Still running lean. - Mustang Evolution
Old 03-09-2012, 08:41 AM   #1
Still running lean.
So i bought the sct flash tuner from a.m. loaded all 3 tunes 1 by 1 (really fun b.t.w if you have an auto this is a must) drove about 20 min on each and i am still throwing lean codes. wtf i thought that took care of this i have o/r selet up and was under the impression i was throwing that because of the absence of the cats but when i filled out that tune form for bama i put o/r set up i have no vac leaks i can hear and the car runs fine i cleaned the m.a.f and still the same thing i know i can clear it but i wanna know why its running lean and solve the prob instead of clearing that code all the time and acting like theres no problem any help is appreciated thanks again
l2plagears is offline   Reply With Quote
Old 03-09-2012, 08:55 AM   #2
ColeJohnson's Avatar
Re: Still running lean.
Did you try doing your own little tune and turning the rear o2 sensors off? Bama is good but sometimes they might overlook things and forgot to write that up in the tune.
2016 Comp Orange GT (current)
Old 03-09-2012, 09:02 AM   #3
No i havent looked into that do i do that when it promps me to make engine adjustments right before i load one of the tunes or is there a separate menu for that?
Old 03-09-2012, 09:35 AM   #4
I'm not certain which tuner you have, but with mine it asks to make adjustments > Keep prev options/edit options/cancel > edit options > rear 02s off.
I haven't messed with my tuner in a few months so thats a rough memory I have of how the list went. Just play around with your tuner and explore the options and you'll eventually find it.
It will not, however, be with the option of loading performance tunes.
Old 03-09-2012, 10:23 AM   #5
Cool thanks man ima get right on it
---------- Post added at 12:23 PM ---------- Previous post was at 12:04 PM ----------
Got it they were turned on thanks for the advice it was under program vehicle then under strategy tune then you had to select a vehicle file then it brought up a list of things you could adjust thanks again yo
Old 03-09-2012, 12:21 PM   #6
I'm glad you got it figured it out! You can always email Bama since they didn't write the file correctly and I'm sure they'll re-write it for you.
Old 03-09-2012, 02:37 PM   #7
Dont give me the credit you figured it out i just hit select a couple times lol
I am Still Confused Please help ME! Codysmustang 1996-2004 Mustang GT 18 04-11-2012 06:06 PM
running pretty bad 82stang224 1979-1995 Mustang GT 10 02-27-2012 09:38 PM
2010 V6 still a mustang ! wendyspony New Member Introductions & Greetings 0 02-20-2012 08:37 AM
04 gt shifter still sticking... some advice? imhooked 1996-2004 Mustang GT 18 02-11-2012 09:15 PM
Still need a HOOD - I want THIS one! Just_John Pre-2005 V6 Mustang 35 02-02-2012 09:10 AM
03:04 AM
