Is it possible? - Mustang Evolution
Old 03-20-2012, 09:13 PM   #1
2003SonicBlue's Avatar
Is it possible?
Taking an 03 stock v6 and putting a 5.0 crate engine in... What would i need to do to my suspension or anything for it to handle the power? I know I'd need to swap the trans but what else
2003SonicBlue is offline   Reply With Quote
Old 03-20-2012, 10:14 PM   #2
Venomouz831's Avatar
Rear end for sure braking
)02 Gt, Founder of WE2G
Old 03-20-2012, 10:42 PM   #3
NeedSomeMods's Avatar
Complete wiring harness, computer, etc unless you're planning on a carb motor. You may have to swap k-members, I'm not sure on 99-04.
Rear end should be swapped for an 8.8" GT one.
Transmission should be fine but bellhousing will have to be swapped.
If your pony has a good amount of miles, I'd recommend replacing/upgrading most of the front suspension. My '94 was riding smooth before the swap. About 900 miles after the swap my steering wheel was shaking like crazy, tires wearing unevenly, etc. took it in and all but one of my balljoints were shot.. I replaced shocks, new balljoints, and good to go again. Still riding on v6 springs.
It's a tough job, and usually more work and money than it is worth.
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 03-20-2012, 10:50 PM   #4
My 03 has 44,000 miles
Old 03-20-2012, 10:50 PM   #5
Brett Greene's Avatar
Thousands and thousands of dollars
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 03-20-2012, 10:53 PM   #6
The above was talking about pushrod 5.0s, if you're talking about coyote engines.. That's a whole 'nother ballgame there.
---------- Post added at 10:53 PM ---------- Previous post was at 10:51 PM ----------
not including the cost of the crate motor! Lol
2000 V6 - RIP
The '94 -
Old 03-20-2012, 10:55 PM   #7
http://www.cjponyparts.com/ford-raci...ng/p/M6007M50/
Old 03-20-2012, 11:15 PM   #8
Yeah.. That'd be a coyote.
You can't just "drop in" a new 5.0 into your car. Being a v6, by the time you got the motor, wiring harness/PCM, transmission, driveshaft, rearend, suspension, brakes, etc you'd be close to the cost of a used 2011 GT. Just speaking realistically. You would be MUCH better off trading in your car for an '11 GT.[COLOR="Silver"]
---------- Post added at 11:15 PM ---------- Previous post was at 11:09 PM ----------
On a brighter note, IF you decided this is what you want and IF you have the cash to blow, it would be awesome. With the popularity of the New Edge design, and the power of the new 5.0, that would be one sick car!
2000 V6 - RIP
The '94 -
Old 03-21-2012, 01:27 AM   #9
Re: Is it possible?
Coyote=
New style gas pedal + module + cover plate under pedal. Relocation of AC compressor. Couple of other things, I can't remember. A few magazine articles have featured the drop in.
Old 03-21-2012, 05:17 AM   #10
Thanks guys. I was thinking about doing this after college. From the looks of it I'll keep my v6 until college is done with then I'll invest in a 50th anniversary xD
AM window tint -- did i just ruin it?? RickPollock 2011-2014 Mustang GT 6 03-21-2012 06:41 PM
Anyobe order the steeda spacer and not receive gaskets wit it? Watchawow07SGT 2005-2010 Mustang GT 13 03-21-2012 08:14 AM
Which coil is better? Blackedout Pre-2005 V6 Mustang 12 03-21-2012 05:36 AM
What is a better header? Minus2380 1979-1995 Mustang GT 3 03-20-2012 09:04 PM
this is probably a dumb question medicespo 2011-2014 Mustang GT 7 03-20-2012 01:01 AM
01:57 AM
