Mustang emblems - Mustang Evolution
Old 02-23-2012, 12:19 PM   #1
Rose0601's Avatar
Mustang emblems
When I was in a wreck about 8 years ago the mustang emblems on the side got put on backwards. The mustang should always go forward and I was wondering what would be the easiest way to pop these guys out and swap them??! Thanks
Rose0601 is offline   Reply With Quote
Old 02-23-2012, 04:11 PM   #2
Blackedout03's Avatar
Region: Delaware
Buy new ones cause the glue won't hold good if you swap them
Blackedout03 is offline   Reply With Quote
Old 02-23-2012, 04:35 PM   #3
mustangg2000's Avatar
Region: Arkansas
Heat gun low heat putty knife do it easy there are studs that stick through the fender to keep them in place.. you shouldn't have glue on them any way they should have a double sided tape 3M makes lots of different sizes to stick them back on.. re painted my car three years ago and the 3M tape I used still holding strong..
mustangg2000 is offline   Reply With Quote
Old 02-23-2012, 04:38 PM   #4
Region: Delaware
The ones on my car are foam with like some sort of glue
Old 02-23-2012, 04:49 PM   #5
Region: Arkansas
Panel bond its a foam adhesive.. indeed a glue .. insert foot into mouth lol but double side tape be easier no mess .. and very durable
---------- Post added at 05:49 PM ---------- Previous post was at 05:46 PM ----------
I have worked on many and they use a lot of both guess its just a preference for our shops..
Old 02-23-2012, 07:11 PM   #6
Rose0601's Avatar
Yea thanks for all the advice I will prolly try and see if the double sided tape works first if not then I'll just get new ones
Old 02-23-2012, 09:55 PM   #7
Toom71's Avatar
Better to get new ones instead of tape. Ebay always has them for cheap.
Toom71 is offline   Reply With Quote
Old 02-24-2012, 08:08 AM   #8
Region: Arkansas
Whether the emblems are new or the ones on the car still have to be put back on the car right ... And if you pull old ones off the area still has to be cleaned to put new ones or the same ones back on right my point was only the double sided tape is durable and will hold them on there.. but if the emblems ain't broke or messed up why buy new ones ...
« I has a ? | Help? »
Mustang Game 1ijack General Mustang Discussion 8221 08-11-2017 07:22 AM
2002 V6 mustang cats? Rouse Pre-2005 V6 Mustang 43 03-03-2012 06:58 AM
Mustang emblems Rose0601 General Car Discussion 4 02-23-2012 01:17 PM
03 v6 mustang Austen14utd Pre-2005 V6 Mustang 1 02-23-2012 06:46 AM
What mustang evolution inspired me to do 98projectpony General Mustang Discussion 5 02-23-2012 06:30 AM
07:28 AM
