help needed - Mustang Evolution
Old 02-14-2012, 09:26 AM   #1
newboy95's Avatar
help needed
I have a 95 3.8l mustang with either a blown head gasket or cracked piston. I believe piston bc there is oil mixed with gas on the spark plugs. I found a romeo 4.6l brand new only ran for ten minutes extremely cheap. Can anyone tell me what I will need to know to do this swap? I have the stock aode tranny. Will that bolt up or no? Really need info. Main mode of transportation now is a 92 f350 with 460... can't afford the gas. Any help is needed. Thanks.
newboy95 is offline   Reply With Quote
Old 02-14-2012, 09:58 AM   #2
mustangg2000's Avatar
Region: Arkansas
Those years is bad about head gaskets blowing.. and 4.6 wire harness.. k member with engine mounts ..computer .. not sure on trans if it does Ull still have to change bellhouse ..
mustangg2000 is offline   Reply With Quote
Old 02-14-2012, 10:02 AM   #3
newboy95's Avatar
I found out about the head gasket problems after the car broke down.. any idea on how much that would run? I'm nineteen and lack experience with fords. Everything that needs done I have to do.
Old 02-14-2012, 10:24 AM   #4
Region: Arkansas
It's do able for anyone not a easy task but ain't hella hard.. Ull need head gasket kit and new head bolts.. while u got it apart might as well change both head gaskets what id do .. First thing take a lot of pictures .. remove your engine accessories (alt.. ac compressor.. air intake.. etc..) there brackets take valve covers and upper intake off and your to them ... Document parts places so u don't lose nothing and know where to put it back
---------- Post added at 11:24 AM ---------- Previous post was at 11:20 AM ----------
There are YouTube vids on the how to get a good manual from ur local parts store chilton repair manuals are always good to keep handy
Old 02-14-2012, 10:24 AM   #5
newboy95's Avatar
Okay thanks. Big help. Still getting the engine anyway but I will try that first. Then I will update. Thanks again.
Old 02-14-2012, 10:27 AM   #6
Region: Arkansas
Yeah I'd get the 4.6 if its a hella deal but that my friend is a hella task but search this site there is info on the swap
Old 02-14-2012, 10:45 AM   #7
newboy95's Avatar
Thanks man. And hellatious deal. Brand new, no miles, romeo 4.6 for 500 bucks.
Old 02-14-2012, 03:08 PM   #8
Region: Arkansas
Dude that's my friend is the most wicked deal right on
Coolant through TB needed? Otlaw80 1979-1995 Mustang GT 3 02-01-2012 09:43 PM
1987 Mustang GT 5.0: Huge Help Needed Johnson 1979-1995 Mustang GT 24 01-18-2012 08:19 PM
suspension work needed geo Pre-2005 V6 Mustang 11 10-07-2011 05:15 PM
Building a computer tower... input needed jimmy_beaner The Bar 52 09-06-2011 09:48 PM
Help needed t0t4lbl4ck0ut 1996-2004 Mustang GT 8 07-01-2011 03:23 PM
09:20 PM
