'99 Window Leak? - Mustang Evolution
Old 02-02-2012, 05:05 PM   #1
'99 Window Leak?
Hey guys, I need a bit of your advice/knowledge.
My '99 Mustang (Coupe) seems to have a leak on the little rear passenger side window (the proper name escapes me at the moment).
It's been raining heavy for a few days (no sort of garage or cover) and when I got in my car to head to work, I noticed some water running down the plastic trim by the rear passenger seat, under the little back window. It was only on the side trim, and I could see water where the lower trim meets the side/upper trim. This made me concerned, because I've seen water once before in the same spot, after washing my car once.
Any ideas to what's up? The exterior of the window looks like all the seals are fine.
Smiley is offline   Reply With Quote
Old 02-02-2012, 05:16 PM   #2
It's not me, it's you.
primer2tone's Avatar
Humm? Maybe it's not the quarter window? Have you checked the seal at the top of the rear window? It might be leaking there and running down on the inside. You might have to remove the interior panels to see where it's coming from.
Old 02-02-2012, 05:22 PM   #3
2Greeny7's Avatar
Send a message via Skype™ to 2Greeny7
Unskrew your seat belt on that side and you can take out the pannel by the window. Check out the window there and if theres nothing apparent there then sit inside your car and check the molding all the way around your door. Tell me how it goes!
2001 V6
CAI, SF3/X3 Tuner, 4.10 Gears, Auburn lim-slip
GT4 Rims (Summer), Stock Rims (Winter)
2 Subs, New speakers all around
1 Great Car 1 Happy Kid
July '12 Mustang of the Month
2Greeny7 is offline   Reply With Quote
Old 02-02-2012, 06:49 PM   #4
Re: '99 Window Leak?
Hm. I'll go ahead and see about pulling the trim off when I get the chance. Run a water hose over it and see if I can spot where the water's coming from. If I find something I'll take pictures and give an update. Didn't know if this was a possibly common problem.
Old 02-02-2012, 07:53 PM   #5
2Greeny7's Avatar
Sometimes the window wasnt put in right or the stuff around the window gets holes and such, plus out side of the car water can sit there and pool in heavy rain. Let us know what you see and if u need help
2001 V6
Help window tint messing up 98projectpony General Mustang Discussion 2 12-20-2011 04:11 AM
Window Tinting crkmonzo 1979-1995 Mustang GT 8 09-11-2011 03:34 PM
88 fox oil leak 04TRV6 1979-1995 Mustang GT 4 07-05-2011 01:17 PM
questions for a 98 - Driver Seat motor, Headlights, and window motor StreetJMusic Pre-2005 V6 Mustang 10 06-27-2011 03:39 PM
05:10 PM
