When i brake... - Mustang Evolution
Old 02-16-2012, 01:30 AM   #1
Timm04's Avatar
When i brake...
It pulls to the right and I have to turn the wheel to the left just to keep going straight and then if I let off the brakes completely it's shoots over to the left it only pulls when I'm braking? Do I need my front end aligned?
Timm04 is offline   Reply With Quote
Old 02-16-2012, 02:35 AM   #2
Re: When i brake...
Sounds like you need to rebuild or replace your front brake calipers.
Old 02-16-2012, 07:41 AM   #3
Re: When i brake...
Sounds like a tie rod issue.
l2plagears is offline   Reply With Quote
Old 02-16-2012, 08:26 AM   #4
irishn8's Avatar
How?
Old 02-16-2012, 08:42 AM   #5
Re: When i brake...
nevermind i read the post the wrong
Old 02-16-2012, 09:13 AM   #6
mustangg2000's Avatar
Region: Arkansas
Could have something in your brake line not letting the fluid pressure squeeze your other side front it pulls that one side hard cause it grips first or only .. check lines as well caliber
mustangg2000 is offline   Reply With Quote
Old 02-16-2012, 11:49 AM   #7
Timm04's Avatar
Thanks guys I'll check it out it's really killin me on what it is
Old 02-16-2012, 12:28 PM   #8
irishn8's Avatar
I would try bleeding the brakes first thing.
Old 02-16-2012, 12:33 PM   #9
Camo1967Mustang's Avatar
Re: When i brake...
Definitely sounds like the left caliper is bad
Adrian
2001 Mustang
--AM CAI, BBK Headers, Dual exhaust, Billet grille, hood and side scoops, Sequential tail lights,
AM Headlight covers, Fog lights, Chin spoiler, H&R Lowering Springs, KYB Shocks and Struts
January 2012 StangAlley ROTM
Camo1967Mustang is offline   Reply With Quote
Old 02-16-2012, 02:09 PM   #10
Project Pony's Avatar
Have your suspension checked out. I too thought I had a bad caliper. Pulled em off and they were fine, but I noticed the ball joints were worn. Replaced them and it didn't pull anymore. What your describing sounds more suspension related than brakes. Either tie rods or balljoints would be where I'd bet on you finding your problem. Most shops will check out your front end really cheap and let you know for sure what is going on.
[SIGPIC][/SIGPIC]
Old 02-16-2012, 02:26 PM   #11
Cobrarunnin9s's Avatar
Re: When i brake...
He said it Happens when he's on the brakes, if it was a suspension issue it would happen all the time regardless of the driving situation. I would just check the left front caliper and check the line for cracks or if it's collapsing.
Cobrarunnin9s is offline   Reply With Quote
Old 02-16-2012, 02:52 PM   #12
Re: When i brake...
It is your front calipers.
I have had this happen on several cars over the years.
The caliper pistons get worn down and dirty over time and they will eventually stick in the bores and not apply pressure to your brake pads when you brake.
Evidently that's what has happened to your left caliper and when you brake only the right caliper is working which is what pulls you to the right.
You shoot back to the left because you are compensating for that pull and when you release the brakes the car naturally goes back to the left because you have released the drag on the right wheel.
Old 02-16-2012, 02:58 PM   #13
deadsp0t's Avatar
Exactly, there may be something like dirt in the bore for the piston causing it to not apply evenly.
That's unimpressive
Old 02-16-2012, 03:22 PM   #14
Re: When i brake...
+11
Old 02-16-2012, 03:46 PM   #15
This is not true. My situation was identical to his. Pulling only under braking. Calipers were fine, ball joint was shot. Don't tell him to ignore a possible reason for his issue just because you have never seen it. And since when is it bad advice to have him check out his suspension. The best time to replace stuff is before it breaks. Preventitive maintaince is never a bad thing. He could have either issue, but I bet you'll feel real smart if you are wrong. To the OP, check everything, it doesn't hurt to find any issues and take care of them before they get worse.
[SIGPIC][/SIGPIC]
Old 02-16-2012, 04:39 PM   #16
Re: When i brake...
For one, I never said disregard or ignore checking the ball joint at all. Just said I wouldn't check it. Plus you can get a caliper and pads installed for alot cheaper than replacing the ball joint. That's why I said just check the caliper and line.
Old 02-16-2012, 06:33 PM   #17
Why wouldn't you check something that doesn't cost you any money to check?! I wash my hands of this thread......
[SIGPIC][/SIGPIC]
Old 02-16-2012, 10:57 PM   #18
Timm04's Avatar
Alright guys didn't have time to tear it apart today or tomorrow but imma check this weekend
Old 02-21-2012, 02:50 AM   #19
Aussie Stang's Avatar
Region: Australia
Timm04,
Not wanting to dismiss your brake issue, but I love your profile photo. Post some photos up eh?
Aussie Stang is offline   Reply With Quote
Old 02-22-2012, 11:33 PM   #20
Timm04's Avatar
Originally Posted by Aussie Stang
Timm04,
I got some pics of it but imma wait till the spring when I have my other rims on and my car completely done on the exterior to take tons of pictures!! But I'm gunna take some more Don't worry bout that!
what are the advantages of a tune when you have a 5 speed ? jrny99 2011-2014 Mustang GT 3 02-26-2012 09:03 PM
ugh..... Not what I wanted to see when opening my differential. Otlaw80 1979-1995 Mustang GT 24 02-16-2012 02:59 PM
car turns off when disconnect battery superman1 Classic Mustangs 4 02-08-2012 09:41 PM
Weird noise when start up? 96 stang SVT Mustang 9 01-13-2012 06:25 PM
Anyone know when TPMS kicks in? illestdomer2005 2011-2014 V6 Mustang 5 01-05-2012 12:11 AM
09:37 AM
