It's Winter, I'm cold - Mustang Evolution
Old 03-02-2012, 06:43 AM   #1
MikeWatkins17's Avatar
I changed my thermostat after my car stopped blowing hot air and that fixed the issue for maybe two days. It switches from blowing hot to cold but mostly cold. Can this have anything to do with having a low amount of fluid in the radiator resivor? Plus once in a while driving the temp gauge randomly rises then goes back to normal.. Also if i just sit in the car and let it idle it starts to over heat..
MikeWatkins17 is offline   Reply With Quote
Old 03-02-2012, 08:10 AM   #2
Project Pony's Avatar
Could be a clogged radiator or maybe a dying waterpump. Have you tried flushing the cooling system?
[SIGPIC][/SIGPIC]
Old 03-02-2012, 08:25 AM   #3
Titus Wadicus
svtlx's Avatar
Re: It's Winter, I'm cold
if its not low on antifreeze .... the question is y though. hole in radiator, hole in heater core, worst case...theres a head gasket issue. fill it up and check for leaks...everywhere.
it could just be an air pocket in there to.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-02-2012, 08:26 AM   #4
Its quick and easy to burp the system, free too so that would be a good start.
[SIGPIC][/SIGPIC]
Old 03-02-2012, 09:41 AM   #5
So just fill it up, turn on the car and see if anything is leaking?
What it takes for forced induction and much more... dreamstang 1979-1995 Mustang GT 2687 10-31-2012 11:50 AM
Could you awesome gentleman have any reccomendations on a cold air intake? memo232 Roush Mustang 10 03-22-2012 02:32 PM
if you could have ANY stang in the world, which one would it be?? zeltik General Car Discussion 80 03-14-2012 08:46 PM
Brand New JLT cold air intake for 05-09 v6 stamg saxxx Mustang Parts for Sale and Wanted 9 03-12-2012 08:56 PM
Is it really that hard?? 98StangKid 1996-2004 Mustang GT 23 03-07-2012 05:39 PM
10:07 PM
