| Re: New Headlight installation
There are two "grenade pins" behind the headlight assembly. Pull those up an the headlight assembly will no longer be connected to the car. Disconnect the headlight connector and the turn signal connector and you can remove the light. There is a plastic ring that holds the bulb in place. Just rotate it and remove the bulb. Install is the reverse procedure.
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
