Gt-v6 exhaust - Mustang Evolution
Old 03-14-2012, 03:54 PM   #1
Surffer227's Avatar
Gt-v6 exhaust
Will the stock dual exhaust off a gt fit my v6? Just bolted on? Or do I need to do some fab work with a welder,,,
Surffer227 is offline   Reply With Quote
Old 03-14-2012, 03:55 PM   #2
Venomouz831's Avatar
Need to fab n take it to a shop. U have n y pipe while gts have a h
)02 Gt, Founder of WE2G
Old 03-14-2012, 04:03 PM   #3
Surffer227's Avatar
Well what if it's the full system, like headers back
Old 03-14-2012, 04:06 PM   #4
The Blue Dragon
GrabberBlue5.0's Avatar
V8 headers will not fit a v6. The v8 headers have one more outlet per side than the v6 not to mentions diff bolt pattern
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 03-14-2012, 04:07 PM   #5
Surffer227's Avatar
I know... I mean from behind the headers... Lol
Old 03-14-2012, 04:13 PM   #6
The Blue Dragon
Pretty sure the pipes are a diff size
Old 03-14-2012, 04:24 PM   #7
Surffer227's Avatar
So no ones ever heard of this swap :/
Old 03-14-2012, 04:30 PM   #8
If u can get the shop to fab n weld it yea I'm sure they can do it
Old 03-14-2012, 04:32 PM   #9
Surffer227's Avatar
Well I'm more into doin this stuff myself, I'm 17 so I don't have the money to go to shops, but I go to an automotive school, so I know my stuff and have access to lifts and tools, but not Realy a welder.. Lol
Old 03-14-2012, 04:34 PM   #10
Well thts what u really would need a welder and about 5 hours of time
Old 03-14-2012, 04:42 PM   #11
Re: Gt-v6 exhaust
Installing a GT-takeoff dual exhaust system on a 99+ Mustang V6
Read this article...it's basically what you'll want to do...you can cut off the stock exhaust with a saw but you'll need to weld the GT catback up somehow.
The only way to avoid any welding is to buy the pacesetter h-pipe adapter which costs ~120. It will bolt up to your cats and to any GT catback, including the stock one.
http://www.americanmuscle.com/pacese...it-9904v6.html
But I'd imagine a shop could do those simple cuts and welds for that money or less.
It's up to you.
The stock piping is the same diameter...2.25", so don't worry about that. But you will need passenger side hangers for the muffler and exhaust tip.
Old 03-14-2012, 05:25 PM   #12
Surffer227's Avatar
Ok, thanks, so any chance on not needing to weld? I asked like everyone I know n no one has a welder :/
Old 03-14-2012, 05:37 PM   #13
Re: Gt-v6 exhaust
Well there's really no way to simply bolt the GT exhaust to your stock exhaust due to the way the midpipes are set up. On the GT exhaust the h-pipe is bolted to the cats, but it's also bolted to the 2 dual pipes on the GT exhaust.
Your stock y-pipe is attached (not bolted) to the cats, and bolts up to a single pipe on your stock v6 exhaust.
Cutting and welding is required to make it work...like I said the only way to really avoid welding is to buy that Pacesetter adapter...it simply bolts up to the stock cats and to the GT catback. I personally would weld the damn thing to the cats if it were me, but you can get away with simply attaching it.
Old 03-14-2012, 06:00 PM   #14
Horseplay's Avatar
since we are on the subject. my brother is removing his h pipe to put in a off road x pipe on his gt. i can just use his h pipe right ? what else will i be needing ?
Low2v
Old 03-14-2012, 06:05 PM   #15
Re: Gt-v6 exhaust
Yah you could use it...you'll probably have to weld it up to the cats and to whatever catback setup you have.
What's your current exhaust?
Old 03-14-2012, 06:10 PM   #16
Horseplay's Avatar
its all stock i just got a single flow 40 and i had my tip cut off just passing where the hanger is
Low2v
exhaust
post clips of your exhaust sound 1quick4.6 Pictures and Videos 37 04-02-2012 10:34 PM
Wheels/Tires Possibly for sale and GT OEM Strut Tower avengnd Mustang Parts for Sale and Wanted 7 03-28-2012 08:07 AM
04 GT horsepower shsfresh87 1996-2004 Mustang GT 61 03-19-2012 04:15 AM
New muffler or all new exhaust? DaYanks4Ev Pre-2005 V6 Mustang 23 03-14-2012 07:56 PM
Fox body exhaust Foxcrazy 1979-1995 Mustang GT 7 03-14-2012 06:18 PM
02:08 PM
