computer reset - Mustang Evolution
Old 02-12-2012, 11:39 AM   #1
98mustang11's Avatar
computer reset
If you unhook negative cable it resets the computer on the cat right ??
98mustang11 is offline   Reply With Quote
Old 02-12-2012, 11:45 AM   #2
Cobrarunnin9s's Avatar
Re: computer reset
Unhook both cables and tap them together a couple times and that will reset the PCM.
Cobrarunnin9s is offline   Reply With Quote
Old 02-12-2012, 09:41 PM   #3
Re: computer reset
why do you want to reset it? if it's due to emissions get ready for the kicker....they are able to tell if you reset your computer doing the battery trick.
Anonymous is offline   Reply With Quote
Old 02-12-2012, 10:57 PM   #4
My bad meant computer and I heard it would re learn the way you drive
Old 02-12-2012, 11:02 PM   #5
Re: computer reset
It does reset everything and relearn to. as long as all the readiness monitors pass, it's all good. Your allowed to have a couple not ready and you will still pass emissions. I just recently passed emissions on my cobra with no cats and just MIL eliminators in place.
Old 02-12-2012, 11:29 PM   #6
Re: computer reset
mil eliminators kill the code...so i don't see how you'd have any issue passing...however pulling the battery is a different thing...i've failed a few times because of having to pull the battery out for one reason or another a day or two before emission testing...now if he does a full drive cycle before testing (if that's even what this is about) then it won't read the battery has been removed
Old 02-18-2012, 10:00 AM   #7
Touching the cables together not fry something
Old 02-18-2012, 04:52 PM   #8
Ok so the cables Wong reach
Old 02-18-2012, 06:22 PM   #9
Re: computer reset
Cant you just pull all the harness out the e.c.u doesnt that reset it???
l2plagears is offline   Reply With Quote
Old 02-19-2012, 09:08 AM   #10
Blogger
99ford's Avatar
I'd clear the computer using a scanner. They aren't much. I did that to mine drove 100+ miles no issues.
Engine control computer/ module Matt5.0 1979-1995 Mustang GT 7 02-06-2012 10:30 PM
How long does it take to reset the on-board computer? Scrshaw General Mustang Discussion 4 01-01-2012 12:42 PM
Tablet PC question for the Computer Pros M3to5.0 The Bar 4 11-28-2011 08:36 PM
Flashed Computer mcdonaldnick 1979-1995 Mustang GT 5 10-29-2011 12:14 AM
Building a computer tower... input needed jimmy_beaner The Bar 52 09-06-2011 09:48 PM
04:54 PM
