1995 3.8 will a tuner work? - Mustang Evolution
Old 02-23-2012, 10:40 PM   #1
lemons95's Avatar
i'd rather have a tuner, and I read that the 94 and the 95's had OBDII they just arn't 100% compatible with the regular OBDII could i still use a tuner?
Old 02-23-2012, 11:09 PM   #2
clifford's Avatar
Re: 1995 3.8 will a tuner work?
I was under the impression that they (94-95 pcm's) had to be flashed or chipped or something like that. Ran into a similar issue on a Caprice some time ago.
1996 Mustang V6 5M Coupe. 134K Miles. Stock.
clifford is offline   Reply With Quote
Old 02-24-2012, 12:44 AM   #3
lemons95's Avatar
I'm not really sure I haven't looked to see if it has the OBDII port thing i should check that tommorow.
Old 02-24-2012, 02:03 PM   #4
Project Pony's Avatar
My 94 was odbII I used my code scanner on it a few times, as for the tuner I don't think it will work with the 94-95 v6. I could be wrong....
[SIGPIC][/SIGPIC]
Old 02-27-2012, 10:40 AM   #5
newboy95's Avatar
Just a heads up on the 95, before tossin cash into it, make sure the head gaskets are new. 95 had a huge recall on the head gaskets due to bad gaskets. Trust me, you don't want that headache. My 95 blew and then led to a burnt out piston.
newboy95 is offline   Reply With Quote
Old 02-27-2012, 12:15 PM   #6
94-95 were very bad with head gaskets. Problem was fixed on the 96-98 3.8's. I believe it was something like the factory torque specs on the head bolts. My 94 blew one, so a 98 motor was swapped in.
[SIGPIC][/SIGPIC]
Old 02-27-2012, 01:03 PM   #7
newboy95's Avatar
Yeah. I'm swappin to a 94. Replacing all gaskets for sure. Best deal I could find.
Old 02-27-2012, 08:05 PM   #8
lemons95's Avatar
The person i bought it from had them replaced. maybe not soon but later eventually i'll swap a 1997 4.2L in it. I'll have to use my old 3.8 heads though for awhile(do they even fit) cause it looks like one of thems cracked. and I don't have the rest of the 4.2 Intake yet.
Old 02-27-2012, 08:51 PM   #9
newboy95's Avatar
Figure out the cubic inches and I believe the heads won't match. As far as swapping to a 4.2l its a headache. U need the k member and a arms. New transmission and drive shaft. And need an 8.8 rear end. Very costly for the 95.. unfortunetly. I tried that and that's why I'm stickin with the 3.8. If u had a 96 to 98 it would have the k member. 95 is not the choice year.
Old 02-27-2012, 11:33 PM   #10
whyxitx's Avatar
Region: Nebraska
I thought the 95 and under were all OBDI's?
whyxitx is offline   Reply With Quote
Old 02-27-2012, 11:41 PM   #11
lemons95's Avatar
I'm planning on swapping alot into but no one else has ever told me i'd need a new transmission. since there both small blocks they should fit. the biggest problem i've seen so far is swapping to split port. Theres a used auto wrecker where i can get the heads for $100 each. the 8.8 rearend I don't think is needed but I want the 8.8 rearend anyways so that's not really a problem. The engine in it currently is the original 3.8 its got over a 150,000. The 4.2L i got i found in the back room of my high schools autoshop got it for free. I plan on buying mostly or hopefully all high performance parts.
Old 02-28-2012, 12:01 AM   #12
newboy95's Avatar
Its better to move to the 8.8 for better performance. If its an aode auto tranny, the engine will burn it out in no time. Standards I'm not sure about.
Old 02-28-2012, 07:50 AM   #13
The gt's were I believe, but the sixes are odb2
[SIGPIC][/SIGPIC]
Tuner help 2002VertGT 1996-2004 Mustang GT 43 02-28-2012 08:16 PM
98 3.8 in need of power.. cam? trixinahat Pre-2005 V6 Mustang 33 02-26-2012 09:40 PM
More goodies for me! SCT tuner ?'s Project Pony Pre-2005 V6 Mustang 2 02-23-2012 02:04 PM
Diablo predator tuner 2000v6jj Pre-2005 V6 Mustang 5 02-21-2012 10:06 PM
03:01 AM
