Rear Gears - Mustang Evolution
Old 11-28-2007, 09:50 PM   #1
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
Rear Gears
I know there are many rear end threads but I did wan to "jack" them.
Will the 3.27 gt gear fit in my v6? I found some used 3.27 gears cheap. I want a little more acceleration but maintain my economy for now. Where can find these new? Also t-lock, I want tlock but would I need a whole new axle? or rear end?
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 11-29-2007, 06:03 AM   #2
bbunt302's Avatar
Re: Rear Gears
No, the gears from the 8.8" rear in the GT will not fit in the 7.5" rear in the V6. Besides, it not a good idea to take used gears from a rear end and put them in another due to wear patterns.
If you really want T-Lock and would be happy with the stock 3.27 gearing from the GT, you're best bet is to look from a complete GT rear end. It's a direct swap with the V6 rear end and can probably be found for around $500 or less. That's a lot less than you'll spend on new gears, a T-Lok and install on the 7.5 rear. Plus you get all the strength advantages of the 8.8.
Scary stuff.
Old 11-29-2007, 06:08 AM   #3
Herbstang's Avatar
Re: Rear Gears
What Ben said
Old 11-29-2007, 07:00 AM   #4
Re: Rear Gears
Like said above if you wish to have 3.27 gears buy a complete GT rear end (differnet years vary in how wide they are so get one in the same year style as yours if possible)
I would not go 3.27s... go 3.73's at least or dont waste your time.
Old 11-29-2007, 09:37 AM   #5
Re: Rear Gears
i agree with spector v middle wa of better acceleration is actually 3:55 but the best all around gears is atleast 3:73 because the acceleration is like night and day compared to stock v6 gears but your gas wont drop tremendously.
customsixstang is offline   Reply With Quote
Old 11-29-2007, 10:00 AM   #6
Re: Rear Gears
okay you all got me convinced. I will start shopping for a 8.8 rear end with 3.73 gears in the same year area. thank you
Old 11-29-2007, 02:09 PM   #7
Re: Rear Gears
how many splines do the gts from 94 to 98 have (the axle)
Old 11-29-2007, 06:06 PM   #8
Re: Rear Gears
28 spline as far as I know for all of those rear end axles and the axles from teh 7.5 are interchangable with the 8.8 as well (as far as i know) abs can get ya but you can just swap it out.
Old 11-29-2007, 09:48 PM   #9
Re: Rear Gears
I was asking because I am looking for a tlock. Do the 94 to 98 gts come stock with tlock? What is ABS?
Old 11-30-2007, 06:40 AM   #10
Re: Rear Gears
ABS is anti-lock brakes.
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline   Reply With Quote
Old 11-30-2007, 07:18 AM   #11
Re: Rear Gears
you cant use a traction lock unit from a gt as they fit 8.8 rear ends. You need one for a 7.5 inch rear end like the ones that come in rangers.
The abs is a little sensor and a ring gear on the axle ends~ you can take this out I am sure without to much issue. It can be a pain to get the axle shafts out of the rear end with ABS crap on them FYI (due to getting to the C clips)
Old 11-30-2007, 07:37 PM   #12
Re: Rear Gears
well I think if I am going to do gears I may as well go with a bigger rear end from a gt. Thats why I ask.
Old 12-04-2007, 01:57 PM   #13
Re: Rear Gears
Okay, I appreciate all your help and advice. I did 2 hrs of calling around today and made about 50 phone calls. I came up with 3 rear ends of which I can afford (<325). Tell me which you would prefer and why. PLEASE
1: 95 GT w/89,000 mi 3.27
2: 96 GT w/96,000 mi ?.??
3: 97 GT w/111,000 mi ?.??
Old 12-04-2007, 02:32 PM   #14
Re: Rear Gears
all of those will have 3.27 gears or worse so I wouldnt do that. I would do 3.73 or dont waste your money.
Old 12-04-2007, 02:35 PM   #15
Re: Rear Gears
So what rear end do I look for?
Old 12-05-2007, 10:34 PM   #16
Re: Rear Gears
I am just going to get gears for now. If I get gears I will need a chip or tuner to recalibrate correct speed. However, I have looked all over and I cannot find a chip or tuner for my 94 v6!!! know where I could get one?
Old 12-06-2007, 07:19 AM   #17
Re: Rear Gears
The issue with finding 3.73s as it is VERY hard to find a GT rear that has them installed. The factory usually put 2.73, 3.08, or 3.27s in the Mustang... so mostly you just have to buy the gears, tlok unit, and get it installed.
Installing MUST BE DONE RIGHT. Get a written warranty to protect aginst gear whine and breakage (such as bolts comming off the ring gear and chewing up your rear diff). If a company does not know how to set backlash, pinion depth, the crush sleeve, and check the wear pattern etc etc then they do NOT need to install your gears. DO NOT BUY USED PARTS EITHER. Buy ford racing 3.73 gears and a ford tlok for a 7.5 inch diff (if you build your 7.5 inch instead of an 8.8) dont buy other brand gears.
Rear End gears 2007STANG Pre-2005 V6 Mustang 19 03-23-2009 06:38 PM
rear end gears o3mustangGTafs 1996-2004 Mustang GT 2 07-17-2006 08:42 PM
rear gears tim11 Pre-2005 V6 Mustang 45 11-12-2005 01:40 AM
Rear Gears TBone Pre-2005 V6 Mustang 16 05-04-2004 10:10 PM
3.73 gears for 7.5 rear - $75 + shipping heramb22 Mustang Parts for Sale and Wanted 1 01-28-2004 09:02 PM
04:46 AM
