2001 3.8L exhaust system - Mustang Evolution
Old 02-19-2012, 10:28 AM   #1
Hey! I have a 2001 v6 and I want to make it loud, but not ridiculously loud. I want people to notice me and for it to sound good but my parents are against extremely loud systems like loudmouths, flowmasters, etc. Is there any way I could make it sound deep or almost like a GT for a small price? Thanks!
mchilliard28 is offline   Reply With Quote
Old 02-19-2012, 12:27 PM   #2
Re: 2001 3.8L exhaust system
The easiest and cheapest way is to get a chambered muffler like a flowmaster or pypes street pro muffler and dump it.
Simply swap the new muffler in place of the stock one, then have a turndown tip attached to the outlet end of the muffler.
This will make your exhaust louder than stock, but not crazy loud. It will also sound deeper as the exhaust will reverberate off the ground.
If you want to take it a step further you can do dual exhaust. You can do the same thing just with 2 pipes and mufflers. There are catback, converter back and full exhaust systems available, as well as having a shop fab the piping.
Dumping the exhaust is nice if you have the stock rear bumper as it doesn't have the exhaust cutouts like on the v8 cars.
Old 02-19-2012, 12:40 PM   #3
lemons95's Avatar
you could cam it
Old 02-19-2012, 12:44 PM   #4
Originally Posted by lemons95 View Post
you could cam it
Honestly, that would make a v6 sound the closest to a v8, at idle anyways...no type of exhaust will get you that lope from a cam.
Old 02-19-2012, 03:53 PM   #5
Alright thanks! Also, would there be a way to get a new catback without doing a dual conversion? And would that help my performance as well?
Old 02-20-2012, 06:25 PM   #6
Well I'm not sure if anyone sells a catback version with only a single pipe as 99% of the people buying catbacks usually want the dual piping.
If you want to keep one pipe, I'd just swap out the muffler...that way you'll get more sound and slightly more performance as the aftermarket mufflers are way less restrictive.
Old 02-20-2012, 07:28 PM   #7
Blackedout03's Avatar
Region: Delaware
What would be he best duel conversion setup to give it a loud but not ricer setup i got flowmaster 40's right now but an looking to get more aggressive v6 sound without doing cams
Blackedout03 is offline   Reply With Quote
Old 02-21-2012, 06:47 PM   #8
Well it really comes down to personal opinion...some guys will say the flow 40's are the best mufflers for the v6, while others will say borla or flow 10's.
I like my Pypes Street Pros over flows and Magnaflow because they don't get too high pitched in the higher rpms, they give more of a racy 350Z pitched tone. If you've heard a 350Z they don't sound like a honda with a cannon, more of a unique sound and I don't mind it. I do have all 4 cats and the stock y-pipe, so mine isn't crazy loud.
Honestly the v6's are better tamed than loud. Loud means more noise and higher pitched tones in the upper rpms, v8's are another story
Stick with chambered mufflers...if you want to make your current flow 40's louder try an off road midpipe, longtubes, or dumping the exhaust rather than tips out back.
Old 02-21-2012, 07:15 PM   #9
Project Pony's Avatar
My flow 40's sounded much better when I dumped em before the rear axle. But I still don't like them, they sound like a tractor. After hearing the magnaflow that's what is going to replace my flows.
[SIGPIC][/SIGPIC]
Old 02-21-2012, 07:51 PM   #10
Region: Delaware
I've been looking at longtubes and probably gonna get them but when it comes to mid pipes I have no clue on what midpipe to get would sound most like a v8 I've heard a lot of people with custom h pipes that sound like a v8 but am not sure haven't heard to many x pipes. Do they sound better than a h pipe?
Old 02-21-2012, 08:35 PM   #11
X pipes tend to be more raspy while h-pipes tend to make your exhaust deeper.
I personally don't care for off road x-pipes on v6's because it makes them way too raspy and high pitched...pair that with a straight thru muffler and you sound just like a 4 banger import. A catted one would probably sound better as it's quieter.
The h-pipes help make the exhaust sound a little bit deeper at idle and in the lower rpms, but higher up it's not going to matter, the v6 is just naturally high pitched.
Another option that might save some money is to simply replace the stock y-pipe with 2 divorced pipes. Basically the same concept minus the h or x part lol. In reality the science behind the h-pipe doesn't really apply to v6's since they're even firing, the pulsations don't balance.
This way you can keep 2 or 4 of your cats if you want and get rid of the restrictive y-pipe.
Old 02-21-2012, 08:40 PM   #12
Region: Delaware
I already have the duel setup with flowmaster 40's but want something a bit deeper
Old 02-21-2012, 08:42 PM   #13
I did divorced duals with no x or h pipe. Sounded OK, but sounded better once I had the h pipe welded in
---------- Post added at 11:42 PM ---------- Previous post was at 11:41 PM ----------
Long tubes...
[SIGPIC][/SIGPIC]
Old 02-21-2012, 08:44 PM   #14
Region: Delaware
Long tubes...
What about changing my mufflers or taking off cats or resistors
Old 02-21-2012, 08:46 PM   #15
Borlas tend to be deeper on the v6's but are pricey...
Do you have the stock v6 bumper? You could dump the exhaust right after the mufflers or past the axle under the bumper. That would help the exhaust sound deeper.
Old 02-21-2012, 08:50 PM   #16
Region: Delaware
Ya stock bumper and what type of borlas would you recommend and I'll probably dump them
Old 02-21-2012, 08:59 PM   #17
Well I know Borla used to make a converter back system for the v6's and it was ~700 So your best bet would be to find some regular Borla mufflers or Stingers. They are probably crazy expensive too...everything Borla is expensive because of the name and they sound real good on v8's.
I would try dumping your Flows first..you may like the sound difference. Keep in mind Borlas are straight thru mufflers and may not sound good to you. I personally haven't heard them on a 99-04 v6..some people like them others don't.
Old 02-21-2012, 09:04 PM   #18
willrad00's Avatar
How much of a clearence issue are longtubes? i want longtubes but i also wanna lower the stang bout 2' all around, and headers are the last thing i want hitting speed bumps.
willrad00 is offline   Reply With Quote
Old 02-21-2012, 09:14 PM   #19
Region: Delaware
Alright thanks
---------- Post added at 11:14 PM ---------- Previous post was at 11:08 PM ----------
And if I can't find any borlas what else would you recommend
Old 02-21-2012, 09:18 PM   #20
Don't want to hijack the thread but I'll answer quick...
I am lowered ~2" in the front and 1.8" in the rear and on rough roads (crowned, gaps) I will scrape my cats. So I'd imagine you might catch your longtubes on rough roads. Steep inclines and speed bumps would also be tricky...you could scrape entering/exiting a driveway/business with an incline. It really depends on the brand and how low the collectors sit.
If you're careful and avoid bad roads and speed bumps you'd be fine.
A couple scrapes might not hurt but you always take that chance of damaging the piping or catch a flange.
Old 02-21-2012, 09:28 PM   #21
Alright thanks
Well again it's really a personal preference but I like Pypes Street Pros and the Flowmaster 10's. There is a chambered Cherry Bomb out there that some have said sounded decent but I haven't heard them. The regular Borla XS, Borla S and Borla Stingers are the popular mufflers, but are expensive.
It's hard for me to recommend mufflers and say what sounds "good" since I really don't believe anything sounds truly "good" on a v6, that's why I just threw on 2 chambered mufflers and called it a day. It's quiet, has a crisp tone when accelerating and doesn't get overly high pitched above 3k.
If you want different sound than try a different muffler brand, preferably chambered.
If you want to change your current mufflers sound, add a midpipe, divorced piping, or dump the bastards under the car.
Old 02-22-2012, 04:18 PM   #22
Region: Delaware
would the rolled exhaust tips help it rumble more?and if im correct wouldnt a longer tip make it rumble more?
Old 02-22-2012, 11:58 PM   #23
lemons95's Avatar
COMP Cams: 6 Cylinder
@blackedout03 a cam would get you the best idle, everything needed to cam it is in the link, you should get new roller lifters, pushrods(i haven't checked what length is needed) and stiffer/stronger springs.
Old 02-23-2012, 12:11 AM   #24
Region: Delaware
How much that run?
Old 02-23-2012, 03:08 AM   #25
lemons95's Avatar
1/4 mile or as in the price? its late and i'm tired...
for the price the cams for the 3.8/4.2 cost the same but the higher performance ones require spring and computer modifcations at $337
I may be wrong but the roller lifters cost $163 this is where I'm worried bcuz
i think its each
springs are between $43-155
so around $1500 for everything
you could save alot by re-using your old roller lifters
then it would be more around $500. I don't know much. i'm actually learning alot here myself. but i've been planning.
Have you heard how a cammed V6 sounds like though. I LOVE IT! can't wait to do it to mine.
Old 02-23-2012, 04:34 AM   #26
trixinahat's Avatar
Ya I am pricing some today.. thanks for the input and yes camed out v6 sounds great!! Mine is dumped so I can wait. I going to order the under pulleys Saturday
trixinahat is offline   Reply With Quote
Old 02-23-2012, 05:45 AM   #27
Region: Delaware
Let me know if you can tell a difference with the pulleys I've heard it doesn't do much unless supercharged
Old 02-25-2012, 07:47 PM   #28
trixinahat's Avatar
Ya it do help.. . I noticed right off the bat. Just did it this morning. Not hair raising fast but when you ball on a budget like me it easy fast and makes a difference.
Old 02-25-2012, 09:46 PM   #29
Region: Delaware
Probably like ten horses?
Old 02-25-2012, 11:45 PM   #30
Prolly just an increase in acceleration. You won't feel 10 hp difference.
Blackedout is offline   Reply With Quote
Old 02-26-2012, 06:02 AM   #31
99ManMustang's Avatar
Hey y'all, talking bout all this exhaust stuff, figured I'd throw my question. Looking at some duals for my 99 v6, I've heard stock 99 -04 gt exhaust bolts up directly, would a 1994 mustang gt exhaust bolt directly up to my stock headers? It's a good price so I'm hoping even if I have to modify it a little bit it will still work. Thanks guys.
99ManMustang is offline   Reply With Quote
Old 02-26-2012, 05:42 PM   #32
I believe you need a mid pipe for the GT exhaust to work.
[SIGPIC][/SIGPIC]
Old 02-26-2012, 06:29 PM   #33
I don't wanna sound stupid, but what's that?
Old 02-26-2012, 09:12 PM   #34
The GT exhaust won't just bolt to your factory y pipe. You'll have to get an adapter.
[SIGPIC][/SIGPIC]
Old 02-27-2012, 05:27 AM   #35
No such thing as a stupid question. If you don't know just ask.
exhaust
« Reverse | 98 3.8 »
exhaust & warranty 04TRV6 2011-2014 V6 Mustang 20 03-04-2012 06:26 PM
Exhaust Taxman 1979-1995 Mustang GT 17 02-18-2012 11:59 PM
Better sound of exhaust Blackedout Pre-2005 V6 Mustang 7 02-18-2012 04:23 PM
exhaust help!? reeg2010 2011-2014 Mustang GT 28 02-18-2012 02:36 AM
Exhaust questions Gixx 2011-2014 Mustang GT 14 02-17-2012 06:40 PM
08:21 AM
