Gas tank question - Mustang Evolution
Old 03-27-2012, 08:27 PM   #1
Gas tank question
I have a 2000, and it's 12 years old obviously, I wanna drop my tank and clean it, just bc I want a healthier fuel tank, I'm doing it just for precautions. So how do you clean the gas tank?
Blackedout is offline   Reply With Quote
Old 03-27-2012, 09:47 PM   #2
Kflynn318's Avatar
Gas naturally cleans as is. It would be a waste to drop the tank for just "cleaning" just keep running and switch to a premium tank 1 time a month. If u absolutely want to clean it drain it. Spray with brake cleaner and rinse the bottom with fresh clean gas
Kflynn318 is offline   Reply With Quote
Old 03-28-2012, 12:21 AM   #3
Kingmidas87's Avatar
I'm not sure about the different octane cleaning anything but different gas company's have different additives. I've gone with chevron and it's been good gas. My buddies dad restored and old rusty motorcycle tank by throwing a couple handfuls of nuts in side then shook the piss out of it. The nuts broke up all the rust and hard gunk. I figure if you REALLY wanna check it out I'd do it on a empty tank, drop it, take the pump out and take a flash light and look around inside. If there is build up you might be able to fit your arm inside with a putty knife or if it's really bad you could try the nuts idea. I would put a couple pounds in it then bounce it to death on a trampoline or roll it around on a lawn. Then flush it out with gas, install a new pump and sending unit, throw it back in and you're good to go.
Kingmidas87 is offline   Reply With Quote
Old 03-28-2012, 01:09 AM   #4
Re: Gas tank question
Hot soapy water (Dawn Dish Liquid works well) and a handful or two of marbles, hex nuts, ball bearings, etc., etc..
Fill tank about a 1/4 full of the hot soapy water.
The hotter the water, the better it will work.
Add the agitation objects and shake well.
Rinse well with hot water, remove the agitation objects and inspect.
Dry out with compressed air or let it sit out in the sun and dry out completely.
The hot soapy water will help dissolve the sludge and the agitation objects will help break up any accumulated gunk and rust.
Old 03-28-2012, 05:17 AM   #5
Alright
---------- Post added at 05:17 AM ---------- Previous post was at 05:15 AM ----------
Alright thanks
Old 03-28-2012, 05:38 AM   #6
Might as well put that 255 fuel pump in while your at it. You know your gonna eventually anyway, knowing you-
Old 03-28-2012, 10:05 AM   #7
Yeah with the soapy water would prob be better.
Old 03-28-2012, 10:29 AM   #8
Venomouz831's Avatar
---------- Post added at 08:29 AM ---------- Previous post was at 08:29 AM ----------
Originally Posted by Venomouz831
ddc4d
K nvm emoji don't work lol
)02 Gt, Founder of WE2G
Old 03-28-2012, 06:42 PM   #9
Where can I get one? And does it need a tune?
---------- Post added at 06:42 PM ---------- Previous post was at 06:40 PM ----------
And what do I look for I know nothing about fuel pumps. Never got there yet.
Old 03-28-2012, 07:25 PM   #10
BBK Electric Mustang Fuel Pump Kit - 255 LPH (86-97 V8) 1607 - Free Shipping!
It does not need a tune because we have a return fuel rail (I believe thats how it is discribed) but no, you do not and you can go higher no problem. It is something that will be needed if you plan on incresing HP considerably in the future. Another reason for getting one (My reason right now) is when the fuel system check valve starts to fail and it takes a second or two more to crank over the engine. I get around it right now by priming the pump before starting it- Turning the key but not enough to start the engine so that the fuel pump turns on and fills up the fuel line- then I start the engine. Dropping the tank is a big job, I have been putting it off. Alot of people have suggested to me buying an Edlebrock fuel pump, but they all seem pretty reliable.
Old 03-28-2012, 07:41 PM   #11
What's ddc4d?
---------- Post added at 07:41 PM ---------- Previous post was at 07:39 PM ----------
ddc4d ddc4d ddc4d ddc4d ddc4d ddc4d ddc4d ddc4d ddc4d ddc4d ddc4d ddc4d ddc4d ddc4d ddc4d ddc4d ddc4d ddc4d ddc4d ddc4d
Won't fit my 2000 mustang
Old 03-28-2012, 07:53 PM   #12
99-04 Mustang Walbro Fuel Pump 255-317 lph
Sorry, Same thing, just another model year. same situation though, understand.
Gas prices D: zeltik The Bar 134 04-28-2012 05:34 AM
Gas gauge issues... 2002VertGT 1996-2004 Mustang GT 26 04-02-2012 07:02 AM
Wheel Spacers Question CYCLON37 General Mustang Discussion 0 03-27-2012 02:13 PM
those gasoline really evaporate from gas tank? robertoortiz85 1996-2004 Mustang GT 5 03-26-2012 09:27 PM
electrical question 93_347foxbody 1979-1995 Mustang GT 22 03-25-2012 09:37 PM
06:11 PM
