Cultch pedal slack - Mustang Evolution
Old 01-29-2012, 10:35 AM   #1
Matney10's Avatar
Cultch pedal slack
I was wondering how much slack is in the clutch pedal in your guys cars. Mine has about a inch and a half to two inches of play before it starts pushing the clutch in. It has a brand new clutch so that's not the problem and I know it has a auto tensioner cable on it. Is there anyway I can make it have less slack before it starts to engage the clutch. Thanks
Matney10 is offline   Reply With Quote
Old 01-29-2012, 12:23 PM   #2
Cobrarunnin9s's Avatar
Re: Cultch pedal slack
Have you tried to adjust it, if it's like my car you just out your foot underneath the clutch pedal and pull it up towards the dash and it should click or something. Just depress the clutch after that and it's adjusted.
Cobrarunnin9s is offline   Reply With Quote
Old 01-29-2012, 02:02 PM   #3
Matney10's Avatar
Yea I pulled it up as far as it would go then pressed it back down but it dosnt pop or get tighter. Does your pedal have much room before it starts to engage the clutch? I think my best rout might be a adjustable cable and quadrant.
Old 01-29-2012, 02:13 PM   #4
I bought a zoom cable and quadrant and a BBK firewall adjuster, before that I only had like maybe an inch of play of that, now I have none in the pedal.
Old 01-29-2012, 02:19 PM   #5
Matney10's Avatar
That's prolly what I'm gonna do. Where did you order yours? I got my clutch from summit. I guess I'll look into AM tho for that stuff cause they prolly got it cheapest.
Old 01-29-2012, 05:32 PM   #6
The adjuster I got from summit and the cable/quadrant they had at advanced auto parts in stock. I didn't have time to wait I needed the cable because mine broke almost completely in half so I had to replace right away.
Old 01-29-2012, 05:54 PM   #7
willrad00's Avatar
I dont mind the slack as much as just how deep my clutch is. I learned on a car with a very short clutch and my mustang's can annoy the crap out of me
willrad00 is offline   Reply With Quote
Old 01-29-2012, 05:57 PM   #8
Stag's Avatar
Did you get some air in the lines?
Stag is offline   Reply With Quote
Old 01-31-2012, 02:07 PM   #9
97Stallion's Avatar
to tighten your clutch up you need to press your clutch in first, then while still holding the clutch pedal down grab and hold the quadrant (right above the gas pedal), then pull up on the pedal. you'll hear it click then. I use 2 clicks on mine. if you go too far, let go of the pedal and quadrant and then pull up on the pedal again not holding the quadrant this time to let the tension off, then repeat as desired.
Living one day at a time!
Old 01-31-2012, 02:09 PM   #10
Matney10's Avatar
I'll try that when I get out to the car after work. Thanks man.
Old 01-31-2012, 02:10 PM   #11
97Stallion's Avatar
there is no try, only do and do not!
Old 01-31-2012, 02:12 PM   #12
Matney10's Avatar
LOL... True.. Hopefully its a DO.
Old 01-31-2012, 04:47 PM   #13
97Stallion's Avatar
And how did it work?
Old 01-31-2012, 09:58 PM   #14
Matney10's Avatar
It worked very well. But I think my cable is way stretched cause it's Macedonia out and still has slack. It's never been replaced I don't think so I'm gonna go ahead and at least replace it with a factory one. That's a great tip tho man. Thanks for the help.
Old 01-31-2012, 10:13 PM   #15
saxxx's Avatar
Does that work on all models because I have a 2007 v6 with a similar problem
saxxx is offline   Reply With Quote
Old 02-01-2012, 07:55 AM   #16
Matney10's Avatar
I'm pretty sure in a 07 it has a hydraulic clutch. I don't think there's anyway to adjust it except for bleeding some air out of the lines.
Old 02-01-2012, 01:56 PM   #17
97Stallion's Avatar
Well I'm glad it worked for you, and it's not a fix all, i still have my original clutch cable, but i have a spare cable and quadrant just in case it breaks.
Old 02-02-2012, 09:32 AM   #18
mustangg2000's Avatar
Region: Arkansas
There is also a clutch cable adjustment down on the linkage on the transmission its self covered by a lil plate
---------- Post added at 10:32 AM ---------- Previous post was at 10:31 AM ----------
My clutch engages soon as you hit the clutch peddel
mustangg2000 is offline   Reply With Quote
Old 02-02-2012, 11:41 AM   #19
Matney10's Avatar
Ok. I'll look into that. Like I said mine has about a inch of play before it starts to engage the clutch and it annoys me. Lol. Thanks man
gas pedal austinknoll General Mustang Discussion 7 01-26-2012 11:59 PM
Gas Pedal Got Stuck illestdomer2005 2011-2014 V6 Mustang 13 01-17-2012 09:14 AM
Clutch pedal assembly robert81717 1979-1995 Mustang GT 2 12-29-2011 01:16 PM
If u have air in the break fluid can that make ur clutch pedal feel stiff? bluestorm52 2005-2010 Mustang GT 7 12-10-2011 04:49 PM
Pedal removal 90mustangLX 1979-1995 Mustang GT 3 11-26-2011 07:45 PM
08:06 PM
