12-11-2007, 07:09 PM
#1 | | Registered User
| Engine Knocking
Hey whats up guys? Havent posted in a while.. but I started hearing this clacking sound when I turn on my car. It does it most while warming up, but i hear it the whole time im driving. Any ideas? Some people said it might be my pistons, some have said fuel injector.. some have said exhaust leak..
If it is a serious problem, I might just throw in a new engine.. I want a built v6. where would I go about finding a good one.. and what kind of price range would I be looking at for the engine plus install? thanks!
12-11-2007, 07:56 PM
#2 | | Terminator Owner
| Re: Engine Knocking
supersixmotorsports.com has a good bit of v6 stuff. It could be an exhaust leak, a rod knocking, etc. You might have to let a mechanic diagnose it~
__________________ 2003 Cobra Vert (Redfire) #3938 of 5082 @ 05/27/2003
472rwhp/493rwtq - Modification List - Dyno Sheet 2012 Mustang 3.7L M6 (Kona Blue) 2011 Ford Edge Sport (Red Metallic) |
12-11-2007, 08:07 PM
#3 | | Registered User
| Re: Engine Knocking
I had a knock for 3 years. It finally gave out on me. Never found out what caused it.
12-12-2007, 09:25 AM
#4 | | Legacy Member
| Re: Engine Knocking Quote:
Originally Posted by Brent I had a knock for 3 years. It finally gave out on me. Never found out what caused it. | beer bottles under the hood
Mods-K&N CAI , True Dual Flowmaster 40,BBK Ceramic Shorties,3.73 ,T-Lok, 25% UDP, 3/8 Phenolic Intake Spacer ,Steeda Tri-ax, SCT Chip/Dyno Tune Quote: |
12-12-2007, 02:48 PM
#5 | | Legacy Member
| Re: Engine Knocking
To be honest, it's probably your passenger side exhaust manifold. Check it where the y-pipe bolts to the manifold. It has probably broken there.
Mine: -03 SB Cobra vert- 2552 of 5082 Born 02/25/03
Our's: 90 7up vert - new project-07 DSG Focus -DD 335 |
12-16-2007, 12:43 PM
#6 | | Registered User
| Re: Engine Knocking
i say it is a rod or lifter(s)
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
12-16-2007, 04:03 PM
#7 | | Registered User
| Re: Engine Knocking
Try the old broken broom handle trick to see if you can find where its coming from also some Lucas Heavy Duty Oil Stabilizer might help shut it up some.
12-18-2007, 01:04 PM
#8 | | Registered User
Originally Posted by rocknbronco Try the old broken broom handle trick to see if you can find where its coming from also some Lucas Heavy Duty Oil Stabilizer might help shut it up some. | lol its an old trick.. but ive never heard of it?
12-18-2007, 07:51 PM
#9 | | Registered User
| Re: Engine Knocking
It works well just place it along various points along the block and you will know when you find it, simply put it will sound way off the other option is a stethiscope, more than likely miss spelled..lol
07-08-2010, 10:56 AM
#10 | | Registered User
| Re: Engine Knocking
I think my mechanic may have diagnosed this problem in my 2000 Mustang, V-6. He said Ford Windstar had the same problem cuz it has this same engine. The problem is the PCV Valve Cover allows oil into the engine and the fumes create a carbon build up which causes this clattering, knocking sound when accelerating. Ford even revised this valve cover because of this problem. Check it out. |
07-08-2010, 04:42 PM
#11 | | Registered User
| Re: Engine Knocking
thread is 2 1/2 years old
closed
1970Chevelle SS 454 big block Old School 500hp Sold |
