rear end bad? - Mustang Evolution
Old 02-03-2012, 02:46 AM   #1
Horseplay's Avatar
rear end bad?
how will i know i need a new rear end already ? will it make noises ? what are the symptoms ?
Low2v
Old 02-03-2012, 08:18 AM   #2
mustangg2000's Avatar
Region: Arkansas
It make a popin noise when your in the gas or a howling sound when letting off slowing down and creeping make a grind pop it be hesitant..
---------- Post added at 09:18 AM ---------- Previous post was at 09:07 AM ----------
And worse cases your hear gear teeth breaking or metal on metal slipping where its messing the tips of the teeth up ... Ull need to pop off the rear-end housing cover make sure there no metal in your gear oil if no metal fill back up with a thinker gear oil see if that helps the noises if not then its upgrade time
mustangg2000 is offline   Reply With Quote
Old 02-03-2012, 11:26 AM   #3
Horseplay's Avatar
thanks dude i gota check that out. its been making poping sounds here and there especially on bumps and stuff. i chaged the shocks and struts so its not that. i also know my fuel door doesnt close properly because its dented inside the fuel door so that dent wont let it lock right. so idk if it can be the door bouncing around hitting the car wen im driving
Low2v
Old 02-03-2012, 11:47 AM   #4
Matney10's Avatar
Does it only pop on bumps and when ur completely stopping? If so then it's prolly a control arm bushing.
Matney10 is offline   Reply With Quote
Old 02-03-2012, 11:50 AM   #5
Region: Arkansas
No problem ...u joints when bad make a clinkin noise as well ur rear one on drive shaft could be clinkin around the tips hold the greased bearings could have lost all the bearings out it and its moving around ...
Old 02-03-2012, 12:09 PM   #6
Horseplay's Avatar
well i know for a fact that the front left bushing is ripped..an i also need a new rack&pinion so can this be the reason ?
Low2v
Old 02-03-2012, 12:13 PM   #7
Region: Arkansas
Well if it only happens on bumps wouldn't be your rear end and if you got new shocks .. could possibly be bad bushings
Old 02-03-2012, 12:18 PM   #8
irishn8's Avatar
Kinda along the same lines; mine kinda whines and grinds around sharp corners when warmed up. What exactly is that? I've never gotten to open it up.
Old 02-03-2012, 01:05 PM   #9
Matney10's Avatar
Re: rear end bad?
Mine did the same thing and it was a upper control bushing. Id check into that first. They kinda suck to change but they are pretty cheap so its a good place to start.
Old 02-03-2012, 01:26 PM   #10
Horseplay's Avatar
thanks. ill check into it. can a rack&pinion from a gt fit in my six ? i saw one for sale on ebay from a gt
Low2v
Old 02-03-2012, 02:12 PM   #11
Matney10's Avatar
I'm pretty sure it will fit but I'm not positive.
Gt rear end Blackedout Pre-2005 V6 Mustang 11 01-19-2012 04:41 PM
Rear End Swap Sycopath80 2005-2010 V6 Mustang 3 12-30-2011 11:25 AM
rear end G4be 1996-2004 Mustang GT 6 10-28-2011 07:32 AM
95 8.8 5Lug Rear End into 87 5.0 Fox mcdonaldnick 1979-1995 Mustang GT 2 10-12-2011 06:03 PM
Rear end swap bmabbott Pre-2005 V6 Mustang 9 10-01-2011 12:14 AM
06:01 AM
