Help chin spoiler - Mustang Evolution
Old 03-20-2012, 04:14 PM   #1
Help chin spoiler
Those with chin spoilers, how did y'all install them? I know I have to let it sit for 24 hours. But I'm letting mine sit out for 3 days going buy me some ramps to drive my car onto. Any help?
Blackedout is offline   Reply With Quote
Old 03-20-2012, 04:17 PM   #2
Rm360's Avatar
Is it urathane or plastic?
Old 03-20-2012, 04:25 PM   #3
Venomouz831's Avatar
Easy just bolt it on just try to get it flush. Lol sit for 24 hours?? Who said tht
)02 Gt, Founder of WE2G
Old 03-20-2012, 04:29 PM   #4
Rm360's Avatar
I have the urathane one I let it sit in the sun for a hour to let the material get flexible, then I supported th middle and drivers side end with jack stands , starting from the passenger end I held up the spoiler flush to the corner and front bumper marked my 1st hole drilled 1/4 inch hole put spoiler back up and pushed in the plug repeat for the remaining holes . If u end up a bit long on the driver side corner use a dremel tool with sanding wheel to flush up the corner take ur time with this step.Good luck!
Old 03-20-2012, 04:44 PM   #5
stampde's Avatar
Re: Help chin spoiler
there's holes in the lower underside of the bumper cover ,and its held on with plastic push /screws
fairly simple , didn't your chincome with hardware ?
if it didn't you can go to your local Ford dealer and get it for an 03 Mach 1
2011 GT Auto
Old 03-20-2012, 05:02 PM   #6
I have all my screws. Every last 14 of them. And all with two washers and one nut each. So I have all the hard wear. So should I use duct tape to support it up?
---------- Post added at 04:02 PM ---------- Previous post was at 04:02 PM ----------
And it's plastic
Old 03-20-2012, 05:59 PM   #7
Does this look good ? I have it taped up. How do you tell if it's on the way it should like lining it up wise
Old 03-20-2012, 06:05 PM   #8
Horseplay's Avatar
do you mark the holes when you have it taped up? and then remove the lip so you can drill it? or just drill it while its taped ? and what drill bit size r u using ?
Low2v
Old 03-20-2012, 07:14 PM   #9
shaqfu's Avatar
I just pulled up to edge of the curb and went under.
i duct taped mine, then drilled holes and mounted, while it was still taped on.
came up a couple screws short from all the holes in the spoiler, but just balanced out the total.,
looks like you got it on straight! the video below shows how...
How To Install A Mustang Mach 1 Chin Spoiler - Intensive Installation Instructions at AmericanMuscle.com - Free Shipping!
shaqfu is offline   Reply With Quote
Old 03-20-2012, 09:42 PM   #10
Alright the chin spoiler is on. Ive got it in place. I used gorilla tape to tape it up. And drilled the holes. And done. Was missing one screw tho.
Old 03-20-2012, 09:43 PM   #11
Horseplay's Avatar
what size drill bit ?
Low2v
Old 03-20-2012, 09:44 PM   #12
Old 03-20-2012, 09:49 PM   #13
1/4
---------- Post added at 08:47 PM ---------- Previous post was at 08:45 PM ----------
Use gorilla tape. It holds best. And get the chin spoiler on and just move it to where you want it. You can have it up on the bumper and modify one part at a time
---------- Post added at 08:49 PM ---------- Previous post was at 08:47 PM ----------
Next is going to be STANGMOD'S Gt hood scoops and side scoops. Then American muscles rear window louver. I'm going back with my window louver it's my most favorite addition.
Old 03-20-2012, 09:51 PM   #14
Bballing0416's Avatar
Take a hair dryer to the chin spoiler and heat it up to get it flexable then tape the chin spoiler to your bumper and begin drilling holes and just go one screw at a time and youll be golden
Bballing0416 is offline   Reply With Quote
Old 03-20-2012, 10:05 PM   #15
I have mine 1/2 inch set back
---------- Post added at 09:00 PM ---------- Previous post was at 08:58 PM ----------
It looks better set back I taped it on lined up with the bumper and I disliked it. And americanmuscle said a 1/4 inch. But I decided half inch set back. Loved it. It looks too ordinary all the way up
---------- Post added at 09:05 PM ---------- Previous post was at 09:00 PM ----------
The corners of the spoiler meets up with the inner fender part of the bumper and flush too. Looks pretty good
Old 03-20-2012, 11:17 PM   #16
shaqfu's Avatar
Looks good. I would like a gt hood scoop as well!
work in progress...
2002 v6, Dual Flowmasters, SCT SF3/X3 Tuner, AM CAI....
next up lowering, gears...
Exhaust help 1lowGT 1996-2004 Mustang GT 15 03-21-2012 04:13 PM
Help!!! QuickFoxbody 1979-1995 Mustang GT 3 03-20-2012 02:23 PM
installation estimate help Beau 2005-2010 V6 Mustang 6 03-20-2012 02:06 PM
Jba shorty header help? Wshewan 1996-2004 Mustang GT 0 03-20-2012 08:48 AM
2011 mustang mykey help killrocker52 2011-2014 V6 Mustang 4 03-19-2012 07:45 PM
01:03 AM
