Split port/ 4.2 stroke kit for an 03 v6 - Mustang Evolution
Old 02-29-2012, 04:58 PM   #1
RaysV6's Avatar
Send a message via Yahoo to RaysV6
Ok fellows another thread im curious about. i had read a little about the split port and 4.2 swap. now what exactly is this swap going to do for my motor? what other things will i need to look into as well. pony power torque what not. if im gunna spend my va money on my car i want the best bang for my buck. im keeping my v6 and as much as i would love to own a gt, my heart stays loyal to my 6. all ideas opinions concerns amd what not will be greatly appreciated. Thanx guys
RaysV6 is offline   Reply With Quote
Old 02-29-2012, 06:21 PM   #2
mustangg2000's Avatar
Region: Arkansas
Okay the 4.2 is a stroked 3.8 .. u can get a good one out a junk yard out a f150 on a stock basis it give u 50+ HP over the 3.8 stang engine.. will drop right in ur stang fine.. Ull want a 01 + truck engine tho..
And u can go badass and get forged internals or keep it easy both works
Windstar upper will fit right in there on the 4.2 as well
http://vapauto.com/windstar.htm
Ull need to reuse your stock cam position sensor
Oil pan
Oil pick-up tube and screen
Ur 3.8 damper
3.8 oil pressure sender and tube
Mustang header
How to: 4.2L V6 Mustang Engine Swap
mustangg2000 is offline   Reply With Quote
Old 02-29-2012, 06:27 PM   #3
You keep your computer with this swap?
What about the internals? Are they the same? Can you use the forged internals you find on supersixmotorsports? Use stock cam? And do you need a custom tune for this?
Blackedout is offline   Reply With Quote
Old 02-29-2012, 06:52 PM   #4
RaysV6's Avatar
so the 4.2 is just a basic full motor swap? couldnt i just use heads and just purchase all new internals, im planning on a turbo later down the road, so for now imma b a naturally aspirated stang. so for now would it be cheaper and easier just to do a windstar intake upgrade? is that all i need? just the upper intake?
Old 02-29-2012, 08:13 PM   #5
Region: Arkansas
Yeah you could use the 4.2 heads etc there a direct bolt up and windstar is the way to go I have one myself and sadly not even gonna be using it cause I got a super coupe set up for my 3.8
---------- Post added at 09:12 PM ---------- Previous post was at 09:10 PM ----------
Also the cams are different between the two the 4.2 cam gives a bit more torque
---------- Post added at 09:13 PM ---------- Previous post was at 09:12 PM ----------
Probably not a Hell of a lot of deference but there is some and 4.2 is a truck motor..
« 98.3 | Cut springs »
Pypes O/R H pipe for sale soccerfreak2143 Mustang Parts for Sale and Wanted 12 04-19-2012 03:22 PM
Opinion on 02 v6 Mustangg5 Pre-2005 V6 Mustang 54 03-01-2012 07:53 PM
03-04 Cobra <3 Lastoria24 1996-2004 Mustang GT 3 02-29-2012 03:04 PM
98.3 v6 Fourloko530 Pre-2005 V6 Mustang 1 02-29-2012 02:42 PM
98 v6 3.8 auto Fourloko530 Pre-2005 V6 Mustang 1 02-29-2012 11:42 AM
09:11 PM
