Cleaning engine? - Mustang Evolution
Old 03-18-2012, 02:49 PM   #1
DaYanks4Ev's Avatar
Cleaning engine?
Any one know of any good cleaners or spray that will clean under the hood up really well? Putting on the plugs, wires, filters, and cold air intake on Tuesday and would like to shine everything up while I'm at it. Mainly just under the hood and maybe even under the body when I'm putting on the fuel filter....
Drivin' young, wild, and free!
DaYanks4Ev is offline   Reply With Quote
Old 03-18-2012, 03:04 PM   #2
2002Gt's Avatar
I've heard purple power does pretty good. I've never used it though
2002Gt is offline   Reply With Quote
Old 03-18-2012, 03:09 PM   #3
DaYanks4Ev's Avatar
Re: Cleaning engine?
Know where to get it from? Hoping a local auto parts store.
Old 03-18-2012, 03:10 PM   #4
2002Gt's Avatar
Yea I think I've seen it in there. Should be around the cleaning stuff
Old 03-18-2012, 03:35 PM   #5
Purple power is great! But I like engine degreaser also.
Blackedout is offline   Reply With Quote
Old 03-18-2012, 03:38 PM   #6
DaYanks4Ev's Avatar
I googled and found something called Black Magic 2 in 1 Engine Shine. Think I might give it a shot!
Old 03-18-2012, 03:45 PM   #7
Alright this is how to properly clean your motor.
You'll need tape, maybe some garbage bags to cover your fenders- KEEP IN MIND ENGINE MUST BE OFF WHEN YOU SPRAY DEGREASER!!!!!! AND SCUB YOUR ENGINE DOWN!!!!!! AFTER THAT LET IT SET IN FOR ABOUT 10- 15 MINUTES!!!!!!!!! THEN WHEN YOU GO TO RINSE TURN MOTOR ON LET THE MOTOR RUN AS YOU SPRAY AND IT'LL WARM AND BE RID OF THE WATER ON IT'S OWN!!!! COVER YOUR COILPACK, AND INTAKE FILTER IF EXPOSED!!!!! THERE IS ONLY REALLY ONE IMPORTANT DETAIL THO - AND THAT IS WHEN YOU GO TO RINSE TURN MOTOR ON AND LET THE MOTOR WARM UP AS YOU SPRAY!!!! """""NO PRESURE HOSES""""" you listen to this advice you'll have a very very clean engine and youll love it. It'll smell really clean you'll love it and it'll perform much better. I believe dirt makes the motor hotter. Enjoy and post some pictures. I'm good at this. So if you need any pictures or anything on how to set upet me know
---------- Post added at 03:45 PM ---------- Previous post was at 03:43 PM ----------
You won't like that one it makes your black hoses fade and your **** dry rott
---------- Post added at 03:45 PM ---------- Previous post was at 03:45 PM ----------
Dude trust me I know this ****
Old 03-18-2012, 03:47 PM   #8
Raiderstang's Avatar
Great advice! Thanks for the information!
Raiderstang is offline   Reply With Quote
Old 03-18-2012, 03:51 PM   #9
My engine I cleaned A year ago... And still clean...
After you wash it just keep it up with this
Just spray and wipe with micro fiber.
For more of a new look paint your radiator cover, fuse box cover, upper and lower crowl. You can find my thread on that. And bro if you do this I'm am sure you'll love it more. It will make you feel like a million bucks.
Old 03-18-2012, 03:51 PM   #10
DaYanks4Ev's Avatar
You want to inbox me some pictures? Or even email or text them to me? I'd rather see so I know what it should look like. I have a habit of trying to fix or improve something and making it severely worse and need repairs.
Example: Disconnecting my battery to hopefully reset my Mach 1000 6 Disc Player so it's quit showing CD ERROR. I popped the hood, unconnected the battery, let it sit for a while, reconnected it, and some where in the process snapped my hood latch cable and had to sit the car for 2 days so the hood wouldn't bounce while I drove. Still no fix for the 6 Disc Changer.
Old 03-18-2012, 03:53 PM   #11
Sure bro what pictures you want? How to cover the parts you don't wanna get wet?
Old 03-18-2012, 04:00 PM   #12
Here's all you need for covering your parts. You don't want that degreaser messing up your paint on your car so cover the fenders with big garbage bags and tape. Then the little walmart bag to cover the coil pack.
Old 03-18-2012, 04:05 PM   #13
Here's the basic set up bags or plastic should cover the whole fender. And cover the coil pack.
Old 03-18-2012, 04:08 PM   #14
Reason for covering is to protect your fenders when you turn your car on your belt will sling degreaser everywhere. It's all very simple. Just use a hose. Don't use any pressure hose or nozzle.
Old 03-18-2012, 04:11 PM   #15
DaYanks4Ev's Avatar
Alright thanks! You said don't get wires wet or put the degreaser on them? Should I use like a squirt bottle and spray everything really good so the most they'd be wet is just a mist if I accidentally get them wet?
Old 03-18-2012, 04:34 PM   #16
Everything else can get wet. Except coil pack it's ok if that gets wet really I don't even cover mine but to be safe
---------- Post added at 04:34 PM ---------- Previous post was at 04:33 PM ----------
Use any spraying method you want but brush everything that you can
Old 03-18-2012, 04:52 PM   #17
DaYanks4Ev's Avatar
Alright sounds good. I just bought a 32oz bottle of that stuff for $5! Gotta love Walmart clearance what kind of brush?
---------- Post added at 05:52 PM ---------- Previous post was at 05:39 PM ----------
You said keep it up with that stuff, is that not the degreaser to clean it with?
Old 03-18-2012, 04:52 PM   #18
Use this...
Old 03-18-2012, 04:54 PM   #19
A nice tooth brush. It'll get all over. Take your time.
Old 03-18-2012, 04:56 PM   #20
DaYanks4Ev's Avatar
Ah crap lol. Is that at Walmart too? The gunk stuff?
Old 03-18-2012, 05:36 PM   #21
Horseplay's Avatar
yeah they have it
Low2v
Old 03-19-2012, 03:24 PM   #22
DaYanks4Ev's Avatar
I heard to cover your alternator too. Where's that located?
Old 03-19-2012, 03:28 PM   #23
Above powersteering
---------- Post added at 03:27 PM ---------- Previous post was at 03:27 PM ----------
Guess you can cover that up too.
---------- Post added at 03:28 PM ---------- Previous post was at 03:27 PM ----------
But when you crank up the motor take those bags away and dont let anything get in that belt.
Old 03-19-2012, 03:54 PM   #24
DaYanks4Ev's Avatar
I won't! Not a chance haha
Old 03-19-2012, 05:43 PM   #25
HoofbeatofUSA's Avatar
The battery is fine through all this?
HoofbeatofUSA is offline   Reply With Quote
Old 03-19-2012, 05:46 PM   #26
DaYanks4Ev's Avatar
I was planning on covering it to! Haha. I don't know if I'm ginna wet it all with the hose like I've been told of with a water bottle. The hose seems like too much to me!
Old 03-19-2012, 07:22 PM   #27
It's not. And a battery getting wet I never had any problem. I was washing a 2001 Mitsubishi galant motor, and the car wouldn't start after and we soaked the crap outa it with a pressure hose at a car wash, so we had to dry the battery terminals and it started right up. So if that happens and it won't start dry the terminals. There's nothing wrong with washing a motor, if done right it has it's rewards. If done wrong and you'd have to be trying pretty hard to, or forgotten to take one of the precautions I told you about in the above comments. Safety just cover whatever you think you should cover. I just cover my fenders, spray degreaser, brush the motor down, and use a water hose to rinse it off. I didnt say go full stream, but just enough to rinse the gunk off. This isn't rocket science. Like I said you'd be having to try really hard to mess something up.
Easy steps* prep, spray, brush and rinse. Walla.
---------- Post added at 07:04 PM ---------- Previous post was at 07:02 PM ----------
I recommend washing only once a year tho. You shouldn't have to wash it anymore. Just use common sence. It's not hard.
---------- Post added at 07:06 PM ---------- Previous post was at 07:04 PM ----------
And a water bottle seriously? That's the most ridiculous thing I ever heard.
---------- Post added at 07:22 PM ---------- Previous post was at 07:06 PM ----------
Hope this helps
Old 03-19-2012, 07:23 PM   #28
DaYanks4Ev's Avatar
I'm not stupid lol just really not wanting to wash too hard or fry something lol. And I know a water bottle sounds stupid, the person that told me just said it doesn't put near as much water or force on everything.
Old 03-19-2012, 07:25 PM   #29
Of course theres nobody calling you stupid. It's only natural to be nervous the first time you do something. It's understandable.
Old 03-19-2012, 07:27 PM   #30
DaYanks4Ev's Avatar
Especially when you have a history of buying something to replace, ruining it while replacing, then having to buy again. All the while it's something that determines how much the car is driven while I'm doing the replacement.
Old 03-21-2012, 06:44 AM   #31
I really would have never guessed you can spray the alternator like that
Old 03-22-2012, 10:38 PM   #32
Kingmidas87's Avatar
The purple bottle "super clean" I think, works wonders! I have always used it but I have since found out it can corrode your Metal surfaces. My Crome cold air intake tubes are nasty and the intake Manifold looks kinda "hazy". It gets off the engine oil and cleans up the battery, brake master cylinder and power steering pump really good but I would just suggest to dilute it 50/50 or add even more water.
Kingmidas87 is offline   Reply With Quote
Old 03-27-2012, 12:00 AM   #33
SoCalKev's Avatar
Send a message via Skype™ to SoCalKev
Very Purrty engines lmao
SoCalKev is offline   Reply With Quote
Old 03-27-2012, 12:05 AM   #34
Carb cleaner fixes everything
Crunch9876 is offline   Reply With Quote
check engine light 2002Gt 1996-2004 Mustang GT 48 03-31-2012 07:11 PM
MAC ProChamber & V6 Engine robb15033 Pre-2005 V6 Mustang 8 03-24-2012 11:55 PM
Engine Miss Taxman 1979-1995 Mustang GT 16 03-19-2012 02:33 PM
Engine shaking at start up 813floridaracin Pre-2005 V6 Mustang 5 03-14-2012 08:54 PM
Engine shops? WhiteCobra94 1979-1995 Mustang GT 10 03-13-2012 02:59 PM
06:52 AM
