I got my turbo off a 2.3 turbo coupe its not a big turbo only boost at a max of 15 but I have it dialed at 6 don't wanna mess up anything.. got my intercooler off a neon SRT.. and my piping off it and a cobalt SS SC .. everything works perfectly and only in my whole system bout 500 bucks
mustangg2000 is offline   Reply With Quote
Old 01-30-2012, 08:54 AM   #10
Wow really. You have a video and what are your numbers. I would love to set one up.
Old 01-30-2012, 09:50 AM   #11
Mu5t4ng's Avatar
Region: West Virgina
I have a 1995 v6 that was manufactured in feb of 95 so it has the obdII port and reads and clears check engine light when scanner hooked up. Does this mean I can use a 96-98 sct sf3 tuner from American muscle? I really want a tuner cuz I tried the chip and ruined my cars computer connection trying to make it work so it's either tuner or new computer then chip
Mu5t4ng is offline   Reply With Quote
Old 01-30-2012, 10:05 AM   #12
Region: Arkansas
Honestly that's weird before 96 those ports wasn't installed so if u have it means yours a split year ride early production on the next year programmer should work
Old 01-30-2012, 10:07 AM   #13
deadsp0t's Avatar
Pretty sure the 95 V6's came with ODBII
That's unimpressive
Old 01-30-2012, 10:12 AM   #14
Mu5t4ng's Avatar
The port under the steering column to the right, that's it right? I've heard that there was early versions of obd2 would that be my case? Like the only difference was ignition system or something, that should interfere with the tuner and computer right?
Old 01-30-2012, 10:32 AM   #15
Region: Arkansas
It should just be a obd obd 2 didn't get put in till 96
---------- Post added at 11:32 AM ---------- Previous post was at 11:27 AM ----------
And like I said they split yeared you could have the obd 2 .. some even 94 could have it but mostly didn't start put the obd 2 in till 96
Old 01-30-2012, 10:32 AM   #16
Mu5t4ng's Avatar
So if it was just obd1 would it be able to be read by a scanner for engine codes? Because my car was read with a scanner at autozone when my o2 sensor went bad
Old 01-30-2012, 10:52 AM   #17
Region: Arkansas
Check this out tells you in detail how they are different and how there the same ..
http://www.auto-facts.org/OBD-2.html
Best exterior mod? MarshallYoung 2005-2010 V6 Mustang 19 02-02-2012 04:31 AM
2011 5.0 Next Mod Suggestions? doug5.0 2011-2014 Mustang GT 7 01-11-2012 07:28 PM
T-56 anti venom mod 03turbo cobra SVT Mustang 4 12-13-2011 12:51 PM
Check out this Mustang's MOD motor! Trojan Horse Pictures and Videos 5 10-29-2011 11:39 AM
First Mod Suggestions? illestdomer2005 2011-2014 V6 Mustang 34 07-19-2011 05:17 AM
09:02 PM
