can I redline? - Mustang Evolution
Old 03-10-2012, 09:10 PM   #1
Send a message via Skype™ to iphonemaster93
can I redline?
I've got a '00 3.8L v6 manual with a problem with a slight crack in the manifold and a problem with the crankshaft (not clear on what the crankshaft problem is but every time i switch gears, i hear a metal noise). also when i floor it anywhere on 3000 RPMs or after the gear shifter rattles like crazy. my question is, am i still able to shift after the start of the redline zone (my redline starts at 5300 RPMs)? would i get any horsepower if i were to shift after redline? or should i just shift right on redline? what's the bad part about shifting in redline zone, will the engine just shut off or something? i really want to know because it doesn't seem like i'm getting the engine's full horsepower and torque even when i'm shifting at around 5300 RPMs, being complete stock (but i'm putting in an air intake real soon, in about a week or so). and how do i get more hp easily without spending much money? thanks in advance
iphonemaster93 is offline   Reply With Quote
Old 03-10-2012, 09:14 PM   #2
deadsp0t's Avatar
Before you worry about HP past the redline you need to address the intake issue and whatever the grinding sound is...it's not likely the grinding has anything to do with the crank.
That's unimpressive
Old 03-10-2012, 09:17 PM   #3
Re: can I redline?
i took it into a muffler shop and the guy said it wasn't a critical issue, he said i don't have to fix it (it probably won't get worse for a long time) but it's always a good thing to fix it, said it was gonna cost like $500 or something. then another repair shop told me about the crankshaft problem, test drove the car and said there's something wrong with that but he doesn't know what is. told me to go to a junkyard or something to find a newer used one.
Old 03-10-2012, 10:31 PM   #4
deadsp0t's Avatar
A cracked intake is a critical issue. Most $500 repairs are critical.. They told you to get a junk yard crankshaft?
That's unimpressive
Old 03-10-2012, 11:28 PM   #5
Re: can I redline?
so would I be able to bring it into the dealer franchise that I bought it from the replace the part? or can i just bring it into some auto parts shop and have them do it?
Can't get out of park, help! 97greenstang Pre-2005 V6 Mustang 8 03-21-2012 10:22 AM
what are small things i can do to my 2003 mustang to add some appearance? Mord Fustang 1996-2004 Mustang GT 22 03-08-2012 03:26 PM
Words can't explain!! Mustang_Madness 1996-2004 Mustang GT 3 03-01-2012 03:52 PM
Can someone photoshop these wheels? Skyza Mustang Wheels & Tires 11 03-01-2012 02:54 PM
Where can I buy this!!? HELP! 83 Fox 1979-1995 Mustang GT 2 02-27-2012 07:00 PM
09:05 PM
