02-24-2012, 03:09 PM
#1 | | Registered User
| ticking sound under my car?
I recently took a trip out to palm springs CA. On our way back to L.A. I noticed a kinda change of acceleration. It feels like its forced to go up past 25mph. Also there's a ticking sound kinda like a clock tick but three times faster. I'm on the bus cause I didnt want to push the car around if its hurting. Any ideas what it could be?
02-24-2012, 06:56 PM
#2 | | Registered User
Idk but all the mustang engines down here in central Texas just have a ticking sound. Kinda like you need to change ur oil but that's not it lol..
"Hp sells cars, Tq wins races" - Carroll Shelby
Black and yellow, black and yellow!
Runnin' circles around one camaro at a time |
02-24-2012, 10:00 PM
#3 | | Registered User
Do you notice it more when your slowing down and accelerating? If so I'd check the driveshaft. Mine was making a ticking sound and just got to fiddling with it and all the bolts on the driveshaft that connect it to the rear end were loose. I tightened them up and it stopped.
02-25-2012, 05:47 PM
#4 | | Registered User
| Quote: |
Originally Posted by Cp3 Do you notice it more when your slowing down and accelerating? If so I'd check the driveshaft. Mine was making a ticking sound and just got to fiddling with it and all the bolts on the driveshaft that connect it to the rear end were loose. I tightened them up and it stopped. | Actually it could be on Idle and you can still hear it. The sound matches the acceleration. So higher mph =fast ticking etc.
02-25-2012, 07:08 PM
#5 | | Registered User
Did you check the bolts? In not gonna tell you for sure that it's the problem but it spear hurt to check. Other than that idk
02-25-2012, 09:23 PM
#6 | | Registered User
Won't. Not spear
02-25-2012, 09:33 PM
#7 | | Loc: Austin,TX
| Re: ticking sound under my car?
Could be a exhaust leak or throw out.
---Dan--
2011 5.0 6MT Black on black premium,3.73 option and some go fast goodies!
*POSTING RULE #1*
Before you post a question, use the forum search feature to determine whether your topic has already been covered. http://www.mustangevolution.com/foru...ork&page=rules |
02-25-2012, 09:36 PM
#8 | | Registered User
DDTCM could it possibly be tranny? Or is that what you mean for throw out?
02-25-2012, 09:38 PM
#9 | | Registered User
Do you owe any shady people or organizations any money?
02-25-2012, 11:35 PM
#10 | | Senior Member
| Quote: |
Originally Posted by wheelman Do you owe any shady people or organizations any money? | Haha ---------- Post added at 12:35 AM ---------- Previous post was at 12:35 AM ---------- Ticking... Any check engine lights?
02-25-2012, 11:46 PM
#11 | | Loc: Austin,TX
| Re: ticking sound under my car? Quote:
Originally Posted by Cp3 DDTCM could it possibly be tranny? Or is that what you mean for throw out? | Throw out bearing. Had the same issue on my Cobra,needed a new clutch. Does it make this noise at idle and when you engage the clutch a bit it goes away?
---Dan--
*POSTING RULE #1*
02-26-2012, 06:46 AM
#12 | | Registered User
I had a ticking that matched that and I throw a rod .. same thing faster acceleration faster the ticking and you give it gas acted like it wanted to not get up and go.. my bearings on my crank was stacking up.. had to get a new engine
02-26-2012, 10:36 AM
#13 | | Registered User
No I don't owe any shady people.money LOL. And no check engine lights. Tomorrow I'm going to have someone scan to see if it picks up any codes. If not I gotta take her in for an inspection.
02-26-2012, 08:02 PM
#14 | | Registered User
Told you to have my money today!!
02-26-2012, 09:38 PM
#15 | | Registered User
You know i drove today for a bit and the oil gauge randomly drops down to e them goes back to regular/ ---------- Post added at 10:38 PM ---------- Previous post was at 10:36 PM ---------- I mean L
02-26-2012, 10:29 PM
#16 | | Senior Member
| Quote: |
Originally Posted by Vile87 You know i drove today for a bit and the oil gauge randomly drops down to e them goes back to regular/
I mean L | Mine does that too. Don't worry about it. An oil guage isn't accurate on our models. From what I heard ---------- Post added at 11:29 PM ---------- Previous post was at 11:29 PM ---------- Quote: |
I mean L | Someone needs to research this. And why this happens!
02-27-2012, 07:00 AM
#17 | | Registered User
The sensor needs to be changed and the oil gauge read the pressure. And not how much oil is there
02-27-2012, 08:34 AM
#18 | | Senior Member
| Quote: |
Originally Posted by kickerofdoom The sensor needs to be changed and the oil gauge read the pressure. And not how much oil is there | So the sensor needs to be changed. And the oil gauge is accurate. Is what your saying?
02-27-2012, 08:58 AM
#19 | | Registered User
Yes that what I heard has helped
02-27-2012, 10:33 AM
#20 | | Senior Member
| Quote: |
Originally Posted by kickerofdoom Yes that what I heard has helped | Alright. Thanks. I made sure mine was connected and it wasn't it was loose I might need another one
02-27-2012, 10:39 PM
#21 | | Registered User
Check the passenger side manifold, they're notorious for exhaust leaks due to the A/C dripping on the manifold. If that's the culprit, get it welded and make an A/C drip catcher so it doesn't drop on the manifold anymore.
and i also know that our cars are notorious for the "ticking" sound in the manifold.. i've learned to just deal with it. Get a louder exhaust so noone can hear it!
02-28-2012, 07:29 AM
#22 | | Evolution's Finest
| Quote: |
Originally Posted by whyxitx Check the passenger side manifold, they're notorious for exhaust leaks due to the A/C dripping on the manifold. If that's the culprit, get it welded and make an A/C drip catcher so it doesn't drop on the manifold anymore.
and i also know that our cars are notorious for the "ticking" sound in the manifold.. i've learned to just deal with it. Get a louder exhaust so noone can hear it! | Its a nasty problem that they have. I have to replace mine, but I'll make sure to divert the AC condensation to avoid it happening again. The ticking drives me bonkers, and sounds horrible.
Just because something "can" be done, does not mean it should be done....
02-28-2012, 09:42 AM
#23 | | Registered User
| Quote: |
and i also know that our cars are notorious for the "ticking" sound in the manifold.. i've learned to just deal with it. Get a louder exhaust so noone can hear it! | +1 on the louder exhaust, also you can crank that music up, you'll never know its there!
02-28-2012, 09:48 AM
#24 | | Terminator Owner
99-04 v6's are known for water leaking (condensation) onto the headers and can cause a leak. It chould be this.
__________________ 2003 Cobra Vert (Redfire) #3938 of 5082 @ 05/27/2003
472rwhp/493rwtq - Modification List - Dyno Sheet 2012 Mustang 3.7L M6 (Kona Blue) 2011 Ford Edge Sport (Red Metallic) |
02-28-2012, 10:42 AM
#25 | | Registered User
Yup I hate it too. Well turns out I definitely need to replace my oil pressure components. And the ticking was from loss of engine oil. My guy still has the car but he called to tell me it was burning up the oil....? Imma swing by later to see exactly what's the issue.
03-02-2012, 10:38 PM
#26 | | Registered User
its your exhaust manifolds either the passanger or drivers theres a tsb on this your mpg will drop and you accel will also replace with pace setter headers from summit racing for 174 and ur good
03-03-2012, 10:54 AM
#27 | | Registered User
I had this problem and I noticed it when I moved from Cali to Arkansas/texas... What my step dad and I did was check where the exhaust and engine connect. I have a 99 v6 5 speed, and it's where the donut is suppose to be, you just tighten those bolts because they may be loose. Now I dont hear it unless I slam on the gas, and my step dad said it's either the exhaust gaskets or the exhaust manifold... But check if the bolts are loose, and if you still hear it, it may be either the gasket or exhaust manifold.
03-03-2012, 11:36 AM
#28 | | Registered User
Yeah Texas stangs are known for that sound, including mine
03-03-2012, 12:06 PM
#29 | | Senior Member
I wonder if I can make hose fit in that hole an route it away from the exhaust ---------- Post added at 01:06 PM ---------- Previous post was at 01:05 PM ---------- Quote: |
Originally Posted by Blackedout I wonder if I can make hose fit in that hole an route it away from the exhaust | Or would the hose clog
03-04-2012, 07:42 PM
#30 | | Registered User
yes you can do that.
