Cut springs - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 02-27-2012, 08:56 AM   #1
Surffer227's Avatar
Surffer227 is unknown around these parts
Cut springs
Im cutting my springs right now and wanna know how much Is good, anyone know?
Surffer227 is offline
Old 02-27-2012, 09:06 AM   #2
deadsp0t's Avatar
deadsp0t is unknown around these parts
Always herd one complete coil. Never done it so idk really.
That's unimpressive
deadsp0t is offline
Old 02-27-2012, 09:20 AM   #3
Venomouz831's Avatar
Venomouz831 is unknown around these parts
Like chop some off?
)02 Gt, Founder of WE2G
Venomouz831 is online now
Old 02-27-2012, 09:28 AM   #4
Surffer227's Avatar
Yea, I was thinkin like half a coil or somethin, but I was wondering the coil to inch drop ratio lol if there is even one
Old 02-27-2012, 09:34 AM   #5
Idk the drop ratio but I would recommend to not do it. My friend did tht and was the bumpiest ride ever. He regrets doing that but it made his car lower
Old 02-27-2012, 09:41 AM   #6
Eturner's Avatar
Eturner is unknown around these parts
+11. Save your cash and get an actual drop springs!..
Eturner is offline
Old 02-27-2012, 10:25 AM   #7
deadsp0t's Avatar
Ppl cut springs everyday.
That's unimpressive
deadsp0t is offline
Old 02-27-2012, 10:29 AM   #8
Las0mbra's Avatar
Las0mbra is unknown around these parts
People also do a lot of stupid things. Cutting the springs can weaken them. You can find a cheap set of springs for like $120 if you look around.
Las0mbra is offline
Old 02-27-2012, 10:33 AM   #9
Yea don't cut springs it will f up ure suspension
Old 02-27-2012, 10:48 AM   #10
deadsp0t's Avatar
Whatev... Seen cars run 5.0000 in the 1/8 on cut springs. Never said it was the best option, it's really not that serious. I'd cut springs before I ran cheap knock offs any day.
That's unimpressive
deadsp0t is offline
Old 02-27-2012, 11:04 AM   #11
Never said you couldn't just saying its not gonna be a good ride at all.
Old 02-27-2012, 11:13 AM   #12
LuVUrFr3nZ is unknown around these parts
I'm pretty sure this was on last weeks episode of car warriors. They said if you were going to do it, do it at most a quarter coil at a time
LuVUrFr3nZ is offline
Old 02-27-2012, 11:19 AM   #13
Eturner's Avatar
You can get a good set of Eibachs or a set from Steeda for about $150!..
Eturner is offline
Old 02-27-2012, 11:27 AM   #14
Yup got my maxspeed for 140
Old 02-27-2012, 11:42 AM   #15
shaqfu's Avatar
shaqfu is unknown around these parts
Re: Cut springs
check these out for cheap option....
Anyone have an idea why it says not good for convertibles?
1979-04 Mustang Specific Rate Red Lowering Springs by SVE at LRS - Free Shipping!
shaqfu is offline
Old 02-27-2012, 11:48 AM   #16
Project Pony's Avatar
Project Pony is unknown around these parts
I did my springs for giggles. Started with a 1/4 at a time and ended up doing one full coil. Don't let the spring get to hot when cutting. Gave about 1.5-1.7" drop. Noticed no difference in handling and had no issues. I did however order dropzone springs before I cut. I heard so many stories good and bad about cutting springs. I had no problems, just wanted to see what all the fuss was about. If you don't have money for springs, theyre not expensive, then you can cut your springs for a temporary drop. I would still look into getting a set of springs.
---------- Post added at 02:48 PM ---------- Previous post was at 02:47 PM ----------
Different weight for the convertibles.
Just because something "can" be done, does not mean it should be done....
Project Pony is offline
Old 02-27-2012, 11:54 AM   #17
shaqfu's Avatar
Re: Cut springs
thats what i thought, lighter weight engine + less weight with no hard top = wont drop as much,,,with that in mind, is any spring better for convertible drop?
I am getting new larger wheels soon (17 x 9 vs 16 in stock), and wanted to drop 1.5 inches also. so i wanted to make sure. Going to have my local guy do a dual exhaust (adding another flowmaster 44) and install springs at same time.
shaqfu is offline
Old 02-27-2012, 12:19 PM   #18
If I'm not mistaken the vert wieghs more than the coupe, extra bracing and supports to make up for the lack of a roof.
Old 02-27-2012, 12:31 PM   #19
shaqfu's Avatar
Re: Cut springs
interesting....google is probably my friend on that question...
Let me google that for you
shaqfu is offline
Old 02-27-2012, 12:34 PM   #20
kickerofdoom's Avatar
kickerofdoom is unknown around these parts
The Ford springs are the best for money. Cheaper and are made for mustang and no need to change out other parts maybe at most shocks
kickerofdoom is offline
Old 02-27-2012, 01:07 PM   #21
Surffer227's Avatar
Cut half a coil on the front and didnt notice much, doing the rear tomarow, another half on the front is a possibility, just don't Realy feel like taking it apart again.. Haha
Old 02-27-2012, 10:36 PM   #22
whyxitx's Avatar
whyxitx is unknown around these parts
Re: Cut springs
1 - 1 1/2 coils on the front, 1 coil in back. That's what i usually hear people are running. They won't hurt your suspension horribly either so just go for it.
whyxitx is offline
Old 02-28-2012, 12:29 PM   #23
Surffer227's Avatar
Just cut a full coil in the rear and it looks great. Rides fine, no rubbing, and I have 18"s. only did half a coil on the front, so I kinda have a Cali drop goin haha, I might do more on the front tomaro, but I'm not sure if I should do another full coil for 1 1/2 up front or just another 1/2 coil and make it even with the back, anyone know how much camber I can get out of the stock bolts, without buying the plate or kit? Just incase I get a rubbing issue.
Old 02-28-2012, 12:46 PM   #24
A full coil drops between 1.6 and 2 inches, you will need plates or camber bolts as your camber will be off by about 1 degree. Don't skimp on this because you will wear your tires unevenly. I just ruined a set of brand new tires this way. So now I'm buying all new tires, and the eibach camber bolts which will give enough adjustment to get everything back to normal. The bolts only run about 30 bucks on American muscle, much cheaper than two new tires will cost you.
Old 02-28-2012, 12:52 PM   #25
stampde's Avatar
stampde is unknown around these parts
Re: Cut springs
I would never cut a coil spring , supposedly the rides harsh ,but the real problem is your weakening the spring overall witch will lead to other suspension issues in the future ...........
2006 Tungsten grey v6 Pony package
stampde is offline
Old 02-28-2012, 12:52 PM   #26
Its also a very good idea to replace your shocks and struts if they have any kind of miles on them after a drop like this.
Old 02-28-2012, 01:13 PM   #27
Surffer227's Avatar
Can't I just get smaller bolts from like homedepot or something? Obviously the same strength, and my springs ride fine so far.
Old 02-28-2012, 01:29 PM   #28
Eturner's Avatar
If your going to do some thing do it right!.. Don't get some homedepot S*** and think it's all going to be ok!.. Plus personally I would never think of cutting the springs!.. I've known to many who did that and ended up being sorry they did!.. The stock springs are designed to ride at a certain hight, and for good reason, just get some actual drop springs!.. There are several companies out there that make great drop springs, for almost any hight you want!..
Don't be in such a rush that you are taking cheap easy shortcuts to building your ride!.. You'll be much happier in the end, plus you might not be spending some of your hard earned cash fixing one of those cheap shortcuts you took!..
Eturner is offline
Old 02-28-2012, 01:34 PM   #29
Surffer227's Avatar
Already did it, and don't regret it, I want advise from people who did it, or know what their talking about, not people who herd it's a bad idea...
Old 02-28-2012, 01:57 PM   #30
Eturner's Avatar
First off I know it to be a bad idea because I've known several people that did it!.. One guy his car started riding at a weird angle, like stated before, cutting the springs weakens them!.. This is not hearsay!.. This is a fact!.. Each coil on your springs is wound in such a manor to, one keep the vehicle ridding at a certain hight, and two, to bear a certain amount of load, or weight!.. When you cut off a coil or more you drastically change that!..
Take your time and build it right!.. Use the right parts the right way and you'll be happier in the end!..
Growing up I've known too many guys building their own cars!.. One guy spent nearly ten years building his car!.. When he was done I asked him why did it take you so long to build it?.. He said because he wanted to do it only once and to do it right!.. He didn't take any shortcuts!.. Some others took shortcuts and ended up spending more cash fixing alot of those shortcuts!..
Eturner is offline
Old 02-28-2012, 02:00 PM   #31
deadsp0t's Avatar
The springs are cut already.
That's unimpressive
deadsp0t is offline
Old 02-28-2012, 02:57 PM   #32
Do The Evolution
primer2tone's Avatar
primer2tone is unknown around these parts
This is always gonna be a controversial topic. I've cut springs in the past and I've used lowering springs as well, I've even got a set of fully adjustable coil overs on my 240sx! One pro I can say about cut springs is you never hear the thump of your spring coils smacking together when you go over hard bumps like you do with lowered springs. Lowered springs coils are just too close together on some applications. I'm just a lyrical Gangsta and that's how I roll. You'll learn that.
primer2tone is offline
Old 02-28-2012, 03:20 PM   #33
Senior Member
Blackedout is unknown around these parts
Don't do it. SONICPONY03 has a great set up you should look at his profile pictures
Blackedout is offline
Old 02-28-2012, 03:34 PM   #34
Moderator
93slowstang's Avatar
93slowstang is unknown around these parts
I have 2" drop springs and they don't smack together.
93slowstang is offline
Old 02-28-2012, 03:43 PM   #35
Eturner's Avatar
I had a 1.5" drop on my Monte and they didn't smack together or anything like that!.. Perhaps he got bad set or something!..
But still I would rather go with some actual drop springs vs cutting the them!.. There's just to many things that can go wrong with cutting them that can make for some bad Mojo!!... Lol
Eturner is offline
Closed Thread
55D springs 5LHO 2010-2014 Mustang GT 12 03-11-2012 03:06 AM
$110 Track day at Willow Springs- Big Track -March24 in SoCal Extremespeed Regional Mustang Discussion 1 03-07-2012 12:08 AM
WTB: lowering springs 2002VertGT Mustang Parts for Sale and Wanted 4 02-27-2012 12:35 PM
New Cams and Springs 67mustang97 1996-2004 Mustang GT 5 02-21-2012 06:02 PM
How can you tell if you have stock springs?? SwatKatz901 1996-2004 Mustang GT 16 02-17-2012 06:48 PM
12:21 AM
