Balljoints, struts, suspension, etc - Mustang Evolution
Old 02-28-2012, 09:03 PM   #1
Ajmt719's Avatar
This morning my Balljoint separated on my 99 mustang causing the tire, struts, and everything connected to bend badly... What should I do? Any idea of how much it'd cost to replace? Thanks in advance
ID:	42065   Click image for larger version
Ajmt719 is offline   Reply With Quote
Old 02-29-2012, 05:36 AM   #2
Damn I need to get my balljoints done then... Holy crap. Mine been squeaking and popping. It's been this way for a year. :0
Blackedout is offline   Reply With Quote
Old 02-29-2012, 07:16 AM   #3
mustangg2000's Avatar
Region: Arkansas
You gonna do the ball joint change yourself? There two different kinds a bolt in and a press in .. most local part store rent tools Ull need a press tool if that's what urs is.. first all u need to get it jacked up get the side out a bind.. take the tire off see if it needed up much or if was just the ball joint
mustangg2000 is offline   Reply With Quote
Old 02-29-2012, 07:44 AM   #4
I would do it myself but idk how to do it.... I got stock balljoints
Old 02-29-2012, 07:45 AM   #5
Ajmt719's Avatar
I'm not really good mechanically so I'll probably take it to a local shop....mine squeaked and popped for maybe 7 months, I had a backyard "mechanic" check it several times and all he did was spray it with wd-40 which stopped the squeak but made it Way worse
Old 02-29-2012, 07:50 AM   #6
Should have rubbed grease around the balljoints
Old 02-29-2012, 08:03 AM   #7
Region: Arkansas
In my Chevy I had all four front ball joints broke at once it was a Hell of a ride I was going down a busy street.. I changed the whole front end after that .. but yeah always needs to stay greased up there is a alimite fiting u pump full grease with a grease gun..
Old 02-29-2012, 08:28 AM   #8
Ajmt719's Avatar
Aren't the stock Balljoints sealed so they can't be greased?
Old 02-29-2012, 08:59 AM   #9
Rascal's Avatar
Re: Balljoints, struts, suspension, etc
Yup there is no grease nipple on the stock ball joints.. My buddy had a little needle fitting for a grease gun. we just poked a little hole in the boot and filled her up. sucks having to put a hole in your boot but getting grease in there is better than having none. ^^b
Put a little gorilla glue over the hole and didn't have any leaking problems
Rascal is offline   Reply With Quote
Old 02-29-2012, 09:23 AM   #10
Ajmt719's Avatar
That sounds good, ill be sure to remember that for future references
Old 02-29-2012, 06:23 PM   #11
Bought my steeda x2 balljoints
---------- Post added at 07:23 PM ---------- Previous post was at 07:22 PM ----------
I have a rough ride the wheel wobbles when I drive
Old 03-01-2012, 08:54 AM   #12
I went the "cheap" route and it turned out perfect after a long *** time on the alignment machine. I bought my springs and shocks/struts. Then purchased balljoints, bumpsteer, and caster camber plates. All of it was most economical but functionable. My parts list:
-FRPP "B" springs
-KYB shocks/struts
-Steeda X-2 balljoints
-Maximum Motorsports bumpsteer kit
-Maximum Motorsports caster camber plates
PICTURE BELOW OF RESULTS:
Old 03-01-2012, 09:05 AM   #13
Region: Arkansas
That's not good bud
---------- Post added at 10:05 AM ---------- Previous post was at 10:04 AM ----------
Wheel wobble that is
Old 03-01-2012, 12:52 PM   #14
That's not good bud
Been doing it for a year now. A year now that since I realized the balljoints were bad. Sounds like the ball joints?
Old 03-01-2012, 01:06 PM   #15
Project Pony's Avatar
Jack up the front end and and grab the top of the tire and give it a good tug. If you have movement could be balljoints, if you grab the sides and try to turn the wheels from side to side. Movement in that fashion could be tierods.
---------- Post added at 04:06 PM ---------- Previous post was at 04:05 PM ----------
But if you don't really know what your looking for most shops would check it fairly cheap.
[SIGPIC][/SIGPIC]
Old 03-01-2012, 01:13 PM   #16
Noise comes from balljoints. How do I know? Bc I had my gf press down on car and I was under the car and when it squeaked I sprayed liquid wrench on them and they stopped at least for a while
---------- Post added at 02:13 PM ---------- Previous post was at 02:13 PM ----------
They started squeaking again after a good hard rain and puddles got to them
Old 03-01-2012, 01:45 PM   #17
You need to have them checked. Lubes will get rid of the sound for a little while. If they are factory and squeaking just replace them. You will have a really bad day if one of them gives out.They are cheap and you can by a ball joint press from your local auto parts store for about a hundred bucks. Took me a couple hours to do both, then take it and get it alligned.
[SIGPIC][/SIGPIC]
Old 03-01-2012, 01:52 PM   #18
I take a lot of risk. Been doing it for a year and I still fly over normal speeds of 65 mph.
Old 03-01-2012, 01:56 PM   #19
Its a risk I am positive youll never take again when you blow out a balljoint....and if it happens at anything other than a slow crawl, well I hope you have a bunch of money to sink into fixing it, or buy another car....
[SIGPIC][/SIGPIC]
Old 03-01-2012, 01:56 PM   #20
Region: Arkansas
You must have had your car bought for you ?? Or just Hell on wheels
Old 03-01-2012, 02:06 PM   #21
Just hell on wheels. Y'all possibly saved my life. I didn't know it was that serious. I need to straighten up. And realize I'm not getting younger and I'm not invincible like I thought I was back as a kid. That danger is out there.
---------- Post added at 03:06 PM ---------- Previous post was at 03:06 PM ----------
Thanks y'all.
Old 03-01-2012, 02:07 PM   #22
Gotta be something like that, how old are you blackedout?
[SIGPIC][/SIGPIC]
Old 03-01-2012, 02:08 PM   #23
Hope they last another week or so.
---------- Post added at 03:08 PM ---------- Previous post was at 03:08 PM ----------
23
Old 03-01-2012, 02:15 PM   #24
23
Go buy a chilton's or Haynes for mustangs at the auto parts store, it'll be the best investment you can make for your mustang. They only run like 25-30 bucks. And check out rockauto.com for replacement parts. I've used em for years and they are so much cheaper than the auto part store chains. You could do your balljoints for like 80 bucks(that includes and chilton's book) plus whatever an alignment costs in your area. You can rent a balljoint press from advance auto or any other parts place for about 100 bucks, which you get all of back when you return it.
[SIGPIC][/SIGPIC]
Old 03-01-2012, 02:22 PM   #25
Just started put on my own.
---------- Post added at 03:22 PM ---------- Previous post was at 03:15 PM ----------
Just started putting stuff on my car my own
Old 03-01-2012, 03:02 PM   #26
Region: Arkansas
Yeah man ball joints breaking at 65 mph your toast and anyone u hit sadly
Old 03-01-2012, 03:50 PM   #27
Not driving it till I get the ball joints and put them on.
Old 03-01-2012, 05:24 PM   #28
That's a good idea, and the sooner you get done the sooner you can let her rip again.
[SIGPIC][/SIGPIC]
Old 03-01-2012, 05:25 PM   #29
Yeah
shocks and struts 5pointOh 2011-2014 Mustang GT 3 02-28-2012 07:07 AM
Looking for information about IRS suspension 1995boss 1979-1995 Mustang GT 6 02-23-2012 09:21 AM
suspension question Nashgizam 1996-2004 Mustang GT 9 02-18-2012 07:09 PM
Aftermarket shocks & struts Gobabygo67 1996-2004 Mustang GT 3 02-09-2012 03:11 PM
rear suspension robert3188 1979-1995 Mustang GT 10 02-03-2012 06:32 PM
04:54 AM
