Supercharger Question - Mustang Evolution
Old 12-09-2007, 01:12 PM   #1
Question Supercharger Question
I have a 2003 Mustang with a 3.8L and wanted to know if a supercharger made for a Thunderbird Supercoupe with a 3.8L will work?
Bullitt03 is offline   Reply With Quote
Old 12-10-2007, 08:34 AM   #2
Herbstang's Avatar
Re: Supercharger Question
it will work But it's gonna cost and there quite alot of work involved C and P is my friend
What you'll need -----------------
-Roots blower
-SC blower top
-SC lower intake
-SC rear blower intake with SC TB
-Rear intake (from IC to lower intake)
-SC thermostat housing
-SC jackshaft pulley bracket
-SC PS pump bracket
-SC crank pulley
-SC water pump and pulley
-PS pump pulley (you can us your mustang pump)
-SC tensioner pulleys (all 3)
-if using the SC block/crank then use the 94-95 neutral balanced dampener with exeter gear, some dampeners off the F150 will work as well.
-if using the mustang block/crank then use you stock mustang dampener
-if using the SC block/crank then use the SC flywheel/flexplate
-if using the mustang block/crank then use the mustang flywheel/flexplate
-Mustang or SC starter will be fine, they are the same
-Mustang headers
-SC heads are better but Mustang heads would probably be fine (SC heads are supposedly a little stronger)
-SC injectors or eqivilent plus matching MAF
-89-93 SC came with 30# injectors and 55mm MAF
-94-95 came with 36# injectors and 70mm MAF
-all cooling hoses
-SC thorttle cable
-SC throttle cable bracket
-MUSTANG EEC
-MUSTANG wiring harness
-wire to lengthen wiring harness connectors
-extra cooling hoses for custom work
-MUSTANG timing chain cover or 94-95 SC timing chain cover
-MUSTANG crank sensor
-MUSTANG or SC alt will work, MUSATNG better sicne it has the extra connect on it, but will work without it for the SC alt, need to change pulleys if using the Mustang Alt. I believe the Mustang alt is more powerful as well, not exactly sure.
-SC AC compressor
-custom AC lines
-custom air inlet needed
-SC intercooler should work, not sure how well the SC intercooler tubes will clear but they should
or use a custom IC setup like me [img]images/smiles/icon_smile.gif[/img]
-Mustang motor mounts
-SC valve covers
-Mustang DIS module, don't need the SC one.
-SC oil cooler (not needed but good to have)
-Mustng rad will work, but if using the SC IC then might be easier to us ethe SC rad its a little smaller though but works for the SC guys fine.
-Major tuning
-SC coil pack bracket (mustang coil pack should work but I have the SC coil pack as well)
A lot of custom work is needed
Old 12-10-2007, 03:22 PM   #3
rydog's Avatar
Send a message via MSN to rydog
I think you scared him away Herb...
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 12-10-2007, 04:17 PM   #4
Herbstang's Avatar
Just tryin to let him know And then there's all the parts you wind up makin or having made
Old 12-11-2007, 06:36 PM   #5
Thanks alot Herbstang. I just had a friend who was willing to give me the supercharger but I wasn't sure how much work it would take to get it to fit.
Old 12-11-2007, 06:48 PM   #6
crazeflier07's Avatar
Send a message via AIM to crazeflier07
Might as well take the money you would spend on all that and get the M112 adapter from Super Six Motorsports and then get the 03-04 cobra blower and put it all together. Just my 2 cents.
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
~CAI, True dual exhaust, UDPs, MGW Shifter, H&R springs, Stage 1 & 2 supension kit, performance rotors & pads, steel braided lines, 1 inch rear spacers, A.R. Rebel 17x9s with BFG rubber! :thumbs2:
crazeflier07 is offline   Reply With Quote
Old 12-11-2007, 07:03 PM   #7
I would just do a turbo or a centri blower... the roots is nice but its to much for the stock bottom end~ to much heat.
Supercharger question obxdude018 Pre-2005 V6 Mustang 4 09-27-2009 01:41 PM
Supercharger Question... Sonic Blue Pre-2005 V6 Mustang 5 05-16-2006 10:12 PM
supercharger(blower) question? RED(99)GT 1996-2004 Mustang GT 6 03-09-2006 08:52 AM
supercharger question 99 sleeper vert 1996-2004 Mustang GT 7 02-03-2005 04:54 PM
supercharger question 232SCstang Pre-2005 V6 Mustang 12 03-27-2004 05:39 PM
01:41 AM
