Project motor - Mustang Evolution
Old 02-05-2012, 04:41 PM   #1
Project motor
I wanna build a powerful v6 motor. It's going to have a turbo on it and possible 50 shot nitrous fogger system.
I found this...
http://www.powertrainproducts.net/Pr...oductCode=1811
And build it with this package
http://www.supersixmotorsports.com/p...1PowerPaks.pdf
Heres the turbo
http://www.tmaturbo.com/streetstripkit.html
What y'all think? The reason I'm doing this is bc I wanna have this car the rest of my life and enjoy it. And i made up my mind this is what I wanna do
Blackedout is offline   Reply With Quote
Old 02-05-2012, 04:55 PM   #2
kickerofdoom's Avatar
Well look into a gt fuel pump and bigger injector
Old 02-05-2012, 06:14 PM   #3
Alright 39 lb fuel injectors?
---------- Post added at 07:14 PM ---------- Previous post was at 06:54 PM ----------
Ok since I'm building this a part at a time. Could I have the 39 lbs and the gt fuel pump running on my v6 motor ?
Old 02-05-2012, 06:28 PM   #4
You can add the fuel pump for now but you can't change the injector. But the size depends on the boast
Old 02-05-2012, 06:37 PM   #5
Oh thanks. What about modding to a Gt feul tank? Is there more fuel?
Old 02-05-2012, 06:41 PM   #6
I think they would but you still need a bigger one for turbo. Remember supporting mods you cant go cheap
Old 02-05-2012, 08:25 PM   #7
I'm going to start from rebuilding the motor and using the h/c/I from supersixmotorsports
---------- Post added at 09:25 PM ---------- Previous post was at 09:23 PM ----------
Got a brand new transmission so might as well remake the motor or buy a low mileage one and build it
Old 02-08-2012, 01:37 AM   #8
davidcseifert's Avatar
Region: Arkansas
Re: Project motor
i see fail everywhere....
gt fuel pump useless.... same as the V6 one
the SVT focus 255lph pump is a direct drop in and can handle a decent hp load
the gas tanks are also the same -_-
what boost are we talking here? hopefully not more than 10-11psi considering you showed a factory bottom end..
SSM while they make great stuff is overpriced... i only have it thanks to someone's screw up...
you have money in hand for this or what? or do we have to wait 5 years to see some results LOL
edit: wow in one day swapping to a V8 lmfao (other thread of yours)
blower/new cam soon
Old 02-08-2012, 05:11 AM   #9
It's from people telling me what I should do. I would just go rebuild what I got now. Then buy another mustang. Too much trouble engine swapping. No money issues. Most likely going to keep what I have and make it better.
Old 02-08-2012, 08:02 AM   #10
mustangg2000's Avatar
Region: Arkansas
Turbos are awesome superchargers are better in My opinion.. turbos produce lots of heat .. more heat less horsepower... They heat soak everything in engine compartment.. superchargers don't less heat more horsepower.. and you can get the lil superchargers that attach on a bracket instead changing whole intake if you or someone already or wanted to up grade to the windstar upper intake ...
mustangg2000 is offline   Reply With Quote
Old 02-08-2012, 01:07 PM   #11
Region: Iowa
Re: Project motor
While a turbocharger will generate more heat under the hood, I have never seen a supercharged application make more horsepower per pound of boost than a matched turbo setup. The setups that produce more under hood heat are prob cheap home made setups that aren't ceramic coated, or heat wrapped.
Turbo's are generally better.
Gokui is offline   Reply With Quote
Old 02-08-2012, 01:33 PM   #12
Region: Arkansas
Which goes to show its an opinion matter..
Old 02-08-2012, 01:43 PM   #13
Region: Iowa
Re: Project motor
From a "what makes more horsepower" standpoint its not turbo wins, from a "what do I want to put on my car" is all opinion, same with "whats better" thats an opinion also.
Old 02-08-2012, 04:54 PM   #14
Re: Project motor
race ported m112 on meth... gobs of torque...
The Green Six is offline   Reply With Quote
Old 02-10-2012, 03:44 PM   #15
If tomorrow goes fine I'll have a 1999 svt cobra motor. It needs to be rebuilt, and has 140k miles on it. The guy selling it to me is giving me a friendly price of 600$
This will be a great project because my girlfriends job does machine work it's a family business and her dad said he will bore it and all for a case of beer. Not a bad deal. The motor has it all even the wire harnesses. Going pick it up tomorrow. Then getting the tremec t45 later the transy I'm looking at it rebuilt for 1,020$. Then 8.8 rear end and feul pump. Radiator and cooling system and computer. And done.
Old 02-10-2012, 06:18 PM   #16
DaBluedude's Avatar
Do a forged stroker kit on it. Bad *** results. Also. Port the heads and intake manifold while your at it. The 4v is sweet.
2003 Mach 1
Old 02-10-2012, 06:45 PM   #17
Ok so I did all my research now i need to know what I can do to modify my car for the tremec t 45 transmission... Any help?
Old 02-10-2012, 11:17 PM   #18
DaBluedude's Avatar
I know the swaps been done many times. Sure the.writeup is on here somewhere. You should also look into swapping to the cobra brakes too.
2003 Mach 1
Old 02-12-2012, 07:10 PM   #19
Region: Iowa
Re: Project motor
Attachment 40415
Attachment 40416
650$ what needs to be done? Does it need new pistons/rods or just new bearings you may want to check on that before you jump into a 1500$ engine build, plus you need a wiring harness, motor mounts, but I'm sure you know all that.
Old 02-12-2012, 07:19 PM   #20
Guy changed his mind at the last minute. So... Leaves me right back to saving up for a v8. Good news tho... I KNOW STANDARD! so that's what I'll look for. A standard 99-04 mustang gt. So awesome.
---------- Post added at 08:19 PM ---------- Previous post was at 08:17 PM ----------
My friends been teaching me standard and they've been very supportive and so has my dad. I think he will buy me another mustang, a v8 this time, if this v6 dies off. That or I'll have my opportunity to buy my v8 myself. But itll definatly be standard.
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
1971 Mustang Fastback Project yellow99 Classic Mustangs 0 09-03-2011 05:49 PM
questions for a 98 - Driver Seat motor, Headlights, and window motor StreetJMusic Pre-2005 V6 Mustang 10 06-27-2011 03:39 PM
02:12 PM
