Howl sound? - Mustang Evolution
Old 02-16-2012, 07:31 PM   #1
austinknoll's Avatar
Howl sound?
Hey guys, I have a howling noise that sounds like its coming from either the rear end or tranny and can't seem to figure out what it is. It howls only in 4th and 5th gear. My dad said it might be a bearing but I'm not sure.
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 02-16-2012, 07:40 PM   #2
Nichg's Avatar
Ya I'd say you have a worn bearing, how long has the noise been there because your ring and pinion could be compounded. If you leave it to long you may be looking at a new gear set. Did you check for leaks from the diff and tranny? That's where I'd check, also check to see if the noise is the same when on the throttle and off when in 4th and 5th
Nichg is offline   Reply With Quote
Old 02-16-2012, 08:37 PM   #3
Project Pony's Avatar
Does the pitch change with speed?
[SIGPIC][/SIGPIC]
Old 02-16-2012, 09:33 PM   #4
Throttle on noise, throttle off no noise or very little but mainly when the throttle is on
---------- Post added at 11:33 PM ---------- Previous post was at 11:32 PM ----------
When I go faster say in 4th it would go away when I press the gas more but casually driving it howls
65 Mustang coupe
Old 02-17-2012, 05:08 AM   #5
Nichg's Avatar
Re: Howl sound?
Sounds to me like you have a bearing(s) gone in your differential had the same situation/conditions on my 04 gt
Old 02-17-2012, 06:25 AM   #6
I agree. I need to have the rear end rebuilt in my wife's explorer. I had to replace the axle seals and when I popped off the diff cover it was nice and sparkly.....metal shavings everywhere.
[SIGPIC][/SIGPIC]
Old 02-20-2012, 08:46 AM   #7
So is this something I could do myself or do I need a shop to do it? My dad is a mechanic and we have most tools. And if info have to take it to a shop what am I looking at cost wise
65 Mustang coupe
Old 02-20-2012, 04:21 PM   #8
If your rear end needs to be rebuilt and your not familier with it then take it to a shop. First you need to pinpoint where the sound is coming from.
[SIGPIC][/SIGPIC]
Old 02-20-2012, 04:29 PM   #9
Nichg's Avatar
Re: Howl sound?
Ya your definately right, you need to diagnose which bearing(s) are gone. And remember when you get into your diff when replacing one bearing you should replace them all. And your crown and pinion gear set may require replacement.
Your looking at probably $700 for a rebuild kit and then labour on top of that if your not doing it yourself. Probably $1000 to $1500 for everything together. Just a guess you'd have to get a qoute
Factory sound inhance tube Gibby Saleen & SMS Mustang 13 01-28-2012 12:38 AM
Does Our 2012 Boss 302 Mustang Sound Insane or What?! Read more: VIDEO: Does Our 201 AMDanBailer AmericanMuscle 0 01-27-2012 03:51 PM
Sound shsfresh87 1996-2004 Mustang GT 35 01-15-2012 09:06 AM
Clicking sound?! ColeJohnson 1996-2004 Mustang GT 22 01-12-2012 04:31 PM
Shaker Sound System(s) Y2E0L0L5OGWT Mustang Audio & Video 1 01-08-2012 09:50 PM
09:38 PM
