4r70w replacement - Mustang Evolution
Old 03-04-2012, 10:23 AM   #1
4r70w replacement
Sup dude's my trans (i think) is F'd up it shifts up through gears just fine but when i take my foot off the gas it feels jumpy through downshifts and will sometimes not all the times downshift crazy hard and clank if this is the trans. and it needs replacing how hard is it to just remove and replace the transmission with the same model transmission i have never done this before but im going too if i have too so please i appreciate all advise just dont tell me to have someone do it i only have 800 bucks so thats gotta work thanks as always
l2plagears is offline   Reply With Quote
Old 03-04-2012, 11:46 AM   #2
mustangg2000's Avatar
Region: Arkansas
Well bud could be your clutch.. but its rather easy to change out your trans.. I have changed out two.. u can get a new one that's decent to good from 300-600 .. u got four bolts on the trans off the bell houseing .. but that's last first disconnect the drive shaft let's hope u ain't got custom x pipe or h pipe cause Ull have to.take it off before drive shaft.. slide it out the end off the trans will have gear oil coming out trans plug the hole or drain the trans put a jack under the trans to keep it level take out the bolts slide it out the belt housing and clutch be careful not to miss line it then basically do the process in reverse
mustangg2000 is offline   Reply With Quote
Old 03-04-2012, 02:48 PM   #3
Re: 4r70w replacement
Cool thanks man and i do have an x so that sucks but whatever doesn't sound too difficult
Old 03-04-2012, 03:17 PM   #4
Region: Arkansas
Need to check your clutch and throw out bearing so u may wanna just take it apart at the engine and bellhousing ..but nope not difficult at all jack ..jack stands .. metric sockets and rachet.. your good to go.. my buddy helped me so we didn't use a jack to stable the trans I held it as he took out the bolts
Old 03-04-2012, 03:29 PM   #5
93slowstang's Avatar
You are aware that a 4r70w is an auto right? No throw out bearing or clutch.
---------- Post added at 03:28 PM ---------- Previous post was at 03:26 PM ----------
First check your trans fluid level and make sure it's at the proper level. If its low it can cause hard upshifts and downshifts.
---------- Post added at 03:29 PM ---------- Previous post was at 03:28 PM ----------
Does it feel like it slips any while you're driving?
Old 03-04-2012, 03:35 PM   #6
Region: Arkansas
I just saw down shift my bad lol
---------- Post added at 03:30 PM ---------- Previous post was at 03:29 PM ----------
But still taken out the same way
---------- Post added at 03:35 PM ---------- Previous post was at 03:30 PM ----------
Mine is a T5 so guess thought into that a bit more but its gravy.. check your fluids like guy said .. I'd change your fluid and the trans filter .. see how that helps before u jump into a trans swap..
Old 03-04-2012, 04:49 PM   #7
Yep definitely don't want to spend more than you have to.
Old 03-04-2012, 08:03 PM   #8
I gotta a flush and filter change from ford for a b.day gift from my lady like 3000 miles ago i checked the level is fine and the fluid is nice and red thats why im assuming its about to take a dump and am preparing for the worst my friends dad told me to check the valve body gasket to see if its blown but wouldnt i lose fluig if that was the case
Trunk lid GT badge replacement Delta vt 2011-2014 Mustang GT 30 03-24-2012 05:36 PM
Floor pan replacement gc19662007 Classic Mustangs 3 02-28-2012 06:52 PM
Mozzler replacement Coryshade1995 1979-1995 Mustang GT 4 02-20-2012 05:45 PM
Heater core replacement OG86GT 1979-1995 Mustang GT 6 02-08-2012 11:28 AM
01:58 AM
