Mach 1 Stereo CD Error? - Mustang Evolution
Old 03-12-2012, 11:39 AM   #1
DaYanks4Ev's Avatar
I've had my Stang for close to 4 months. Have the Mach 1000 system and my 6-disc changer has read cd error from the start. Can't eject or enter new discs. Tried disconnecting battery and no fix. Anyone have any other solutions?
Drivin' young, wild, and free!
DaYanks4Ev is offline   Reply With Quote
Old 03-12-2012, 02:17 PM   #2
Re: Mach 1 Stereo CD Error?
Im not trying to be mean but just replace it dude those head units are all over the place so you can find one for cheap and even if you have 0 audio exp. swapping a factory head for a factory head in a mustang is simple. you pull off the shifter bezel with you hands then there's two screws at the bottom of the radio bezel remove those and pull the bezel straight out pulling from the middle of it then disconnect the connectors for the rear defrost traction control and fog light(if you have them) and remove the radio bezel then there are four screws one in every corner of the head unit remove those and the radio will come right out disconnect the att. and the harness from the back and switch it for the new one put everything back and your done
l2plagears is offline   Reply With Quote
Old 03-12-2012, 02:30 PM   #3
DaYanks4Ev's Avatar
Hey thanks man! Is there ANY fix though? I just got done putting stripes and all kinds of decals on it so money is kinda tight. And if I buy a new head unit like you said, you mean an entire new stereo right?
Like this...Pioneer - 50W x 4 MOSFET AppleŽ iPodŽ-Ready In-Dash CD Deck - DEH-6400BT
Thanks again! The number of Mustangs I've owned doesn't match up to my knowledge of this stuff.
Old 03-12-2012, 02:57 PM   #4
No prob yo. You can for sure go aftermarket with the radio but then you have to get a dash kit (which suck) so it fits right then a wire harness (which you need to do some electrical splicing for) so you don't have to cut into the factory one and in some cases an adapter for the att. so you can listen to am/fm radio so you would already be up 60.00 bucks just in the crap you need just to run the pioneer.If you look you can find factory head units for 80 to 100 bucks and that's all you'll need to spend and like i said simple swap no splicing and building dash kits as far as fixing the old one i would say check to see if the fuses are blown if they are just replace them and it will cost you like a dollar if not then i would say its done for.
Old 03-12-2012, 03:01 PM   #5
DaYanks4Ev's Avatar
Sounds good! Have you heard of the iSimple? I have that installed so I can play my iPod through and AUX input. Will getting a new head affect that?
Old 03-12-2012, 03:09 PM   #6
I have not heard of that so i cant really say, don't wanna give bad advise.
Old 03-12-2012, 03:32 PM   #7
kjunitalian's Avatar
Have any cds in the changer?
kjunitalian is offline   Reply With Quote
Old 03-12-2012, 03:53 PM   #8
Yah honestly once that Mach head unit starts giving you trouble it's tough to get it working 100% again.
Same thing happened to mine last year. I tore that sonofab*tch apart twice trying to get it to load/eject cd's again and the end results were 4 leftover screws that I had no idea where they went
My head unit still works, so I can still use my Ipod dock but the disc changer doesn't..I'm too cheap to upgrade or buy a replacement so I just deal with it...besides I don't really use cd's anymore anyways.
...and don't feel bad, this is a common problem with these units...since 02 they have been jamming up in mustangs lol.
Old 03-12-2012, 04:02 PM   #9
DaYanks4Ev's Avatar
I'm not sure if there are cd's in it right now. I don't hear any noise of. Hanging discs but that's cuz it could be totally not responding. I'm not sure. I just know mine as well as 2 other friends are having the same problems in their 03's. Sucks...
Old 03-12-2012, 04:34 PM   #10
If it won't even respond than the only way to find out is to tear it apart...that's what I ended up having to do and I wouldn't have cared since 5 of them were burned discs but the 6th was my Breaking Benjamin Dear Agony CD...f*cker wasn't claiming that one
Old 03-12-2012, 04:41 PM   #11
DaYanks4Ev's Avatar
I didn't mean it doesn't respond at all. I just mean it shows cd error and there's no noise of the discs moving around inside. I'll try the fuse change if not that I'll just have to get a new head it looks like.
Old 03-12-2012, 05:02 PM   #12
03GT88's Avatar
Mine in my 03 did the same thing. I took it and just disassembled it to see if anything was broke or stuck in there I didn't notice anything. So I put it back in and somehow it worked fine and I haven't had any issues for almost a year.
03GT88 is offline   Reply With Quote
Old 03-12-2012, 05:10 PM   #13
DaYanks4Ev's Avatar
Alright. Thanks! Now I'm just afraid to mess with it.
Old 03-12-2012, 05:58 PM   #14
Oh I get ya...mine did the exact same thing for a while..."cd error" would pop up and you could hear a slight ticking, almost if the changer was trying to cycle cds and load but wasn't...my guess was that the arm or some related mechanism wore out. Again, I tore it apart and tried fixing it but had no luck. You could try and might get lucky.
Try the fuse change but I doubt that'll fix it...it sounds like the unit itself is worn out.
Old 03-12-2012, 06:15 PM   #15
DaYanks4Ev's Avatar
How do you pull of the shifter bezel? Can you do it and still he able to out it back on without damaging it or having it rattle? Seemed like in my 98 you couldn't remove or replace anything without it rattling like crap after putting it back on.
Old 03-12-2012, 07:15 PM   #16
just push it in a little on both sides and pull straight out I've taken mine apart a few times no rattle yet just try really hard no to break anything on its way out and you should be fine
Old 03-12-2012, 08:12 PM   #17
DaYanks4Ev's Avatar
Next question, I googled Mach 1000 factory head unit and it came up with a bunch of listings with two different things. Not sure which one I'd need to fix it..
One is a set of two wires going into a plug. Looks like this...
AMERICAN INTERNATIONAL FWH594 Car Stereo Harness Ford/Lincoln/Mercury 1986-2006 in Car Installation | JR.com
And the other looks like the actual face of the unit...
Ford factory AM/FM 6 disc CD player radio stereo 99 00 01 02 03 4C2T-18C815-AA on eBay!
Old 03-13-2012, 09:59 AM   #18
then its prob the second option
Old 03-13-2012, 10:43 AM   #19
stampde's Avatar
YA MINE WOULD DO THE SAME thing every now and again ,but it would work from time to time and then one day it totally stopped ..so i replaced it with a Pioneer
2011 GT Auto
Old 03-13-2012, 10:46 AM   #20
DaYanks4Ev's Avatar
Alright. Thanks guys!
Mach 1 section Nel86 Other Special Edition 71 04-18-2012 01:10 PM
Mach 1000 system. Head unit and subs an amps 1995boss Mustang Parts for Sale and Wanted 8 03-26-2012 07:23 PM
Stock stereo Karisvt Mustang Audio & Video 9 03-13-2012 03:07 PM
FICTION :: 2004 Ford Mustang Mach 1 Mezmer Member Garages 0 03-11-2012 12:26 AM
Lower Din pocket for 2000 mach system Daly2000GT Mustang Audio & Video 6 03-06-2012 01:07 PM
04:01 AM
