Struts - Mustang Evolution
Old 03-13-2012, 03:11 PM   #1
Blackedout03's Avatar
Region: Delaware
Struts
Hey my friend had some front struts on his wrecked gt and said I could have them. Probably a dumb question but would I have to get alignment after I put them on?
Blackedout03 is offline   Reply With Quote
Old 03-14-2012, 07:43 AM   #2
kickerofdoom's Avatar
I would say yes but I'm not sure
Old 03-14-2012, 08:25 AM   #3
ColeJohnson's Avatar
You shouldn't have to as long as you keep the outter tie rod the same spot. Swapping struts is super simple and shouldn't throw off any suspension geometry especially since its a stock unit.
2016 Comp Orange GT (current)
Old 03-14-2012, 09:14 AM   #4
Re: Struts
yea as said, you should be fine
Old 03-14-2012, 01:46 PM   #5
Region: Delaware
I have lowering springs tho so it's not completely stock
Old 03-16-2012, 05:31 AM   #6
Lowering sprigs will change the level o compression on stock struts and will cause excessive wear and for stock units to prematurely fail. Food for thought.
Old 03-16-2012, 12:49 PM   #7
Re: Struts
Just a quick FYI: The V6 is 100 lbs lighter. It will sit real high up front.
Old 03-16-2012, 02:14 PM   #8
Region: Delaware
Thanks and what does everyone think of tokico I believe I spelled that right lol
Old 03-17-2012, 01:54 AM   #9
I run Tokico d-spec shocks and struts and I love them.
Old 03-17-2012, 07:11 AM   #10
Region: Delaware
The ones I'm getting are the Tokico HP hoping that I will be able to tell a difference since I'm only doing the front for now
Old 03-17-2012, 07:36 AM   #11
Re: Struts
Yeah, Those Tokico would be awesome.
Old 03-17-2012, 10:59 AM   #12
Region: Delaware
Ok cool would I notice a difference being how I'm just doing my fronts cause if not I'll just wait till my rear shocks come in
Old 03-18-2012, 04:35 AM   #13
Re: Struts
Oh, I would definitely do it all at the same time. I would save up and make sure you have all the parts you think you'll need to achieve what you want performance wise. Suspension work can make for a super dangerous vehicle to travel in at high speeds or make a super comfortable, nimble, quick stopping, and turning machine.
I took a couple of years to collect parts before day of installation. My parts list was:
Caster/camber plates, lowering springs, shocks & struts, X2 balljoints, bumpsteer kit. Shocks/struts & lowering springs for Fox Body.
Figure out what you want and then go for it!
Balljoints, struts, suspension, etc Ajmt719 Pre-2005 V6 Mustang 28 03-01-2012 05:25 PM
shocks and struts 5pointOh 2011-2014 Mustang GT 3 02-28-2012 07:07 AM
Aftermarket shocks & struts Gobabygo67 1996-2004 Mustang GT 3 02-09-2012 03:11 PM
Shocks/struts/springs GunMetalBullet 2005-2010 Mustang GT 11 02-03-2012 03:27 PM
Shocks and struts Justintriner 1996-2004 Mustang GT 2 12-12-2011 09:32 AM
06:46 PM
