Big Problem - Mustang Evolution
Old 03-15-2012, 03:44 PM   #1
Camo1967Mustang's Avatar
Big Problem
My baby isnt starting
She is a 2001 v6
I tested her battery and its good at 12.7v
Her dash lights and gauges come on intermittently though and when I try to start her nothing happens
no sounds at all
What could be the issue?
Adrian
2001 Mustang
--AM CAI, BBK Headers, Dual exhaust, Billet grille, hood and side scoops, Sequential tail lights,
AM Headlight covers, Fog lights, Chin spoiler, H&R Lowering Springs, KYB Shocks and Struts
January 2012 StangAlley ROTM
Camo1967Mustang is offline   Reply With Quote
Old 03-15-2012, 03:51 PM   #2
Project Pony's Avatar
She is a 2001 v6
no sounds at all
Check all your cables, makes sure something hasn't wiggled loose. Intermittent dash lights would suggest loose or shorted wire somewhere.
[SIGPIC][/SIGPIC]
Old 03-15-2012, 03:52 PM   #3
Re: Big Problem
I'll keep checking
Havent found anything loose yet
Also forgot to say that we did try to jump it and she still wouldnt start
Adrian
2001 Mustang
Old 03-15-2012, 03:54 PM   #4
Blackedout03's Avatar
Region: Delaware
I'll keep checking
Could possibly be the altanater gone bad i had the same thing happen in my old truck
Blackedout03 is offline   Reply With Quote
Old 03-15-2012, 03:59 PM   #5
Ehh I don't know. Doesn't seem likely if he's reading over 12 volts on the battery and his dash light only coming on intermittently. Even with no altenator his lights should still work.
---------- Post added at 05:59 PM ---------- Previous post was at 05:57 PM ----------
I'll keep checking
What does it do? Does she turn over or click or nothing at all?
[SIGPIC][/SIGPIC]
Old 03-15-2012, 04:00 PM   #6
Re: Big Problem
She doesnt try to turn over and I dont hear anything at all
Adrian
2001 Mustang
Old 03-15-2012, 06:04 PM   #7
Check the battery ground, and the ground going to the block. I guess it wouldn't hurt to check all your fuses to.
[SIGPIC][/SIGPIC]
Old 03-15-2012, 06:48 PM   #8
I unplugged the battery n reconnected it n she started
Now I'm really confused
Adrian
2001 Mustang
Old 03-15-2012, 06:52 PM   #9
Bad terminal connection seems like. Buy a terminal wire brush to clean it real good, about 3 bucks, and some terminal protective spray.
[SIGPIC][/SIGPIC]
Old 03-15-2012, 06:53 PM   #10
Filibuster
It could really have just been a bad connection on the battery posts(as was stated earlier) this would cause the dash lights to be finicky as well...just the other day a friend of mine at work said he needed a jump,but I remembered him having a bad ground connection...tightened it and it started no prob!..
XXSTEVEO66 is offline   Reply With Quote
Old 03-15-2012, 07:32 PM   #11
Idk....it still bothers me cause some things still worked like the tail lights but the headlights, dome n dash didn't work
Adrian
2001 Mustang
Old 03-15-2012, 07:37 PM   #12
DaYanks4Ev's Avatar
Re: Big Problem
Happened to me when I had my 98 Stang. Battery tested fine time after time and I could get her to start eventually after about 5 minutes. She'd turn over and sound like she wanted to stay on but then RPM's would bobble up and down and just go to nothing and it'd die. I took it to AutoZone and they said definitely a battery issue. I had it replaced for $47 bucks and that was the solution. Also happened with my 86 Stang the first week I had it. Battery wasn't the issue, just needed new plugs, wires, and a fuel filter. Check all those, could be any one. If all else fails, new battery never hurts and with that if its still not working you know then its for sure not the battery. Good luck!
Drivin' young, wild, and free!
DaYanks4Ev is offline   Reply With Quote
Old 03-16-2012, 11:47 AM   #13
Re: Big Problem
She did it again!!
I go to start her this morning and nothing!!
But then when I took the key out I heard a clicking sound like a relay coming from inside the car
What is going on?!
Adrian
2001 Mustang
Old 03-16-2012, 12:16 PM   #14
V6 stang's Avatar
Change ur terminals so you know it's not that and you can quit worrying about that issue if it still does it. Starter? Idk I wish I knew more but not a mechanic
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 03-17-2012, 12:26 AM   #15
Justasix98's Avatar
I had the same problem in my 98'
Put it in neutral (mines an auto) an she started right up. At first it scared the ish outta me..
Just A Sixxer!
Proud member of WickedStangs Okc Chapter!
Justasix98 is offline   Reply With Quote
Old 03-17-2012, 10:47 AM   #16
Re: Big Problem
Figured it out
Was a bad relay behind the fuse panel on drivers side
She starts right up now
Adrian
2001 Mustang
Old 03-23-2012, 05:54 PM   #17
Kingmidas87's Avatar
I would try the starter solenoid. Cuz if everything else gets power but your engine doesn't turn over seems like your starter isn't getting power. Also when you turn the key to the on position can you hear your fuel pump kick on?
Kingmidas87 is offline   Reply With Quote
Old 03-23-2012, 10:42 PM   #18
Already figured it out but thanks for the input
Adrian
2001 Mustang
Old 03-23-2012, 11:01 PM   #19
Yeah sorry I didn't read the rest of the thread
Rev from idle problem CoyoteXII 2011-2014 Mustang GT 11 03-27-2012 07:50 PM
MIL eliminators problem 01mustang01 1996-2004 Mustang GT 9 03-16-2012 09:33 PM
Problem? :( 2Greeny7 Pre-2005 V6 Mustang 11 03-15-2012 07:26 AM
Big ups choppa5307 1979-1995 Mustang GT 5 03-13-2012 06:14 AM
79 5.0 oil pressure problem! 79fordsky 1979-1995 Mustang GT 3 03-12-2012 01:48 PM
10:08 PM
