What size? - Mustang Evolution
Old 03-07-2012, 07:16 AM   #1
Fordhartbreaker's Avatar
What size?
What size wheel spacer should I get
Fordhartbreaker is offline   Reply With Quote
Old 03-07-2012, 07:32 AM   #2
Project Pony's Avatar
In your other thread you mentioned dropping it. You could run into problems cutting tires on the fender. I had 1 1/2 inch spacers and a 2" drop and cut mine on inclines and dips in the road. I sold the spacers and didn't have a problem after that. But now I'm running a wider wheel and it looks like it would be close if i hit a dip at speed. If your wheels are 8" you should be ok with a 3/4 or 1" spacer with it lowered. I'd be more inclined to say if your set on getting spacers then pic up the 3/4".
---------- Post added at 10:32 AM ---------- Previous post was at 10:30 AM ----------
On a 9" wheel I wouldn't do any more than 1/4. That's just me.
[SIGPIC][/SIGPIC]
Old 03-07-2012, 08:48 AM   #3
Titus Wadicus
svtlx's Avatar
Re: What size?
i have 2" drop... i was gonna get sum 18x10.5 (35series)in rear. do u think id cut a tire down?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-07-2012, 09:19 AM   #4
Venomouz831's Avatar
Don't get spacers n a drop with a wide tire trust me it ate my falkens. I had 18x10 with 285's n killed my tire with my 2 inch drop n like 1/4 spacer
)02 Gt, Founder of WE2G
Old 03-07-2012, 09:40 AM   #5
Titus Wadicus
svtlx's Avatar
Re: What size?
nooo, im not getn spacers. just the springs and 18x10.5
Old 03-07-2012, 10:29 AM   #6
I rolled my fender a couple days ago and the rubber went away
Old 03-07-2012, 11:44 AM   #7
Titus Wadicus
svtlx's Avatar
Re: What size?
lol...forgot bout that trick
Old 03-07-2012, 01:32 PM   #8
Yea super easy heat gun n rubber mallot or hammer
Old 03-07-2012, 03:23 PM   #9
Think im going to wait on the drop and just got the wheels so no buying wider ones plus the rear have brand new tires so I believe I will just go with the 25mm/1'' spacer in the back for now then maybe down the road try other options
---------- Post added at 05:23 PM ---------- Previous post was at 05:22 PM ----------
Btw G-Force bear claw tires are awesome!!! I really don't think I can make it spin with out dumping the clutch on dry road u guys need to check these things out
Old 03-07-2012, 03:53 PM   #10
If anything save the money don't buy the spacers. Just save enough and get the drop seriously makes ure car look 100x better.
Old 03-07-2012, 05:01 PM   #11
+100
[SIGPIC][/SIGPIC]
Old 03-07-2012, 07:36 PM   #12
Re: What size?
+101
Yah opt for the drop...second best appearance mod after wheels.
IMO a dropped car with tucked in rear wheels looks better than a spaced rear at 4x4 height.
Old 03-07-2012, 11:37 PM   #13
Originally Posted by sonicpony03
+101
Exactly mustangs look like their on stilts when their not dropped
What made you smile today...? deadsp0t The Bar 12811 03-29-2018 10:14 AM
What Grinds Your Gears? deadsp0t The Bar 21642 03-07-2018 10:18 AM
What did you do today? Qwik Four Six The Bar 20466 01-14-2017 03:24 PM
Painting caliber what color? Blackcat 2005-2010 Mustang GT 45 03-11-2012 07:36 AM
what do i do next for more power? angelofrat42 2005-2010 V6 Mustang 7 03-07-2012 05:26 PM
03:55 AM
