EGR vacuum solenoid wiring - Mustang Evolution
Old 03-28-2012, 02:35 PM   #1
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
SO the wire harness / plug that goes into the egr vacuum solenoid has officially crapped out on me, the wiring was corroded and had literally no other choice but to give it a snip with some wire cutters at the main harness which i now have a grouping of cut wires staring at me. Now obviously I'm throwing codes due to it. Can't find anywhere online to buy the wiring/plug, I don't need the solenoid, any help ?
2002 3.8
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 03-28-2012, 09:22 PM   #2
Re: EGR vacuum solenoid wiring
Is that your picture in the avatar?
-I will search for a replacement for you but a better option would probably be to have your SCT tuner files adjusted for an EGR delete.
Old 03-30-2012, 06:27 PM   #3
Dark02Pony's Avatar
haha no, its not me chief. However, I have the predator and turned off my EGR switch but still throwing the code for egr differential pressure since the vacuum solenoid isn't hooked up due to said connector
Old 03-31-2012, 12:44 AM   #4
I researched the EGR connections and the DPFE sensor but I think the very best option is to visit the salvage yard tomorrow & be done with it.
No EGR Kingmidas87 Pre-2005 V6 Mustang 10 03-26-2012 12:36 AM
solenoid wire & tail light question 93_347foxbody 1979-1995 Mustang GT 11 03-22-2012 11:40 PM
Egr question? Wshewan 1996-2004 Mustang GT 0 03-22-2012 08:22 PM
Egr valve bolt on manifold. What size wrench? Wshewan 1996-2004 Mustang GT 5 03-20-2012 03:36 PM
I need a 4.6 motor trans and wiring harness Hdavis013 1996-2004 Mustang GT 0 03-15-2012 09:39 PM
03:41 AM
