temp guage - Mustang Evolution
Old 03-05-2012, 05:41 AM   #1
temp guage
Hello fellow mustang enthusiasts.
I have a 2000 mustang 3.8 and I am having an issue. I replaced my thermostat and radiator last week, and now I am noticing that my temp gauge is acting differently. When my car is at idle or low speed I notice that my temp gauge will slowly creep up but will not come close to the half way mark, but when on the highway the temp gauge will stay on cold. The other day I drove about 30 miles on the highway and my temp gauge did not get past the cold hash mark. once I reached my destination and parked I sat there at an idle and noticed it starting to move up but not enough to where it got halfway.
The heater worked fine on the highway, heat was blowing hot. Once I got off the highway and was driving at lower speeds the heater cooled down quite a bit, but temp gauge was finally moving up.
Any suggestions at what the problem may be?
stangin is offline   Reply With Quote
Old 03-05-2012, 08:45 AM   #2
Titus Wadicus
svtlx's Avatar
Re: temp guage
sounds like u got an air pocket in there. i think it needs bled.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-05-2012, 08:53 AM   #3
Re: temp guage
how would you go about doing that. is it that bolt that runs into the top of the line?
Old 03-05-2012, 09:38 AM   #4
Titus Wadicus
svtlx's Avatar
Re: temp guage
prolly, but im not lookn at your car. did u fill your overflow all the way up? usualy they will work them selves out.
Old 03-05-2012, 10:55 AM   #5
Re: temp guage
yeah my overflow is good. Ran it for a couple days to let the fluids run, and filled overflow accordingly
Old 03-05-2012, 11:25 AM   #6
Titus Wadicus
svtlx's Avatar
Re: temp guage
then it definatley needs bled. if that doesnt fix it, then u need to investigate where its goin.
Oil Pressure Guage Problem FORDGT14 1996-2004 Mustang GT 6 03-03-2012 06:54 PM
guage problem fastback67 Classic Mustangs 7 03-02-2012 08:33 PM
Oil pressure guage Taxman 1979-1995 Mustang GT 15 02-24-2012 08:27 PM
Oil guage problem Blackedout Pre-2005 V6 Mustang 19 02-12-2012 04:44 AM
Guage / Stepper motor problem fix Charles.young10 2005-2010 Mustang GT 0 01-05-2012 09:10 AM
03:02 PM
