Question.... - Mustang Evolution
Old 01-31-2012, 09:29 PM   #1
Question....
Racing on the drag strip is it safe to manually shift my automatic transmission for my 2000 v6 mustang?
Blackedout is offline   Reply With Quote
Old 01-31-2012, 09:40 PM   #2
Eturner's Avatar
Yes but why?.. Your car will shift itself just fine on it's own!.. You more than likely will be slowing it down manually shifting it!...
Old 01-31-2012, 09:42 PM   #3
Alright
---------- Post added at 10:42 PM ---------- Previous post was at 10:41 PM ----------
Bc a friend showed me and it seems a lot faster
Old 01-31-2012, 09:52 PM   #4
Eturner's Avatar
Ya I've tried it in my car and it was slower!.. But I've also got a tuner for it to!..
Old 01-31-2012, 10:00 PM   #5
I got a tuner also.
Old 01-31-2012, 10:10 PM   #6
Eturner's Avatar
Originally Posted by Blackedout
I got a tuner also.
I would leave it with that!...
Old 01-31-2012, 10:12 PM   #7
Tuner shifts me at 30 mph, 50, 85 and 110 when I just punch the gas
Old 01-31-2012, 10:20 PM   #8
Eturner's Avatar
Depending on what type of tuner you have you might be able to play with the shift points and pressure a bit!.. But I wouldn't suggest doing it too much!.. And only do so in small increments!..
Old 02-01-2012, 01:00 AM   #9
irishn8's Avatar
I wouldn't change shift points. There are people who make a living deciding what points your tranni should shift based on what rpms your engine makes the most power. Unless you have moded your car and you know what you are doing. Shift pressures can be adjusted a little but. The factory setting makes your car more comfortable due to the slower shifts. A sport tune normally stiffens up the shift pressures for you so I wouldn't go much firmer without modding your tranni's valve body to allow faster fluid flow.
Old 02-01-2012, 01:18 AM   #10
deadsp0t's Avatar
I would contact whoever the tunes came from, express your concerns then inquire about an update. You have to remember all cars are different and react differently especially when talking about a canned tune v. a CDT. My point is it May need a little tweaking to get the car exactly where you want it, but unless your experienced leave the tweaking to the pro's.
That's unimpressive
New car, hand brake question prw302 2011-2014 Mustang GT 5 01-28-2012 12:38 AM
Exhaust question Codysmustang 1996-2004 Mustang GT 14 11-21-2011 09:11 PM
Kenne bell 2.6L question Ahmed ali khan 1996-2004 Mustang GT 4 11-14-2011 12:54 PM
Kenne bell question!! Need help Ahmed ali khan 1996-2004 Mustang GT 26 08-11-2011 04:24 PM
1998 v6 exhaust question?? Gt.Vert Pre-2005 V6 Mustang 6 07-23-2011 12:29 AM
05:55 AM
